Thread Tools Search this Thread Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 10-17-2009, 02:11 AM   #1
F1004fun
My Ride: '02 330Ci
No "check engine light" with headers!!!
I found the fix for running the aftermarket ebay headers! And keeping you CEL light out, hell the monitors even pass! Now this is on a '02 330Ci with MS43, I am not sure if this will work on '03 and later as they run MS45, but if your brave and want to try I'll help you out.
Now not that I am all for taking catalytic converters off your car, it's very horrible and you should all feel bad and put them back on.
But with that being said, the Innovate LC-1 is a very cool tool that I honestly must give credit to that pie330 guy for telling me about. It is a wideband O2 sensor with a little control unit that gives you 2 programmable outputs and a serial cable hookup for laptop hookup and tuning.
Now this may sound complicated but it really wasn't that hard to hookup, but I would recommend some automotive and electrical experience and a good soldering iron.
So with the headers installed hook up your 2 pre-cat sensors, this should leave you with 2 bungs left, well plug one and install the Bosch wideband O2 sensor in the other. Now I know your only reading one bank but this is the best I can do for now.
The Innovate controller fits under the engine cover nicely. ( I'll get some pics here in a day or two) I used my old connectors from the old post-cat O2 sensors, installed a 50ohm 10watt resistor in each of two sets of white wires, these are the O2 heater ciruit wires.
For the signal and ground wires it gets tricky. So we should have two wires left over at each of your O2 sensor connections, now sensor side wiring changes so reference the engine harness side for this. Bring the two wires together that connect to the yellow wire, and wire in about 3' of small yellow wire this is the Analog1 output from the controller. Next bring together the two wires that connect to the black wire, again 3' of small black wire, this is the signal ground. Bring this signal ground the yellow wire and all the associated LC-1 wires in a nice loom into the e-box, you'll even find a grommet you can use.
Once in the e-box lift the DME and the bracket that it's held into up and expose the chunk of red-white and brown wires underneath. Connect the sensor ground wire and the white and blue LC-1 ground wires to the splice of brown grounds under the DME, next connect the LC-1's red wire into the splice of red-white yellow dotted wires. Connect the yellow wires together.
Well if your still with me the hard part is done, fire up the laptop and load the software. While your doing this there is a bit of a calibration hoop you need to jump through, the directions are in the box with the LC-1.
Once you load the software go to Analog1, select "use air-to-fuel ratio" and program in .650volts at 18:1 and .100volts at 22:1, then go to advanced and select 1/3 second delay. Program all this in and clear you old catalytic converter efficiency faults and then go out and enjoy.
I have played around with this voltage curve a little and this curve finally got the monitor to pass, as I datalog more cars I'll update any changes I find. Hope this helps, I have found many cool ideas on this forum and wanted to give something back.
F1004fun is offline   Reply With Quote
Old 10-17-2009, 09:21 AM   #2
nite-stalker
My Ride: 325Ci
thats a very expensive o2 simulator, if you are not doing any tuning
nite-stalker is offline   Reply With Quote
Old 10-17-2009, 09:29 AM   #3
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
$40 at o2simulator.com works just fine, too
Old 10-17-2009, 11:13 PM   #4
F1004fun
My Ride: '02 330Ci
Have you had these actuakky work for you? Because they didn't work for me, eventually my car set a light.
You see the O2 sensor foolers don't work, you get " catalytic efficiency faults".
The O2 sensor simulators don't produce the low voltage "lean" signal when you decelerate, so you will get " oxygen sensor low voltage not detected" fault.
I have tried it all, the LC-1 allows for the good .650 voltage of a good cat at cruising speeds and gives the low voltage on decel, with the addiction of the 1/3 second delay that is what the DME uses to measure the oxygen saturation of the catalytic converter. I am not sure if this is what they designed this little gem for, but it works damn good.
Old 10-18-2009, 03:51 AM   #5
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Glad to hear it worked out for you, and thank you for posting the details for others to learn from.
Old 10-18-2009, 09:38 AM   #6
aggieE46
Keep it clean
aggieE46's Avatar
Working for several thousand miles, now.
Old 10-18-2009, 10:41 AM   #7
guest11072016
Account closed.
