Old 08-21-2009, 02:11 PM   #81
Iceman00
Banned User
My Ride: E90 6MT
Well, I'm back in welding class for fall semester. The good new is that our welding department got a major update, cleaning, and organization, apparently at a cost of around $500k. The bad news is that the contractors are behind schedule and haven't finished. The delay I've heard from talking to the welding teachers is around a month.
If you don't come through....
I will kill you.
Old 08-21-2009, 02:51 PM   #82
mkodama
mkodama's Avatar
I will kill you.
Old 08-23-2009, 03:02 AM   #83
SpookyChief
My Ride: '07 335i
looks like a sweet project. But the big question is...what grade did you get on your project?
Andy
SpookyChief is offline   Reply With Quote
Old 08-23-2009, 03:16 AM   #84
mkodama
mkodama's Avatar
I ended up turning in two finals. I wrote up a report for the work I had completed thus far on the exhaust as well as did a "normal" final project and report.
I totally aced the class being that I did every project + extras, and make very thorough write up(habit from physics lab write ups). In addition to doing all the work I occasionally fill in for the teacher and teach some of the "underclassmen".
Old 08-23-2009, 05:37 PM   #85
SpookyChief
My Ride: '07 335i
nice...I figured you did pretty well considering the attention to detail and I assume the parts list came from your report. good job
Andy
Old 08-24-2009, 06:03 PM   #86
Iceman00
Banned User
My Ride: E90 6MT
I demand a full evaluation, with videos on how the exhaust sounds and performs. Or else.
Old 09-23-2009, 12:40 AM   #87
mkodama
mkodama's Avatar
Work on the exhaust has resumed!
Old 09-23-2009, 12:59 PM   #88
ATF
My Ride: plows snow.
Less talk, more pictures and videos
Nick | BMWCCA 403399 | flickr
ATF is offline   Reply With Quote
Old 09-23-2009, 10:12 PM   #89
mkodama
mkodama's Avatar
Still trying to get fitment correct. It's a really slow process when welding shop and your car are 10-15 minutes away from each other.
Things like this need to be adjusted:
Old 09-23-2009, 10:20 PM   #90
JaaPee
My Ride: ///M
Very nice. Can't wait.
JaaPee is offline   Reply With Quote
Old 09-23-2009, 10:38 PM   #91
folgrz
stop looking at me swan
My Ride: 06 AW ZCP
awesome thread!
folgrz is offline   Reply With Quote
Old 09-23-2009, 11:36 PM   #92
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
how's the ground clearance with 3" piping?
SL Blak Soldier is offline   Reply With Quote
Old 09-24-2009, 12:03 AM   #93
mkodama
mkodama's Avatar
Good, strangely enough. It tucks up underneath just fine and I will have the same ground clearance for daily driving as with the stock exhaust.
The only part where the exhaust hangs a little lower than stock is near the rear axle and it is lower by about an inch. This is a location where the exhaust won't be an issue for ground clearance (since it is right under an axle), but it will make the exhaust slightly more susceptible to damage.
Old 09-25-2009, 01:12 AM   #94
mkodama
mkodama's Avatar
Hooray for having hundreds of thousands of dollars worth of equipment to use! Woo!
Me cutting out a section of a curve to make it less radical, to fix that gap in the picture above:
Also I've been working on getting the flanges to fit. It's quite tight since they are so close to the transmission and each other. I need to verify for a second time to make sure I get the fitting of the flanges correct, and then I'm probably going to weld them together. Also I'll likely have to buy some new BMW flange gaskets to fit since the Vibrant Performance ones are a bit too big.
Old 09-25-2009, 01:15 AM   #95
kuksul08
My Ride: M3
can't wait to see it finished.
Look at that subtle jet-black coloring. The tasteful thickness of it. Oh my God, it even has a 6mt.
S54 Valve Adjustment Spreadsheet & Info: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
S54 VANOS DIY Video: http://www.youtube.com/watch?v=9SkT2j3jsU0
kuksul08 is offline   Reply With Quote
Old 09-25-2009, 01:21 AM   #96
mkodama
mkodama's Avatar
Also one thing in the last week is that people have commented and critiqued my exhaust. Hehe, everybody has their opinion on exhausts. The people I consider more knowledgeable have just asked about design and affects on the car. The people I don't consider as knowledgeable or people I don't know have said that I will lose tons of torque and power and began to tell me why, show me what I should have done with their hands, or tell me the trick that their exhaust guy they know does. lol.
I really need to do a before after dyno with my old exhaust and new exhaust.
Old 09-25-2009, 07:15 AM   #97
jbfrancis3
Formerly Snox400
My Ride: 1999 323i
Do it, please! For your own knowledge. And if its an improvement, then you'll feel all the more satisfied. If not, oh well still a fun thing to do and what, you'd lose 5hp or less? Plus I'm sure it would benefit many others in the future.
jbfrancis3
jbfrancis3 is offline   Reply With Quote
Old 09-25-2009, 07:18 AM   #98
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Yep, do it.
Old 09-25-2009, 08:08 PM   #99
Iceman00
Banned User
My Ride: E90 6MT
Originally Posted by aggiee46 View Post
yep, do it.
+3
Old 09-26-2009, 07:53 PM   #100
b/\/\w STREETS
My Ride: 00 BMW 323I
that would be sick n plus 1 for the haters
b/\/\w STREETS is offline   Reply With Quote
