Old 07-27-2009, 07:54 PM   #1
GodsSon
My Ride: 325i
Corner / Parking Light Delete PROPER DIY............GodsSon
This DIY is for people who want to get rid of the yellow corner / parking lights on the front of their E46 BMW, without risking blowing their LCM, AND without buying LED corners, AND without buying a euro switch. Also gives the option of turning them back on with the flip of a switch... just in case cops give you problems!!
BlackBerry Owner? David is a Wireless Usage Monitor that can track your wireless bill in real time from your blackberry! Available on Blackberry AppWorld... more info
____________________________________________________________ ____________________________________________________
HOW IT WORKS:
The BMW E46 corner / parking lights run on a dual voltage system. 6 volts for the corner / parking lights and 12 volts for the turn signal. This DIY creates a circuit which allows three options for the lighting. Under the 6 volt load it will connect a resistor to the circuit in place of the light to prevent the light from coming on and yet prevent a bulb out warning. Under the 12 volt load it will connect the light allowing the turn signal to function properly. And finally with the switch OFF it will connect the light to function normally as BMW intended in our various countries. This method connects the corner / parking light to its intended power source whereas other mods connect to the side light power source which may create problems with the LCM and later repair bills.
PARTS:
  • 1x - DPDT switch
  • 5x - 2 meter, 14/19 gauge wire / 1x 3m wire
  • 1x - Project Box
  • 2x - 6 Ohm, 50 Watt Resistor
  • 2x - SPDT, 40 Amp, 12 Volt Auto Relay
  • 2x - 1 KOhm Resistor
  • 2x - 3 Amp DIODE
THE BASIC CIRCUIT:
This is the circuit for ONE side of the car only!! so you would just double it for the other side. Since I placed both sides in one box this meant that they could share the ground wire and a switch. the switch in the circuit for the one side is a SPDT whereas if you are doing both in one box you would use a DPDT.
Essentially the TRIGGER will be connected to the side light. The INPUT will be connected to the positive cable running to the corner / parking light. The OUTPUT will be connected to the cable still connected to the corner / parking light. And the GROUND will be connected to the cars ground. A diagram of the connections is provided below.
My finished product is shown below. I fit both circuits in one box hooked up to one switch to control the normal and light delete modes.
I placed the corner delete box in the empty space of the engine bay and attached it with two sided permanent tape. The pics below show the positioning and completed with all cables attached.
NOTE: I found that the resistors and therefore the box got extremely hot while in operation and risked damaging the relays so I relocated the resistors outside the box. This means that the black box could be even smaller than it is now!.. see below pic!
The result is a Corner / Parking Light delete Mod without downsizing to LED's, blowing LCM's or worrying about your province/state's traffic laws!
BEFORE
AFTER
ERTW.......
In God we Trust...all others Pay Cash.
2005 BMW 325i
GodsSon is offline   Reply With Quote
Old 07-27-2009, 09:02 PM   #2
fmzip
My Ride: 2001 330cic & 530i
Nice!
Awful lot of work for a light....gotta love the forums for creativity!
Fran
2001 330cic ESS TS2 Supercharger
Follow me on Flickr
My Car is for sale
fmzip is offline   Reply With Quote
Old 07-30-2009, 08:07 PM   #3
Salazar
My Ride: 323ci
Send a message via AIM to Salazar
wow!
can you make me one of those boxes and sell it to me? LOL
Salazar is offline   Reply With Quote
Old 09-01-2009, 09:17 AM   #4
adjei
My Ride: red e46
can you please make me a box, i live in oakville so it shouldn't be hard to pick up
im about 10mins from sq1
adjei is offline   Reply With Quote
Old 09-03-2009, 03:15 PM   #5
GodsSon
My Ride: 325i
For purchase requests please PM me!
2005 BMW 325i
Old 09-06-2009, 03:01 PM   #6
mujjuman
My Ride: not an E46
when the parking lights are on (without headlights) will the corner lights still light up?
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 09-14-2009, 12:44 AM   #7
GodsSon
My Ride: 325i
When the ModBox switch is set to "ON"; the only time the corner lights are on are when the turn signals are signalling. When the ModBox switch is set to "OFF" the corner lights function as usual (as parking lights/Night Corner Lights/turn signals). So the answer to your question depends on which state the switch is in!
2005 BMW 325i
Old 09-14-2009, 02:30 PM   #8
mujjuman
My Ride: not an E46
haha tahnks!
mujjuman
2003 325xi 5MT
sig by Solidjake
Old 09-22-2009, 02:59 AM   #9
JSanders
My Ride: crawls.
