Rating:
Display Modes |
#41 |
My Ride: 2003 325i
Hi, on my 2003 325i auto I didn't have the electric fan they show here but a mechanical fan with a fan clutch.
The following link shows the tools you need - I ordered from bimmertools - & has another link to another forum covering the procedure. http://forum.e46fanatics.com/showthread.php?t=564570 Steve |
#42 |
idle pulley aka deflection pulley for who was asking. I have the hydraulic system which im having a problem with.
I change my alternator this weekend and stripped the t-50 bolt in side the tensioner pulley. Does anyone know how to get this hydraulic system off?? Or have an idea of how to get the stripped bolt out? I'm sure you guys know there isnt very much space with the fan out |
#43 |
mine has been making noise since 2 years ago. especially in the cold morning. but lately it has stop after spraying WD40 on it. just dont spray it on the belt.
Albert Einstein once said - Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.
#44 |
I am trying to find the 32mm slim wrench and the pulley holder on line but I am not having any success. Can anyone help me out with identifying who I can get this from other than the local bmw dealership. I need to replace the idler pulley, but I cannot get the fan off.
#45 | |
My Ride: 2003 325i
fan clutch tool & 32mm thin wrench
http://www.whatsyourconcept.com/item...asp?itemID=879 |
#46 | |
Spray your fan nut with some lube if it's seized. Take the wrench, place it on the fan. Remember, reverse threaded. Take a hammer, and tap straight down while simultaneously using your left hand to push the wrench clockwise. I've always used this method, and 90% of the time I can get it within 1-3 taps. The other 10% usually requires a bit more lube and another dozen taps. Be careful, hit it too hard and you'll be buying a new water pump(I've never actually seen someone do this... but it's possible) |
#47 |
My Ride: 94 325i full m3 swap
very nice write up man, ill be bookmarking this for reference when i go to do this on, probably, wednesday.
![]() 1994 325i with full m3 swap from 1995 m3 /// S50 Engine ///Dinan 2 Chip /// CAI /// Front and Rear Cross Drilled and Slotted Rotors /// Coilovers /// 8000K Hella Projectors /// 8000K Angel Eyes /// Yellow Fogs |
#48 |
help! i cant get the fan off. im sitting here turning the nut for the fan from left to right as noted on page 1 but nothing is happening, so help?
#49 |
Do you have the two wrench set used to remove fan?
#50 |
ha no i do not but i got it off like right after i posted that. i just used an 11/4 wrench, yes, eleven/four wrench and a really long screwdriver. the screwdriver was used as a crowbar to hold the part of the fan with 3 bolts still while i loosened the fan nut. but after that, everything was very simple.
#51 |
Excellent! Some of the guys use the two wrenches and others are lucky enough like you to use one wrench and a long screw driver. I tried the screw driver and couldn't budge it, so off to the two wrenches I went. Change water pump as well while you were there?
#52 |
nah, it was alreayd 930 here when i started that little project, so i was just more interested in getting the tensioner changed out, but turns out im gunna have to replace that deflection pulley as well because both that and the tensioner pulley had gone bad. so i'll get that sometime next week probably. i have a few other minor issues to worry about for now.
#53 |
Banned
haha nice einstein qoute. well where is it did you actually spray wd-40 on...if you didnt spray on the belt??? and till this day does it still squeal???
#54 |
My engine started making a loud whining noise at start up but would disappear when it warmed up. The dealer said it was the tensioners and wanted $1300 for the repair. I found this great post and it gave me the confidence to try the repair myself. I bought 2 new tensioners and belts from Autohaus AZ and a $15 32mm wrench at Autozone and did the repair myself in about 90 minutes. The engine sounds like new again. Thanks to E46Fanatics for saving me over a thousand bucks!!!
I ended up getting the mechanical tensioners. I drive the car about 10,000 miles a year so I figure I have another 7 or 8 years before I have to worry about this again. |
#55 |
Thanks for this DIY, it helped me when I replaced mine!!
- 2002 Steel Blue 325Ci -
#56 |
Invalid User
you only need to replace those pulleys? i thought the tensioner was a whole unit.
#57 | |
My Ride: 2003 325i
If you have the non-hydralic version, you can not purchase just the tensioner pulley, you have to replace the complete tensioner & pulley assembly. |
#58 |
Get 11-28-1-435-594. It's the deflection pulley for the E46 316i/318i and is exactly the same as the M54 mechanical tensioner pulley. Dealers there in NA won't stock them since the 316i/318i weren't released there, but can still be ordered from Tischer for $37.45 (with some waiting time).
#59 |
Invalid User
how do you tell which one you have? i have an 2002 330ci
#60 |
My Ride: 2003 325i
I was worried about the same thing. You just have to do a visual and see it it looks like item # 2 in post 57 (non-hydrallic) or if it looks like the pic in post 9 & has a hydrallic cylinder.
Not much help I know. But if you have the hydrallic type the cylinder should be easily identified. I also highly recommend doing the idler pulley @ the same time. It's inexpensive and it typicall goes with the same frequency of the tensioner pulley. |
