Thread Tools Search this Thread Rating: Thread Rating: 107 votes, 4.92 average. Display Modes
Old 09-21-2009, 03:06 PM   #161
BimmerDude18
My Ride: 1998 528i
Most chargers are current controlled, there are some that are voltage regulated, basically you need a voltage regulated power supply...
-Tyler
1998 528i 5-speed Work in progress
1988 Toyota Pickup (4WD 5-speed) daily
2007 San Marino Blue 350z 6-speed sold
1996 328i 5-speed sold
www.e46nonM.com - www.precision-sport.com - www.flyingwindowtinters.com - www.techniquetuning.com
BimmerDude18 is offline   Reply With Quote
Old 09-21-2009, 11:12 PM   #162
raymond3080
My Ride: 323CI
hmm so your saying that one of these cannot sustain a consistent voltage to allow a flash to occur? http://www.princessauto.com/shop-gar...eyword=charger
If thats the case what on earth am I going to use to do that?( or take apart?)
raymond3080 is offline   Reply With Quote
Old 09-22-2009, 07:15 AM   #163
ritos530i
My Ride: 2004 E60 530i 6speed
Send a message via MSN to ritos530i Send a message via Yahoo to ritos530i
Nope this will not work. It is only rated for 12v and since it automatically adjust there is no way to control voltage.
The one i seen used is custom built from some old parts or something. I am sure you can find someone to build one for you.
530i E60 Custom Turbo/Nitrous (PSI_unknown)
ritos530i is offline   Reply With Quote
Old 09-22-2009, 11:28 PM   #164
HakenTT
My Ride: 323i with S54
I use power adaptor from my old printer, it has 14v output so I junked the old printer and saved the power adaptor.
HakenTT is offline   Reply With Quote
Old 10-03-2009, 08:10 PM   #165
raymond3080
My Ride: 323CI
hmm alright so ill have to figure that aspect out...anyways hows the software side coming along? Will we be able to flash this thing before winter?
Old 10-04-2009, 04:03 PM   #166
BimmerDude18
My Ride: 1998 528i
The power supply is the easy part. I have 3 different RC car battery chargers, and I think all are current controlled. Power supplies will likely be the best option, although they have low current maxes usually, so I'd measure the draw of the ECU while flashing before I'd try one of those.
Alternators have voltage regulators on them that bleed off excess voltage from the alternator, I wonder how useful that could be coupled with say an 18V power supply.
When I have free time I'll dig through this, electronic's of this sort are fun.
-Tyler
Old 10-04-2009, 04:11 PM   #167
ritos530i
You can not use a battery charger to connect to the bench when flashing.
What I am describing looks like something out of Back to the Future. LOL
You basically have to build them yourself or have one built for you. There may be a company that builds them.
Old 10-04-2009, 10:42 PM   #168
HakenTT
I use a "printer" voltage supply, I trew away my old printer and the power supply adaptor to it is 14v with 625mA ampage, anywhere there 14 to 16v with 300mA to 1000mA will work.
Looks like for you guys it is not even easy to find power supply to flash it. They how could I even begin with this when you can't even go past the easy part.
Old 10-04-2009, 10:55 PM   #169
ritos530i
If you want power supplies i can have them built just let me know.
My source is top secret but guarantee it's what you will need. LOL
Old 10-04-2009, 10:59 PM   #170
AWE46M302
My Ride: E46 M3
if you flash it correctly, the flash can be less then 90 seconds. You do not need to re-write the whole thing.
AWE46M302 is offline   Reply With Quote
Old 10-04-2009, 11:13 PM   #171
ritos530i
that's not the issue we are discussing. Every time the DME has to be flashed it what to be removed put on a Bench to ground the DME then apply a 14volt current to it before you can flash the DME. You can buy all everything you need ready to work from a kit however it doesn't come with the power supply which has to be built which ever method you choice as long as it supplies the 14volts.
Yeap all this for 90 seconds or so.
This is what makes the MS45 dme difficult to tune in my opinion because who the hell wants to go through this every time there is a remap needed. It's also the very same reason i added a AEM FIC to my setup.
Old 10-05-2009, 12:38 AM   #172
hexadecim8
My Ride: '04 ///M3
annyways....... how about an update on the f'ing software???
hexadecim8 is offline   Reply With Quote
Old 10-05-2009, 01:00 AM   #173
raymond3080
My Ride: 323CI
Yes I need to run that 330 software... Hakken getting anywhere??
Old 10-05-2009, 01:35 AM   #174
BimmerDude18
My Ride: 1998 528i
I've got a 14V voltage controlled power supply sitting in front of me from something. I just don't trust power supplies that are rated for 1 amp to run a DME. Maybe it doesn't need much, but I'd want a 5 AMP capable power supply if I was spending money on something, and considering I have a lot of random electrical crap laying around (including a computer power supply I might try modding) I think I can have something together in terms of "instructions for creating one" very soon/easily.
-Tyler
Old 10-05-2009, 02:00 AM   #175
raymond3080
My Ride: 323CI
Sounds good BimmerDude....
Wow I just realized there are almost 14,000 views of this thread...but only 175 posts?
Old 10-05-2009, 04:33 AM   #176
sjo328ci
My Ride: 2000 328Ci
That shows how many people are interested in this topic, and how few know anything about it.
2000 BMW 328Ci
CP 11.5:1 pistons
Schrick 264/248 cams
M54 crankshaft
Crower MaxiLight forged alloy connecting rods
Ferrea 1mm oversize intake and exhaust valves,
valve springs, and titanium spring retainers
Technik Stage 3 cylinder head (mild port and polish)
Technik tubular exhaust header
227 rwhp (265 crank hp est)
What's the point of having money if you don't have something worth wasting it on?
sjo328ci is offline   Reply With Quote
Old 10-06-2009, 11:37 PM   #177
HakenTT
Dude you haven't even posted your stock dump!
Old 10-06-2009, 11:43 PM   #178
raymond3080
My Ride: 323CI
date Wed, Sep 2, 2009 at 10:19 AM
subject DME maps
mailed-by gmail.com
Thats when i sent it... in a email to your self...
Old 10-20-2009, 11:25 PM   #179
raymond3080
My Ride: 323CI
Hellooo anyone out there?
Old 10-24-2009, 12:56 AM   #180
HakenTT
subject DME maps
mailed-by gmail.com
I got one from you the MS52? Software 0110C6? Is that yours?
custom tuning, dme tuning, flashing, kwp2000
