#41 |
Update: I got my software updated too! and omg it's like a brand new car.
![]() I went to Steven Creek BMW in San Jose and my service advisor told me he knows about this problem and it happen's to E46's all the time. I just went in, 15 minutes later got the car out and off i went. No service charge, so yes re flashing your software with a new updated software to solve transmission jerk is the answer.
![]() Sold Steel Gray BMW 330ci 2003 Current Carbon Black BMW ///M5 2003 Mini Cooper S 2003 |
#42 | |
While this resets the adaptations in the DME and EGS, the problem will most likely return. The only true solution is a software update. The adaptations are only sensor related, and once the sensor adaptations are relearned, the clunk will return. The new software changes shift mappings and solenoid actions while downshifting which will eliminate the clunk. |
#43 | |
#44 | |
#45 |
I have an 01 330i with performance package...it just started hesitating at 5500 rpms, only when in gear...do you think the software update will fix that too...also, how often should I service the trans. and is there a diy for a trans flush? thanks
#46 |
My Ride: Fern Green 318i exec
Yes, just did this on mine with an immediate improvement but I'm thinking it will return after "adaptive driving" kicks in.
![]() LED Tails / LED Plate Lights / LED Interior Lights / Angel Eyes / Smoked Corners / Smoked Side Indicators / Low beams - Narva Arctic Blue / High beams - Narva Plus 50 / Gauge Rings / Black Grille / Roof Spoiler / Boot Lip Spolier / Licence Plate Holder Deleted / Tinted windows / Style 44 Wheels/Coilovers. |
#47 |
I did the "key in 2nd position and pressed the pedal to the floor for 30 sec." it seemed to work. I still want to change the tranny fluid...is it possible to avoid the stealership and do it myself? I called Crevier BMW in CA and the service advisor was very rude and said I have to bring it in for a service before they can tell me if I am in need of a software upgrade...anyone know any honest BMW techs that can update my cars software here in OC?
#48 | |
#49 |
WOW my 2003 330i has the same prob. Mad annoying. I do notice it only in the morning and gone after car heats up. anyone knows the exact software needed ?
#50 |
I had mine re-flashed for $210 + CA tax. It worked for a couple of hours then a slight jerking came back.. A couple days later it went back jerking when it slows down going to a stop. I have my tranny fluid changed. Bushings were verified.. Help....... Refer to this bulletin: http://img240.imageshack.us/img240/8060/image001si5.jpg or
#51 |
My '03 325i has the same rough downshift issue. It only happens occasionally, and then after the car has been driven for a while.
But... whenever my tranny does this rough downshifting, it is preceded with the a/c compressor kicking off and not coming back on, although it's 90 degrees here now and it should be cycling on. These two always happen together. What would the tranny and a/c have in common? |
#52 |
My Ride: 2003 325i
Had my car since August 2008 & have experienced this from the beginning.
I've just replaced pads & rotors all around & it did not fix the bump while slowing down. I really thought it was a teh brakes grabing when cold. I have just made an appointment & RMP Motors for tomorrow morning to get reprogrammed. I will report back. |
#53 |
I had the same prob. with my 328i 99 Jatco trans. ( Imported form Japan)happen only when cold in 1st & 2nd, then in the high way between 3-4th when downshift only. It seem need updating as it cleared in the TIS for e36. I'm not sure if the same prob. for e46.
Any new news. please feed back. I'm trying battery disconnect, hope this will help a little. I have already did the trick of key & depress for 30 sec. didnt solve it. |
#54 |
My Ride: 2003 325i
Ok, so good so far. I went to RMP Motors this morning & for $60 I had my 2003 325i reprogramed.
No downshifting clunks all day. We'll see how it goes ... |
#55 |
#56 |
Yep, it has returned to the usual clunk.
#57 |
My Ride: 2003 325i
#58 |
I only did the battery disconnect - haven't had time to get software loaded as yet.
#59 |
Had the transmission software upgraded yesterday, and now the jerk during the 2 --> 1 downshift is gone and it's smooth as butter!
#60 |
My Ride: 2003 325i
I had it reprogrammed two weeks ago today & the bump has not returned.
For a few days after programming I did notice a slight rpm flare between upshifts, 2-3 being the most noticeable, but that cleaned it self up after a few days of learning. |
| Tags |
| jolt, stopping, transmission |
