Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 4.20 average. Display Modes
Old 09-05-2009, 11:02 PM   #1
RACEMX-M3
My Ride: M3
Official Forced Induction Maintenance/Service Thread
I don't see this *important* info posted often so thought I would start a thread to see what everyone is doing to keep thier F/I cars running at top performance. Hopefully everyone is aware that F/I puts a lot more stress on your car's parts that are designed to wear and be replaced. Please post what's on your list of items to check and how often. Here's mine..
Engine Oil/Filter: I believe BMW recommends servicing the oil/filter every 15k miles, even for a n/a car with no mods that seems a little long to me. I may be on the extreme side of caution but my cars gets new oil/filter approx every 2 -3k miles.
Air Filter: Easily overlooked, if you're sucking in a lot more air your filter is going to collect dust and debris a lot faster. Last time I cleaned mine I was a bit overdue. I now clean and oil my filter with each engine oil change.
Transmission Fluid: BMW claims the tranny fluid is good for the life of the car, although they even recommend service @ 100k miles. My car has 50k miles on the clock (most of that was n/a) - I'm planning to change the tranny fluid soon.
Differential: Don't recall what BMW advises - I just changed mine recently. (Wear some kind of gas mask, the diff fluid smells like Sh!t.)
Flex Disk: If you're unfamiliar this is the ultra strong circle of reinforced rubber that connects your transmission to your drive shaft, I replaced mine about 5k miles ago as it was cracked and splitting everywhere. Replace as needed.
Spark Plugs/Coils: I generally replace these as needed. I keep saying I'm going to pony up for the Okada Coils, so far the $1k+ price has deterred me. If you own a HPF car they have recently upgraded to a new high performance plug that is quite expensive, but runs cooler, is pre-gapped, operates more efficiently, lasts longer and puts less stress on your coils.
Tires: uhh..
Brake Pads:
Methanol Injection: If your car has this remember to add two teaspoons of "Alcohol Fuel Lubricant" per 1.25 gallons of methanol. See this thread for more info: http://forum.e46fanatics.com/showthr...fuel+lubricant
Coolant: I live in Texas and it gets HOT during the summer months. In the summer I add a mix of distilled water and 2 bottles of Watter Wetter. In the winter months I go back to the oem BMW coolant.
All I can think of for now. Look forward to hearing other's rec's.
RACEMX-M3 is offline   Reply With Quote
Old 09-06-2009, 12:29 AM   #2
PatmanSC
My Ride: 06 AW/IR M3
hope this gets stickied
06 Alpine White/Imola Red M3 coupe, {Stage 2.5 P6766 open wastegate}
| M2-Motoring | HRE Wheels | Horsepower Freaks | Tecnocraft | Oink Fabrications | Toyo Tires | Mother's |
00 Phoenix Yellow/Red Recaro Integra Type R #00-0035 {JDM Conversion, Built B18C5, Ferea internals, Toda build soon}
PatmanSC is offline   Reply With Quote
Old 09-06-2009, 12:54 AM   #3
sniperm
My Ride: maxima
where do get the flex disk?
how hot is it in dallas? i might be moving up to dallas next month..
04' LSB
sniperm is offline   Reply With Quote
Old 09-06-2009, 01:31 AM   #4
ispeedm3
My Ride: e46 m3 TuRbO
Sniper, I have a new flex disc in box if you need one.
[CENTER]
ispeedm3 is offline   Reply With Quote
Old 09-06-2009, 02:06 AM   #5
DiVinci
My Ride: ....
i guess if ur boosted, u would be putting some extra strain on suspension components too
maybe a good idea to check in with CAB's, RTAB's...etc
^ good thread by the way
DiVinci is offline   Reply With Quote
Old 09-06-2009, 02:12 AM   #6
paraklas
My Ride: ESS TS2 320ci
Engine main belt every 20k miles (At 30k mine was disintegrated with the TS2)
Fuel pump @ 80k miles
Fuel filter every 20k miles
MAF Cleaning 2-3 days after air filter cleaning / re-oiling (I have the K&N drop-in oiled filter)
Brake fluid / Coolant / PS Fluid every 2 years
Old 09-06-2009, 10:35 AM   #7
sniperm
My Ride: maxima
wat does it cost? pm plz..
