DIY - FUEL FILTER CHANGE (with photos) - Page 4 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Old 01-28-2009, 12:09 PM   #61
wuzilla
My Ride: 2001 325it
I bought replacement "fuel line" from the local Advanced Auto (Pep Boy, Trak Auto, insert your local generic parts store here) once as an emergency repair. The thing split on the first drive. Upon closer inspection, their "fuel line" may as well be interchangeable with their vacuum lines. Lesson learned!
As you said, buy OEM, or find a place with real high-pressure hoses!
wuzilla is offline   Reply With Quote
Old 02-06-2009, 01:05 AM   #62
uncsuperman
My Ride: 2004 325Ci
could a clogged/dirty fuel filter cause codes 171 and 174, lean on banks 1 and 2?
uncsuperman is offline   Reply With Quote
Old 02-08-2009, 12:38 AM   #63
LABMW13
My Ride: M3, 330i, '89 325i
SexyDev and I changed out his filter, there was a lot of gas in the lines and i mean a lot
M3: SSR GT3 Wheels, H&R Coilovers, JL 12" W6, Eisenmann 83mm, SS Headers, 4.10's, CF CSL Trunk & Diffuser, Euro Front Bumper, Hamann CF front lip, 3000k Fogs, NX 125 Shot
UUC Parts: SSBC Brakes, Lines, Sway bars, 8LB Flywheel, twin disc clutch, Evo 3 Shifter, RK7A Shift Knob, CF E-brake, Rasp-X Mid Pipes
Coming Soon: VRS Vented Race Hood & VCSL CF Roof Panel
LABMW13 is offline   Reply With Quote
Old 02-08-2009, 12:52 AM   #64
Arin330i
My Ride: 2002 330i
That ***** would not stop leaking... oh well we finished it and it works great but it took like 30 mins for all the fuel to drain haha :]
" Work like a Slave, Live like a King "
Arin330i is offline   Reply With Quote
Old 03-01-2009, 07:08 PM   #65
Killemall
My Ride: 325Ci
deleted
Killemall is offline   Reply With Quote
Old 03-02-2009, 05:06 PM   #66
hx288
My Ride: 2001 BMW 325I
I Replaced my fuel filter this weekend and would like to add the following:
1) removed the filter from the hose in the front first. This would minimize fuel spray.
2) For the gear hoses, it is so much easier to remove the two hoses (with the filter) from the fuel lines instead of removing the filter from the hoses.
hx288 is offline   Reply With Quote
Old 05-08-2009, 12:41 PM   #67
AndyMDass
My Ride: 2001 330i
The best way is to buy a grounding wrist strap for around $5 from radio shack/the source. This will always be useful, as many BMW sensors and electronic boards can be affected by electrostatic energy. Just wrap it around your wrist and clip it on to something metal and unpainted on the car. If you wear rubber gloves, depending on the thickness, you are isulating yourself from the car's electical system, so it is ok, as long as you are not making contact with the car's electical system elsewhere.
AndyMDass is offline   Reply With Quote
Old 05-30-2009, 02:34 AM   #68
Jelly335
My Ride: 2001 bmw 330I
Send a message via AIM to Jelly335
Right now my car isn't starting could it be the fuel filter? My mechanic said it can be the fuel pump. I tried starting the car and had the fuel line cap valve open and my father said no fuel came from that. I'm just making sure it's my fuel pump
E46 330i retired
E92 335 current
<3 my one wheel wonder
http://www.cardomain.com/ride/2269710/1
-Jeremy
Jelly335 is offline   Reply With Quote
Old 05-30-2009, 03:01 AM   #69
Sharky06
My Ride: 06 ZHP 6-SP
Send a message via AIM to Sharky06
subscribed....
Sharky06 is offline   Reply With Quote
Old 06-06-2009, 03:00 PM   #70
msuka
My Ride: 2013 335i M sport
bump I am going to try this today. one tip dont do this while changing the filterlol
msuka is offline   Reply With Quote
Old 06-06-2009, 04:31 PM   #71
packrat555
My Ride: 2001 325i
I suggest you replace the fuel line (8mm or 5/16 id) and you might need six new clamps. Mine had the original factory clamps that were like security screws where you could on get a grip with a flathead to unscrew the but not able to tighten.
Also be sure the blue fuel line goes to the connection in the center of the filter. I got mine switched around and the car would not start until I corrected the problem.
packrat555 is offline   Reply With Quote
Old 06-24-2009, 09:37 PM   #72
TannTheMan
My Ride: 2001 325i
I got the fuel filter, ready to do the change. After reading this post again, I feel that I should change out the fuel hose. My questions, can I get one from Kragen, so I don't have to wait for shipping, here is the description their Goodyear fuse hose.
http://shop.oreillyauto.com/ProductD...egoryCode=3604
Or I should get one from dealer? Thanks.
Tann
TannTheMan is offline   Reply With Quote
Old 06-28-2009, 02:48 PM   #73
Spitfire
My Ride: 2001 330CI
Thanks to all who contributed to this thread...
As mentioned above:
Use three golf tee's to plug the soft fuel lines. Use the end caps from the new filter to cover the ends of the old filter. This combination resulted in virtually no spilling. There was no need for a catch basin or anything to collect the fuel.
Also, use a 5mm socket for the hose clamps--no screw drivers or pliers needed
Good luck!
Daily: E46 UUC SwayBarbarians, UUC RKII, UUC TSE3, OEM Clears, ICE->Link, ACS rep pedals, M3 style lip spoiler, balls of steel, H&R sport cupkit, UUC EVO3/DSSR, hyperblack 18" CSL reps
Track: E30 325 with S52; H&R Race/Billie Sports, IE sways, SSK
Spitfire is offline   Reply With Quote
Old 06-28-2009, 07:46 PM   #74
91blksi
My Ride: nothing
where is the fuel pressure regulater located on a e46 m3?
91blksi is offline   Reply With Quote
Old 07-06-2009, 02:51 PM   #75
willb
My Ride: E46 323 Ci
Same question, I called a few dealers and they all say it's just regular fuel hose which cost $45 per meter.
I read a post talking about p/n 16117175998. But it desn't seem like the right hose based on realoem.com.
Tann
willb is offline   Reply With Quote
Old 07-06-2009, 06:26 PM   #76
91blksi
My Ride: nothing
anyone?
Old 09-06-2009, 02:36 PM   #77
Whammy
My Ride: ZHP
another suggestion, don't have a lot of fuel in the take when changing the filter. Mine has a bunch a fuel (3/4) and 1-2 gal is coming out on the lines.
Whammy is offline   Reply With Quote
Old 09-06-2009, 07:09 PM   #78
Whammy
My Ride: ZHP
One other important detail to point out: The BLUE rear fuel line needs to go into the center point of the fuel filter. Otherwise, the car will not start.
Ask me how I know
Old 09-07-2009, 01:19 PM   #79
firefirefire90
Banned
My Ride: suce ma bite
Send a message via AIM to firefirefire90
wanting to do this today!
did you guys buy the OEM filter, or is asftermarket fine?
firefirefire90 is offline   Reply With Quote
Old 09-08-2009, 09:55 AM   #80
gimmethemuumuu
My Ride: '17 F80 M3, SO/Bk
I got a Mahle filter from Pelican Parts in Dec-2006 (been a while) for $40.75 + shipping. (Nowadays, I'd probably use Tischer BMW.)
I'm sure non-OEM would be fine as long as you stuck with a good name--Bosch, for instance.
gimmethemuumuu is offline   Reply With Quote
