Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
#21 |
#22 | |||||
The materials used dont mean anything if the structure cannot support the forces involved. The body on my car is made of steel. I can punch a large size dent in the side of it. If that body were 1/4 thick of the same material I would break my hand. See the difference? The shape/structure also matters. There is a lot that goes into motor design to allow it to hold a certain amount of power. Quote:
Aluminum is better for turbocharging because it conducts heat away from the combustion chamber faster. Lower burn temperatures allow you to run more boost or a higher compression ratio. Once again you are discussing things you seem to have little background on and making generalizations based on opinions and feelings. Quote:
It is always good to discuss. You need to get a good look at a motor (block) in pieces to see how well it is built. You look at web thickness, types of cylinder liners, upper deck stability and layout, main bearing support, oiling system (critical), ect. Many factors. If people want to put up the cash then we can build a kit.
#23 |
Subscribed
330i SMG M-Sport Paket II Euro Spec
Mods: CF Roundels all around, Black grillz, 7000k Angel eyes,6300k HID fog lights, Hamman Lip reps, ACS roof spoiler reps, Alutech front and rear struts, BMC CDA with DIY heatshield, Pro RS braided brake line, ///M Billet Oil Cap, OEM ///M mats, ///M aluminium pedals, ![]() |
#24 | |||||||||
![]() Quote:
![]() Using the same example, you punching the side of the body has no effect on anything other than cosmetics. The materials used are everything.. you don't get it. I posted everything from what the block is made of to what the rods are made of. Quote:
![]() That's your opinion and I never made a claim at what the most important parts are. I said that tuning would need to be found, and certain parts are universal and can be purchased from anyone. Internals can be found, too, as can a fuel system.
![]() '03 330Ci 5spd PP Alpine Type R, MRP 500 Last edited by Attaus; 05-29-2009 at 01:21 PM. |
#25 |
Keep it clean
Let's keep this an informative discussion, not a finger pointing session. People need to stop face-palming unless they want this thread to go to crap.
#26 |
My Ride: have 5 doors and FI
shhh - I am just watching this...
and not yet...hopefully this week (dme finally being programmed for the bigger injectors and 8psi more FI)
![]() /_________\ OO=[][]=OO |
#27 | |
Grüne Hölle Junkie
Side note- I hate you! ![]() oh, subscribed...
#28 |
hey, dont hate...this has been a long wait...and hopefully it will be done soon
#29 |
Keep it clean
8 more psi? How will I ever catch you now? I guess I'll need 2 bottles
#30 | |
The stud problem is that if you use the ARP studs, they are simply too hard and will pull the threads in the head out. The OEM head bolts allow it to stretch with the soft Al block. If you want, you can buy the extra M54 block I have that is already time-serted and you can R&D a kit to sell. It even comes with brand new OEM pistons. I was able to whoop on stock 350Z in my older setup.
#31 |
Keep it clean
I couldn't get my friend to race me
My buddy drove both our cars. He thought I'd have him from a dig, but he'd get me up top. I'm hoping to find out next weekend.
#32 | |
58mm of Bliss
I suspect I may be the only person to see over 400rwtq on an M54...and my head hasn't lifted. The only cracked blocks I know of are from over-reving an engine. It is true that the M54 aluminum block has a potentially weaker structure than that of an iron block of similar design. But, this is only from a metalurgical point of view, and may not apply to this application. The only way to find out is to start stepping up the power ladder and taking carefull measurements along the way. BTW, do you have deep pockets? This "ladder" isn't cheap. |
#33 | |
My Ride: '90 325i, '02 325it
- James '85 E30 325e '90 E30 325i '02 E46 325it '03 E46 320i '96 Volvo 850R ![]() |
#34 | |
Notice the comparison cars I mentioned were also bmw's, that in stock form would outhandle the 330, and would also make more power for the $$. Also please explain how a supercharger risks daily driveability? Myself and many others on here have been running our SC kits for 30k+ miles A 323/325 with a $4000 SC kit will beat up on a stock 350z, and 328/330s will walk them HARD... ask me how I know. A custom kit would end up costing more $ and time than it's worth IMO, and that's even if you can find someone willing to tune your hardware. As Brian stated, the problem isn't with the studs, it's with the threads in the block. I know of a particular car being built right now, hoping to get 450+rwhp with the b30 + turbo. It isn't going to be cheap, but it'll definitely be interesting to see how it turns out. Adam's motor is an exception. It's not in our league anymore lol.
#35 |
NA V8
Good thread as I plan to go FI sometime next year
![]() M3 DCT/Swift Spec R Springs/Macht Schnell Spacers/Megan Exhaust/Coming Soon: Test Pipes and BPM Stg 2 Tune |
#36 | |
I wanna try this race (please note others in thread, HR Z >> DE Z, 2003-2006 = DE, 2007-2008 = HR). I'm 99% sure I'd take Stan, it should be a decent race, but I still think I'd have an advantage ona b25 running 8 psi or less
-Tyler
1998 528i 5-speed Work in progress 1988 Toyota Pickup (4WD 5-speed) daily 2007 San Marino Blue 350z 6-speed sold 1996 328i 5-speed sold www.e46nonM.com - www.precision-sport.com - www.flyingwindowtinters.com - www.techniquetuning.com |
#37 | |
#38 | |
#39 | |
#40 |
J.C.. I need to stop posting so late.
A couple of corrections. Activ3- I meant you won't get as good of mileage with a supercharger, as it is always on. A turbocharger can be virtually turned off and factory mpg will be retained. That isn't to say a better option, just something to think about. As far as the 350Z.. I don't know why I mentioned that. They are a joke. Z06's are not out of range if the other guy can't drive. To you guys who have more than 400hp, have you done anything to the bottom end?
![]() '03 330Ci 5spd PP Alpine Type R, MRP 500 |