04' LSB
Old 09-06-2009, 10:58 AM   #8
InDiGlOM3
My Ride: HPF M3 stg 2.5
Scott, good thing you seen that cuz that would be some **** to have break while goin fast down the highway, Mine was also in very bad shape but its been replaced.
SniperM. You can get them from bmw for like 130 bucks or so If i remember right. Part #26112226527
Old 09-06-2009, 01:51 PM   #9
lkstaack
My Ride: 04 330iZHP, 05 325iT
Doesn't AJ recommend a new fuel pump every 60,000 miles?
Lars
2004 330i ZHP ESS TS2
lkstaack is offline   Reply With Quote
Old 09-06-2009, 02:48 PM   #10
sniperm
My Ride: maxima
thanx for the info!!
04' LSB
Old 09-06-2009, 03:32 PM   #11
HPFMTRE
My Ride: ESS VT3 E92 M3
Great post scott!
I havent done my air filter yet i should probly do that very soon.
My flex disk was cracked also pretty bad.
Photobucket
Photobucket
Pictures of my car
http://www.cardomain.com/ride/2927228
Originally Posted by BeRzErKaS View Post
wat?? guys with turbo M3's don't have woman troubles...
try adjusting your wastegate
HPF Stage 3 #001
New ride- ESS VT3 E92 M3
HPFMTRE is offline   Reply With Quote
Old 09-06-2009, 04:41 PM   #12
InDiGlOM3
If you call that bad, Then I dont even know where to begin describing how bad mine was haha
Old 09-06-2009, 07:43 PM   #13
jetskier88
My Ride: 330i ZHP S/C TS2+
Send a message via AIM to jetskier88
cool thread.. ive done all of this.. except for the additive to meth kit, but i am only running a 50/50 mix
ESS TS2+ - OEM M3 LSD rear end swap - Meth Injection - Recaros PP - Defi Guages - Dinan TB - Headers&M3 Custom Quad Exhaust - UUC LTW Flywhl - UUC SegKev Clutch - Rogue SSK - KW V2 Coils - H&R Sways - TMS Subfrme&Sway Reinfrcmnt - VMR V710 & M PS2's - Brembo X Rotors and more....
jetskier88 is offline   Reply With Quote
Old 09-06-2009, 07:58 PM   #14
mtran850
My Ride: C6 Z06
is there any symptom when the flex disc is bad or do you just have to pull it out to see if it is bad or not
mtran850 is offline   Reply With Quote
Old 09-06-2009, 08:46 PM   #15
ispeedm3
oh trust me you will know. you will feel a very bad vibration coming from the driveline.
[CENTER]
Old 09-06-2009, 08:57 PM   #16
mtran850
My Ride: C6 Z06
gotcha, thanks
Old 09-06-2009, 09:17 PM   #17
RACEMX-M3
My Ride: M3
My flex disk looked pretty bad when I replaced it, but never noticed any vibration, etc. One of the techs at my BMW dealer pointed it out to me so I replaced it. I just make a point to check on it when my car is up in the air.
Old 09-06-2009, 09:46 PM   #18
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I do the tranny/diff fluids once a year and will definitely add the flex disk to my list.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 09-06-2009, 10:47 PM   #19
MSpired
My Ride: HPF Stage 2.5 e46 M3
Send a message via AIM to MSpired Send a message via MSN to MSpired Send a message via Yahoo to MSpired
Great thread!
I suggest changing the OEM fuel filter every 15-30k. This really depends on your power levels and how hard you push the car, as the more power you make and the harder you drive, the more fuel is flowing through that filter for each mile driven.
x2, Wait till I post pics of mine!
I never noticed any symptoms, and mine was very very torn apart.
MSpired is offline   Reply With Quote
Old 09-07-2009, 12:34 AM   #20
HPFMTRE
haha wow what do you guys do to your car....
Photobucket
Pictures of my car
HPF Stage 3 #001
