Thread Tools Search this Thread Rating: Thread Rating: 50 votes, 5.00 average. Display Modes
Old 03-04-2009, 06:19 PM   #41
royalratch
My Ride: 03 320d SE Touring
So why do BMW sell a Xenon enabled headlight switch at $300+ as the correct part to use with retrofit Xenons?
royalratch is offline   Reply With Quote
Old 03-04-2009, 06:29 PM   #42
sillieidiot
My Ride: '06 AW 330ci
they are just trying to swindle you. you don't need the part at all. just a reflash, however you will lose your high beams if you do, unless you do some extra wiring to make the bixenon function work. getting that LCM still does you no good as far as highs go
Old 03-07-2009, 11:48 AM   #43
royalratch
When you say Bi-Xenon, do you mean normal and high beam Xenon?
My Xenons are bi-xenon, in that they have the shutter - so what do have to do in the end to make it all work as if fitted from factory?
Old 03-07-2009, 12:30 PM   #44
sillieidiot
yes as in the shutter. there's a DIY somewhere, where you basically use a relay and the trigger wire connects directly to the LCM pin that activates the shutters
Old 03-08-2009, 04:29 AM   #45
royalratch
Man, this was supposed to be Plug and Play and now it's a mission!
I'll check it out- cheers for the tip.
I don't suppose there's BMW part use to make it simple.
Old 03-20-2009, 05:33 PM   #46
ferrarix99
ferrarix99's Avatar
My Ride: 87 325e - 05 M3 Vert
Post
If I may suggest in this picture pushing down is not the best way as you may damage the auto leveler, you need to spread those tabs apart to get the ball to come out of its socket. just put a Flathead in there rotate it and pull on the shroud from the front and it will pop apart
click for pics of the old ride...
-Nick the Greek-
euro.techniks
Bimmerworld Epic Tune | OEM Euro Headers | CSL Brakes | B&B TriFlo | aFe SuperStock | PSS10 | Varrstoen TE37 | V1 | ZKW Lens Swap | Orion Golds
Want your car coded? PM me.
ferrarix99 is offline   Reply With Quote
Old 03-20-2009, 06:20 PM   #47
sillieidiot
i didn't tell them to push down. pry it up. there are several different ways to do it. i've been meaning to add to this post several other ways lol for instance, after unscrewing everything what you can do is pull straight up on the reflector bowl. if you do it hard enough, it will pop right out with no problems. that's been the easiest way thus far. i never would have tried that if i didn't lose my screwdriver lol
Old 04-01-2009, 12:57 PM   #48
royalratch
Installed my Xenons and the fever has gone lol!
I went to my BMW Indy who have a computer and they said they cannot flash the LKM
to accommodate Xenon lamps as they say you must have a 'Xenon Ready' Headlamp / LKM?
Can they do it to a normal LKM / Headlmap Switch?
Old 05-13-2009, 05:27 PM   #49
rkneeshaw
My Ride: 330i ZHP
I wish I would have read this 30 minutes ago, because it appears I just damaged my auto-leveler. I'm pissed.
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 05-13-2009, 05:29 PM   #50
sillieidiot
lol yea i was supposed to show other ways to doing that, there's 3 total. but tim/mods say i can't change my post.
anyways, if you are in need of one. let me know, i got one i could sell you depending on what headlight you have
Old 06-24-2009, 05:54 PM   #51
maxxinne 03
My Ride: 2003 M3
Excellent DIY on headlight removal... I'm stuck on how to detach the headlight washer hose undernath the HID housing? Any advice? Thnx!
maxxinne///03
Orion V2 LED Halos//GrafxWerks Illuminate M3 Door Sills//Streamline Air Filter//DICE Silverline//Valentine1//OEM CSL Bootlid//Vorsteiner CSL Diffuser//Eisenmann RACE Exhaust 4x83mm//WORK VS-XX 19x8.5F & 19x10.5R//Toyo Proxies T1R- 245/35/19F & 285/30/19R//Bilstein PSS9 Coilovers//RE RSM's & Rear Spring Perch Reinforcement//TMS Subframe Kit//GC RTAB Shims
maxxinne 03 is offline   Reply With Quote
Old 06-24-2009, 06:26 PM   #52
sillieidiot
Uh i think you posted in the wrong diy, but the washer hose isn't connected to the headlight at all. It's completely separate
Old 06-27-2009, 08:21 PM   #53
maxxinne 03
My Ride: 2003 M3
Hey sillie, I crack the white nut that holds the vertical level aim arm, so where can I get a spare???
maxxinne///03
Old 06-27-2009, 08:30 PM   #54
sillieidiot
What white nut? Usually everyone breaks the white thing at the end of the autoleveling arm
Old 06-28-2009, 12:48 AM   #55
maxxinne 03
My Ride: 2003 M3
Where can I purchase that white thing @ the end of the autoleveling arm?
maxxinne///03
Old 06-29-2009, 12:37 AM   #56
sillieidiot
you can't. you can only get them from old headlights. seems a lot of people keep breaking them. i've only broke once off the thousands that i've opened. i should start keeping stock and selling them to you guys LOL
Old 07-01-2009, 07:19 AM   #57
maxxinne 03
My Ride: 2003 M3
Sillie, let me know when u have a spare handy... Thanx!
maxxinne///03
Old 07-01-2009, 04:41 PM   #58
sillieidiot
How bad is your's broken? If it's not bad i'd just glue it
Old 07-02-2009, 06:49 AM   #59
maxxinne 03
My Ride: 2003 M3
itz bad..
maxxinne///03
Old 07-02-2009, 04:11 PM   #60
sillieidiot
how bad can it be. most of the time when you break it, it's the other side going into the rectangular hole. the piece that holds it in that is broken. pm me a picture?
center trim, remove ballast, remove igniter, take apart headlight, xenon
