Sponsored by The Tire Rack
Old 06-11-2009, 05:02 PM   #1
Inovazione
My Ride: BMW
Offset
Would someone please have pics of wheels with a 40mm offset on a 330ci?
Mickey
Inovazione is offline   Reply With Quote
Old 06-11-2009, 06:03 PM   #2
Bryan@Jlevi SW
1.888.JLEVISW
My Ride: E46 330i ZSP
Send a message via AIM to Bryan@Jlevi SW
I believe the OEM offset for E46 coupes is 38-42mm. So a picture of a stock E46 will get you what you need.
E46 with 17x9 ET41 LTW5's:
Bryan@Jlevi SW is offline   Reply With Quote
Old 06-11-2009, 06:32 PM   #3
Spdu4ia
My Ride: changes too much
et39 on the rear. 19/9.5
-Travis
Spdu4ia is offline   Reply With Quote
Old 06-11-2009, 06:55 PM   #4
BartenderPlease
My Ride: '03 540i/6 M-Sport
Mickey
?? we need the width of the wheel too
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Fiber Trim |
BartenderPlease is offline   Reply With Quote
Old 06-11-2009, 07:28 PM   #5
Inovazione
My Ride: BMW
Width
Sorry about that. The sizes are as follows:
FRONT: 225/4018
REAR: 255/35 18
Thanks again guys.
Micks
Old 06-11-2009, 07:31 PM   #6
Inovazione
My Ride: BMW
Your vehicle is soo sick. Love the art work on the hood. So in your opinion 40mm front and rear offset is fine? Do you have any rubbing if anyone sits in the backseats?
Thanks M
Old 06-11-2009, 07:33 PM   #7
Inovazione
My Ride: BMW
Offset
Just a quickie. So if the offset is PLUS the wheels stick in and if the offset is MINUS they stick out more...correct? Or do I have it revesed?
Thanks M
Old 06-11-2009, 07:56 PM   #8
Spdu4ia
i rubbed with the +39 offest, and since have taken off my 5mm spacer making them +44 with NO rubbing at all. I also havn't rolled my fenders though
-Travis
Old 06-11-2009, 08:02 PM   #9
Inovazione
My Ride: BMW
so 40 would rub in other words?
Old 06-11-2009, 08:12 PM   #10
Spdu4ia
if your lowered with stock fenders on Kumho 255's yes. there are so many variables . same offset with a 245 would be fine I think
-Travis
Old 06-11-2009, 08:19 PM   #11
Inovazione
My Ride: BMW
the car is not lowered, however the tires do tuck in when someone sits in the backseats.
Old 06-11-2009, 08:31 PM   #12
Spdu4ia
i would stretch a 245 on it to be sure
-Travis
Old 06-12-2009, 11:24 AM   #13
Bryan@Jlevi SW
1.888.JLEVISW
There is always the option of rolling your fenders too.
Thanks M
Offset is the measurement of the hub mounting surface to the center of the wheel. A 0mm offset has the hub sitting dead center. Positive offset pushes the hub farther to the outside (road side) and negative offset pushes the hub farther to the inside.
Old 06-13-2009, 03:24 PM   #14
Xcelratr
My Ride: 04 330Ci ZHP
See here.
We will not tolerate intolerance.
Xcelratr is offline   Reply With Quote
Old 06-13-2009, 06:13 PM   #15
Inovazione
My Ride: BMW
Originally Posted by Xcelratr View Post
That explains everything. I just purchased a set of OZ Superleggera's for 800 CAD. The rears are 18x9 with a 40mm offset. Do you guys think that I should put 255/35 or 245/35 tires in the rear?
Old 06-13-2009, 09:36 PM   #16
Xcelratr
The outer lip of your wheel will be 2.5 mm farther inboard than the outer lip of mine. That's a negligible difference. So assuming stock ride height, you can use the 255.
If you're going to lower it, there are people on this forum with a lot more experience than me regarding what sizes/offsets work on a lowered E46.
Post pics when you get them on, I've always liked that wheel.
