Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 4.75 average. Display Modes
Old 07-18-2008, 11:51 PM   #1
Poorboyz
My Ride: 2001 330Ci
DIY -- Coupe B-Pillar Panel removal
After much searching I could not find a how to remove B-pillar for dummies (me) so I decided to write one up with lots of pictures. Any suggestions are welcome to make this more understandable if I don't explain it quite the right way. I have numbered the pictures 1-18 for easy identification. Picture 1 has the tools that I used.
Tools:
T-20 Torx
T-50 Torx
Flathead screw driver
wire cutters
Step 1: Start out by placing your hand in underneath the seat bottom and lift up. The is 2 clips holding the seat bottom in place, one on each side of the seat. Refer to pictures 2-5 if you have any problems.
Step 2: Take your T-20 Torx and use it to remove the 2 screws in the arm rest. This has to be done so you can pull out the panel out just enough to undo the 2 clips holding the B-pillar cover in place. Refer to picture 6 if you have any problems.
Step 3: Open your rear window and pull the window molding/rubber up. This is done so it'll be easier to push the panel into place when putting everything back together. Refer to pictures 7 and 8 if you have any questions.
Step 4: Pull out the door molding just a little bit so you can get your fingers/hand in behind the panel and pull it out. Refer to pictures 9-11 if you have any questions.
Step 5: You should now see the 2 clips that hold the B-pillar into place. Take a screw driver or wire cutters to pry up on the clips. Once those are out the B-pillar should just slide straight down. Refer to pictures 12-15 if you have any questions.
Step 6: Again take your flat head screw driver and place it in between the carpet and the little black plastic piece as illustrated on picture 17 and pry outward. It should just pop right out. Take your T-50 Torx and undo the bolt. Lift up on metal bar once bolt is out and slide the seat belt out. Refer to pictures 16-18 if you have any questions.
At this point repeat Steps 1-6 for the other side. Any questions or suggestions?
Chuck
ID:	278566   Click image for larger version
ID:	278567   Click image for larger version
ID:	278568   Click image for larger version
ID:	278570   Click image for larger version
ID:	278571   Click image for larger version
ID:	278572   Click image for larger version
ID:	278574   Click image for larger version
ID:	278575   Click image for larger version
ID:	278576   Click image for larger version
ID:	278578   Click image for larger version
ID:	278579   Click image for larger version
ID:	278580   Click image for larger version
ID:	278582   Click image for larger version
Poorboyz is offline   Reply With Quote
Old 07-19-2008, 12:03 AM   #2
phrozen06
phrozen06's Avatar
My Ride: E46, E92 M3, R32 VW
Send a message via Yahoo to phrozen06
Don't you need to reinforce the underside before removing the B-Pillar. I realize that coupes still have the hard top but in terms of body flex it seems that without the B pillar body flex would occur more easily
phrozen06 is offline   Reply With Quote
Old 07-19-2008, 12:06 AM   #3
Poorboyz
My Ride: 2001 330Ci
I'm removing only the B-pillar panel on the inside to replace the worn out cloth that's peeling back on the panels. My A, B and C pillars are doing this.
Old 08-26-2008, 01:35 PM   #4
e30m3izzle
Banned
My Ride: 1999 323i pal!
great diy thank you
e30m3izzle is offline   Reply With Quote
Old 05-25-2009, 01:13 AM   #5
BMW_Stu
My Ride: HPF 330ci
why is this censored?
BMW_Stu is offline   Reply With Quote
Old 06-21-2009, 02:39 PM   #6
bumere46
My Ride: E92
same procedure w/sedans?
bumere46 is offline   Reply With Quote
Old 07-02-2009, 04:32 PM   #7
Hellishness
My Ride: Interlagos M3 ZCP
what word is it?!?! am i missing something???
'06 IB M3
2 E30 Verts
Hellishness is offline   Reply With Quote
Old 07-05-2009, 02:53 PM   #8
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
what word is censored?
delmarco is offline   Reply With Quote
Old 07-07-2009, 02:05 AM   #9
delmarco
hello?
Old 07-07-2009, 07:34 AM   #10
misterlau
My Ride: Audi TT, M3 Coupe
For some reason, "B - p i l l a r" is showing up as B*****ar!
misterlau is offline   Reply With Quote
Old 07-07-2009, 07:45 AM   #11
ProchaineStation
My Ride: 03 Corolla
Send a message via MSN to ProchaineStation
I will answer the question about the censorship.
Thje admin of this site said, ''too much spam contains that word so i censored it''
Next Stop: ProchaineStation™
www.youtube.com/AntoDamicoShow
ProchaineStation is offline   Reply With Quote
Old 07-07-2009, 11:27 AM   #12
russ330
Mod Squad
russ330's Avatar
My Ride: Motorsport III
Send a message via AIM to russ330
^very good.
russ330 is offline   Reply With Quote
Old 07-08-2009, 11:45 AM   #13
delmarco
I actually figured it out about 3am last night whiles in mid sleep.
B****ar let me get a P and L and two vowels I and A!
lol....I guess I dream in Wheel Of Fortune vision!
Old 07-08-2009, 08:39 PM   #14
dirsh
Hawaii 3.0
dirsh's Avatar
My Ride: sanbyaku sanjuu
great write up!
just what I needed
Hello dirsh it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
dirsh is offline   Reply With Quote
Old 07-08-2009, 08:46 PM   #15
ProchaineStation
My Ride: 03 Corolla
Originally Posted by russ330 View Post
^very good.
I got your approval
Old 03-22-2010, 01:45 AM   #16
jenewein
My Ride: 323i
+1 I need to do this, are there any insturctions for doing this on a sedan?
jenewein is offline   Reply With Quote
