#1 |
specific DTC codes
Hello folks.. any help would be appreciated..
I got the following codes off my car today. Any help would be greatly appreciated 209 ews manipulation check 227 01 bank 1 control deviation 228 02 bank 2 control deviation ONCE AGAIN THANK YOU!!! |
#2 |
227 Fuel trim (Bank 1),O2 control adaptation limit
228 Fuel trim (Bank 2),O2 control adaptation limit 209 EWS, content of message I Still have no idea what could they be |
#3 |
I have 228 and 227 as well. They mean the fuel adaptation has reached it's limit. The mechanic told me the fuel mixture was to lean and it could be caused by a leak in the air intake system (from the MAF towards engine), crank case vent valve ($600), or O2 sensors. One of the syptoms that is associated with these problems is a rough idle or stalling when stopping after continuos driving.
#4 |
Regional Sponsor
My Ride: 2000 E46 with 254K
To rich or to lean codes. You need to look at the additive and multiplicative readings to see if it is rich or lean. Then run some tests from there
Seth Thorson Service Manager/BMW Tech JB Eurotech Service "Your Reasonable Dealer Alternative" General Questions can be sent to appointment@jbeurotech.com 1. Do not argue with an idiot. He will drag you down to his level and beat you with experience. 2. Light travels faster than sound. This is why some people appear bright until you hear them speak. |