Interesting, Good work!
JSanders is offline   Reply With Quote
Old 10-21-2009, 09:06 PM   #10
zugellos
My Ride: '02 330i
GodsSon's schematic appears to be sound....so has anyone attempted this yet?
If so, what are your results?
zugellos is offline   Reply With Quote
Old 10-21-2009, 09:08 PM   #11
uninc4709
My Ride: 2002 BMW 325i 5spd
how much are you thinking of charging for the boxes??
uninc4709 is offline   Reply With Quote
Old 10-22-2009, 12:43 PM   #12
GodsSon
My Ride: 325i
PARTS:
1x - DPDT switch - $10.00
5x - 2 meter, 14/19 gauge wire / 1x 3m wire - $10.00
1x - Project Box - $10.00
2x - 6 Ohm, 50 Watt Resistor - $30.00
2x - SPDT, 40 Amp, 12 Volt Auto Relay - $20.00
2x - 1 KOhm Resistor - $ 2.50
2x - 3 Amp DIODE - $ 2.50
LABOUR: - $60.00
TOTAL: - $145.00
*Doesn't include shipping
*Custom made electronics aren't cheap and even though its fun I don't work for free, Sorry!
2005 BMW 325i
Old 10-22-2009, 11:33 PM   #13
jreid
My Ride: a car
great find. i allways wondered about doing this.
jreid is offline   Reply With Quote
Old 12-18-2009, 06:55 PM   #14
lbcluis325i
My Ride: 325i
the joker even says that: If you're good at something, never do it for free. hahah
lbcluis325i is offline   Reply With Quote
Old 12-18-2009, 06:59 PM   #15
Define ///M3
My Ride: Dream 2 B Suprchrgd
on coupes the corners look sick
AKA Huggy1989
"I expect to pass through life but once. If, therefore, there can be any kindness I can show, or any good thing I can do to any fellow being, let me do it now, and not defer or neglect it, as I shall not pass this way again."- WP
Define ///M3 is offline   Reply With Quote
Old 12-18-2009, 07:13 PM   #16
UNFORGIVEN
My Ride: Bagged Stang, 330CI
Man, I've been thinking about doing this ever since my corners started blowing. I had new harnesses spliced in on each end and my DS blew again.
I don't know what's going on. So fking frustrating.
...is rocking a new look!
Special thanks to Mr. AWD for the new sig...
UNFORGIVEN is offline   Reply With Quote
Old 06-01-2010, 03:48 PM   #17
snowcatxx87
My Ride: 04 330CI
I would hardly call this proper. The proper way is what I did: software to program my cars LSZ (light switching center) to european spec, and turned off the corner bulbs.
LOL.
snowcatxx87 is offline   Reply With Quote
Old 06-02-2010, 12:27 AM   #18
mujjuman
My Ride: not an E46
damn man that sucks!!!! maybe its the bulbs? dont touch the glass with ur fingers. that tends to make them go out sooner
LOL.
how do u do that?
mujjuman
2003 325xi 5MT
sig by Solidjake
Old 06-02-2010, 09:07 AM   #19
diablo666l
My Ride: 2005 BMW 330ci ZHP
Send a message via AIM to diablo666l
Is it possible to rig it up so that the 'always on' headlights only come on with the parking lights?
LOL.
How/Where did you get the software changed? I have an aftermarket headunit, and the dealership says the program won't take...I want to shut my 'always on' headlights off so badly!
2005 330ci ZHP (I know it's not an M3!)
Audio: Pioneer AVIC Z3, 1200 Watt Mu Dimension Amp, Audio Pipe Crossovers
Lighting: CCFL Angel Eyes, Custom 'devil eyes', custom LED ambiance lighting, LED license plate lights, invisibulb turning signals
Performance: Front AC Schnitzer Strut Bar, Rear Ebay Strut Bar
Appearance: 20% Tint, Clear Bumper Reflectors, AC Schnitzer Aluminum pedals
Other: Viper 2-way Alarm/Remote Start
diablo666l is offline   Reply With Quote
Old 06-02-2010, 11:08 AM   #20
SammyV
My Ride: CB M3
Send a message via AIM to SammyV
I do the software mod for locals in NY/NJ. I can take care of the corner light "mod" as well as many other tweaks...
SammyV is offline   Reply With Quote
corner light, delete, lcm, parking light, turn signal
