Australia
Old 08-10-2009, 07:15 PM   #1
lmaus
My Ride: A5 T
E46 DME Security Question
Hi All,
I'm hoping someone can provide me with further details, or tell me if a workshop can perform this function - I have purchased another DME, which once installed will need to be synchronized to my EWS Immobilizer to allow me to start my car.
Anyone know?
lmaus is offline   Reply With Quote
Old 08-10-2009, 07:16 PM   #2
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
Workshop with the right computer.. OR when you get the new DME flashed you can get EWS *cough* disabled *cough*
E46 Coupe is offline   Reply With Quote
Old 08-10-2009, 07:23 PM   #3
lmaus
My Ride: A5 T
Apparently an Autologic Computer can run the EWS Alignment through it's interface which should be relatively straight forward. Worx, does your box do this?
http://www.autologic.us/bmw.html
Old 08-10-2009, 07:24 PM   #4
lmaus
My Ride: A5 T
Why would I want to disable it Mr CarThief?
Old 08-10-2009, 07:25 PM   #5
lmaus
My Ride: A5 T
EWS
Security
Read and clear fault codes, diagnosis request, module information, ECU coding information, key status (enable or disable), display keys used in vehicle, align EWS to DME or DDE
E36, E38, E39, E46, E53, R50/R53 EWS 2, EWS 3, EWS 3D
Old 08-10-2009, 07:29 PM   #6
E46 Coupe
E46 Coupe's Avatar
Originally Posted by lmaus View Post
EWS
Security
What's that from exactly?
Old 08-10-2009, 07:41 PM   #7
lmaus
My Ride: A5 T
The Autologic Computer OBDII Compatibility List - it shows that the Autologic Computer can run the sync. Maybe I should head down to SouthernBM in Moorabbin and ask if I can use their "ESS" as Andrew claims to own.. Which technically doesn't exist? *laughs* .. Mate we need to catch up so I can whine to you about how ridiculous their service is.
Old 08-10-2009, 07:44 PM   #8
E46 Coupe
E46 Coupe's Avatar
Been there NEVER going there again! DW I know about it.
Old 08-11-2009, 12:22 AM   #9
325Mark
325Mark's Avatar
My Ride: is riding low!
Send a message via AIM to 325Mark Send a message via MSN to 325Mark
Alignment can only be done on uncoded or virgin ews, your used one has already been aligned and cannot be done again any BMW workshop can do this your problem is the ews won't identify the isn from the dme. You need to dump the memory from the original dme and program the used dme. Your best bet would be Bmw scanner or the likes.
'06 E90 325i 6MT | Full M3 Kit | H&R Euro Race | VMR V710 | Colour Kidneys
325Mark is offline   Reply With Quote
Old 08-11-2009, 12:35 AM   #10
Ballistic325
My Ride: slow and steady
^ how do you guys know all this stuff??
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 08-11-2009, 12:46 AM   #11
E46 Coupe
E46 Coupe's Avatar
True fanatic?
Old 08-11-2009, 01:34 AM   #12
lmaus
My Ride: A5 T
Don't you watch Hollywood movies? 325Mark is actually Nicholas Cage.
Old 08-11-2009, 02:01 AM   #13
325Mark
325Mark's Avatar
$5 an autograph
Old 08-11-2009, 02:13 AM   #14
lmaus
My Ride: A5 T
I think the most probable answer without knowing Mark, is that we all work in IT and have an aptitude for anything with a circuit board
Old 08-11-2009, 02:19 AM   #15
Sam_Micropak_AU
Past Site Sponsor
My Ride: E46 M3 Convert
i thought i smelled geek
Sam_Micropak_AU is offline   Reply With Quote
Old 08-11-2009, 03:20 AM   #16
Ballistic325
And that would make you MacGyver
I can help with
* RTABs
Old 08-11-2009, 04:32 AM   #17
325Mark
325Mark's Avatar
I have allot of BMW Diagnostic / Programming gear, Ive done plenty research into coding/programming modules as well as Aftermarket and Genuine BMW Equipment. Its kinda a hobby lol. DME Flashing is extremely hard on these cars and you would probably have more success to get an EWS Programmer and trying to change the ISN Password on the EWS rather than fiddling with the DME, Although you wont be able to swap the DME's then because your one wont work anymore. First off check what version EWS you have to see if you have rolling code ISN but I think you probably do.
Old 08-11-2009, 07:27 AM   #18
lmaus
My Ride: A5 T
This would ordinarily be true for obvious security reasons.
There is indeed a way to hack the DME and change one of the EPROM values to think the EWS is accessible thus accepting the EWS and associated ISN within your immobilizer. This value effectively allows for the DME to be "Open" to input. A closely guarded secret, but known to people who possess certain tools & applications.
I have purchased a Siemens DME which comes with the new tune and the above mentioned open value which will accept my existing EWS information.
Old 08-11-2009, 08:40 AM   #19
325Mark
325Mark's Avatar
So Why do you need to bypass the Used DME if you already have purchased a DME with the lockbit removed.
Old 08-11-2009, 06:57 PM   #20
lmaus
My Ride: A5 T
I don't need to bypass anything, just needed to avoid sending my DME to the US at the cost of 2 weeks vehicle downtime. I have purchased another which has already been flashed with my new mappings to accommodate my ESS TS, just needed to confirm that the EWS sync process would be allowed and not get 10 hours down the install path and not be able to start my car at the end.
Learning about this type of technology has sparked my interest now however, probably in a similar to way to yourself - I have placed an order for the OBDII Carsoft Kit to feed my curiosity
