Old 09-09-2009, 12:05 PM   #21
TxZHP04
My Ride: ESS TS2+ ZHP
Originally Posted by aggieE46 View Post
Where does one go to get a clutch/flywheel balanced? I might have to take mine off, wouldn't mind having this done.
Afraid I can't offer any recommendations since I haven't dealt with this myself. You might check with Chad, the guys at Vorshlag, or Jerry @ Eurosport (assuming he's still there) for recommendations.
Old 09-09-2009, 12:14 PM   #22
TxZHP04
Originally Posted by Activ3 View Post
...GL man. So I guess you're just going to try the CM tob?
That would be my preferred path at this point unless the shop can offer evidence as to why this would be a problem (I'm not convinced the CM tob was ever a problem). By the time I get any feedback from the shop, I'm afraid I may find that I'm already back to a stock clutch.
Old 09-09-2009, 12:21 PM   #23
rhm325i
My Ride: 02 BMW 325i
sounds like a synchro. especially since you said it only happens at high rpm
rhm325i is offline   Reply With Quote
Old 09-09-2009, 01:00 PM   #24
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Cool, I'll ask Chad.
I think my RMS is leaking... the one I just installed. I'm afraid I'll be taking it apart
Old 09-09-2009, 01:01 PM   #25
aggieE46
Keep it clean
aggieE46's Avatar
If they stick the stock one back in, bring it over. We'll get under her and get it done.
Old 09-09-2009, 01:15 PM   #26
TxZHP04
Worn synchros should only cause a problem with engagement, not disengagement. My primary symptom is being stuck in gear.
Old 09-09-2009, 01:21 PM   #27
TxZHP04
That's a bummer. Sure it's not just the back end of the valve cover?
Might just have to do that.
Old 09-09-2009, 04:53 PM   #28
aggieE46
Keep it clean
aggieE46's Avatar
Nope, it's coming from the rear of the oil pan. I'll know for sure when I do the pan gasket next week.
Chad said his machinist could do it. I may order a new clutch disc, just for kicks. Might as well. It was a bit thin when I put it in.
Old 09-09-2009, 09:17 PM   #29
TxZHP04
Well, my shop is waiting on some feedback from CM to figure out how to proceed. Maybe there is still hope.
Old 09-10-2009, 10:24 PM   #30
TxZHP04
Much to my satisfaction, my shop has shown they are committed to getting to the bottom of this. As a result my clutch, flywheel, and transmission will be vacationing at CM for a few days next week so that their experts can get this sorted out.
Old 09-26-2009, 06:34 PM   #31
TxZHP04
Since a few people have already started to ask, here's an update on my clutch issues.
I got the car back last Wednesday after the transmission, clutch, and flywheel had been shipped to ClutchMasters to get everything sorted out. According to CM, the fulcrum point wasn't quite right with the original pressure plate so they provided new parts to correct that and shipped everything back. Due to an accident during the reinstall, I also ended up getting a new slave cylinder. Pedal effort is feather light now (too light for my taste really) and I haven't had any issues with grinding or kickback through the shifter. Unfortunately it's still binding up at the top of second gear and I also now have a little squeak when depressing the clutch (likely either the pedal bushing or a problem with the latest TO bearing).
Not sure what I want to do next. It might just be time to go back to stock and see if that solves all the problems. I could always try a different aftermarket clutch later if removing the FX100 solves the problem.
With all the aftermarket parts I've dealt with, I never expected something as commonly replaced as the clutch to be the only thing to ever give me troubles.
Old 09-28-2009, 12:02 PM   #32
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
Is the clutch engaging early? (pedal position I mean)
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 09-28-2009, 12:21 PM   #33
TxZHP04
At this point, the engagement feels pretty normal.
Before everything was shipped off to CM, the engagement point was completely down at the floor. When disengaging the clutch, pedal resistance was constant and stiff all the way to the floor. With most clutches I've driven, pedal effort typically eases up just a bit once you reach a certain point but it never seemed to reach that point. The behavior seemed in line with the clutch not fully disengaging due to lack of travel resulting from an incorrect fulcrum point.
Now, even though the pedal effort is really light forcing me to really pay attention to feel what's going on, it seems to reach that break point where the pedal effort eases up a bit just prior to reaching full travel. It still just seems really odd to me that this problem only occurs at the very top of 2nd gear and never with shifts below 5-6k rpm.
Old 10-14-2009, 11:10 AM   #34
TxZHP04
Final Update
All problems have been resolved. No binding, no vibration, nothing but smooth shifting! Unfortunately, I had to give up on the CM clutch and return to stock.
Still don't have a complete understanding of why the CM unit wouldn't fully disengage but at this point I am beyond caring. Since I first took the car in for the clutch & flywheel replacement, I've had 3 different CM clutches in the car - all of which had problems. All 3 had engagement/disengagement issues. The first was substantially out of balance and the 3rd also had some minor vibration < 2k rpm.
I've heard nothing but good things about the CM clutches in the past, so I have to admit to being a little surprised with all these problems. CM never left me hanging, they were always willing to seek a resolution to these problems but unfortunately after 3 attempts we weren't any closer to making it work - even after shipping them my transmission, clutch, and flywheel for analysis. Hopefully they will get this ironed out in the future but in the mean time, I'm afraid I can't recommend a CM clutch for the non-M 6-spd.
Old 10-14-2009, 11:44 AM   #35
aggieE46
Keep it clean
aggieE46's Avatar
Bummer. Well, hopefully it'll hold up to more abuse.
Old 02-08-2010, 04:26 AM   #36
paraklas
My Ride: ESS TS2 320ci
Thread revival...
I'm looking to get a clutch kit now, and after reading about your clutch issues I'm a bit reluctant to go with CM, given the fact that I'm overseas and I can't afford any clutch related defect/issue.
Are you satisfied with the stock unit now? I'm a bit lost of what to get.