Interesting...
guest11072016 is offline   Reply With Quote
Old 10-18-2009, 12:20 PM   #8
F1004fun
My Ride: '02 330Ci
I am interested to know if your OBD2 monitors have passed for the cats.
There was a while that I didn't get faults, like about 2 months but the monitors would still not pass.
Old 10-20-2009, 01:39 PM   #9
SmokeyDP
My Ride: 2001 M3
Nice...
Now if there was a way to get the EGT sensor to stop throwing a code from installing headers without actually disabling the monitors...
2004 Acura MDX
2001 Phoenix Yellow M3:
Schrick cams - AFE intake - Custom Tune - Supersprint full exhaust - Evosport pulleys - UUC Evo 3 short shift kit - Brembo 14" BBK brake kit - Euro rear floating rotors - TC Kline Double Adjustable coilovers - Vorshlag caster/camber plates - Adjustable rear camber arms - Black 2005 competition package interior - Vorsteiner CSL front bumper - 19" CSL wheels
SmokeyDP is offline   Reply With Quote
Old 10-20-2009, 01:59 PM   #10
aggieE46
Keep it clean
aggieE46's Avatar
I'll hook up AutoEnginuity later and see what's up.
Other than that, I guess I'll find out next year when I go in for inspection.
Old 10-24-2009, 09:39 PM   #11
F1004fun
My Ride: '02 330Ci
Originally Posted by SmokeyDP View Post
Nice...
It wouldn't be that hard to weld a fitting on there, you might want to consider running the EGT sensor as you DME looks at that for fuel and timing curves.
I don't own an M3 and I only work on a handful of them, so you M3 guys probably know more about that then I do.
Old 10-27-2009, 02:24 PM   #12
SmokeyDP
My Ride: 2001 M3
I have the EGT sensor, but unfortunately with the SuperSprint headers it throws a code unless you run 'race' software which disables the rear o2 monitors which also means the readiness monitors will not set.
2004 Acura MDX
Old 10-30-2009, 01:05 AM   #13
F1004fun
My Ride: '02 330Ci
Dude! This is perfect for you! Run the LC-1 into your rear O2 sensor signal and your golden. How man bungs are on the headers, 2 or 4? If you have 4 then it's the same as with the e-bay headers. If your serious about it I will help you with a wiring schematic, but it should be just about the same.
Old 10-30-2009, 01:10 AM   #14
SpeedDemon
My Ride: E92M3 E46ZHP Golf7R
AA Tuning worked for me and it can work for you too
SpeedDemon is offline   Reply With Quote
Old 10-30-2009, 03:41 AM   #15
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
how much does AA charge for a remap? and how long does it take?
SL Blak Soldier is offline   Reply With Quote
Old 10-30-2009, 04:39 AM   #16
SpeedDemon
$200 and I paid for overnight shipping both ways. I also actually had them put their throttle remap thing on their and raise the rev limit from 6800RPM to 7000RPM; they call it a custom tune and it was $400 in total for everything). My car had to be parked for 3 days and that was counting shipping between Seattle and Florida... not too bad.
Old 10-30-2009, 08:01 AM   #17
SmokeyDP
My Ride: 2001 M3
I thought the LC-1 only helps with the o2 and NOT with the EGT sensor being out of spec when it gets relocated?
I think I am just going to have it fixed correctly and get it custom tuned and be done with it actually.
2004 Acura MDX
Old 10-31-2009, 11:57 AM   #18
F1004fun
My Ride: '02 330Ci
Thats cool, I don't about the EGT not working right. I would think that as long as it is close enough the the exhaust port it should work the same.
You said the reflash turns off the light but doesn't pass monitors? Your lucky, I cant pass smog without my cat monitors checked off, even if all the others are. That was why I had to go with the LC-1, it was my only choice if I wanted headers.
Old 01-27-2010, 07:06 PM   #19
dpgrand
My Ride: 2005 330xi
I tried the o2sim, but i'm still getting a SES. More specifically I'm getting BMW codes 215 and 216, aka P2270, P2271, P2272, P2273. And I get "lean voltage not reached." This sounds an awful lot like the deceleration issue mentioned in the first post. Anyone have any thoughts/input?
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
dpgrand is offline   Reply With Quote
Old 01-27-2010, 07:43 PM   #20
guest11072016
Account closed.
This is bad news. I was hoping to get my o2sim installed when it warmed up
