Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Mid Atlantic
Mid Atlantic
DC DE MD PA VA WV
Thread Tools Search this Thread Rating: Thread Rating: 120 votes, 4.96 average.
Old 10-27-2009, 05:35 PM   #15121
Impulsed7
My Ride: just an M3, sort of
Originally Posted by snikwad View Post
scanning web right now for a fuel pump. i'll tell you all what. right now, im glad i dont have an M3, as their pumps are about double the price of the non Ms
Here, not sure if this works for the e46's too, but it should...
gonna have to do that for my little 318, X2 to save fuel starvation on right turns...
Impulsed7 is offline   Reply With Quote
Old 10-27-2009, 05:37 PM   #15122
Snik
Snik's Avatar
My Ride: IR M3 Vert.
u know, i was turning right. i was turning on the exit from 64 to 264, i had just started to make that rightm hit that bump and the car fukin died.
hmmm...
Do you ride a sportbike?
Old 10-27-2009, 05:47 PM   #15123
bimmerfan08
My Ride: F
Originally Posted by jwm5 View Post
Zach does Tech have any Law or PreLaw departments or classes, I am betting the staff would know of local lawyers, if they themselves don't practice... might be worth snooping around. That seems crazy high, but then again I have never needed a lawyer.
not sure Ill check into it though
"You are free to make choices. You are not free to escape the consequences."
bimmerfan08 is offline   Reply With Quote
Old 10-27-2009, 07:55 PM   #15124
Impulsed7
hmmm...
It should just stumble a bit on long hard right turns, not die completely unless you had like no gas in the tank. If it actually shut off because of this the check valve in the pump assy. is probably bad and backflowed all of your gas in the line.
Old 10-27-2009, 08:29 PM   #15125
Snik
Snik's Avatar
yeah it just died, i tried tapping and banging all kinds of crap, the top, the tank, the filter. nothing. then when vdo showed up i disconnected the battery for a few moments and she cranked right up. no CEL no sputter, nothing... im baffled.
Old 10-27-2009, 09:50 PM   #15126
RSDeuce
My Ride: 2002 BMW M3
Check and see if codes were generated, but that doesn't really sound like a fuel pump issue to me, more electrics....
RSDeuce is offline   Reply With Quote
Old 10-27-2009, 09:51 PM   #15127
Snik
Snik's Avatar
i sold my code reader
Old 10-27-2009, 10:30 PM   #15128
latino1ny
My Ride: BSM 335i
Autozone and Advance read for free... granted it's generic and not top-of-the-line BMW reader, but at least it will give you a general idea.
'08 BSM E92 335i 6MT/KW V1s/matte black grills/blacked out side markers/complete LED interior kit/DCI/M-aero front lip/Alcantara shift boot/Clutch stop/CDV delete/LED reverse lights/muffler delete/Cyba scoops/3.8" Cyba tips
latino1ny is offline   Reply With Quote
Old 10-27-2009, 10:38 PM   #15129
Snik
Snik's Avatar
dude, did you read, i DONT have a CEL(check engine light) therefore, a OBD2 reader wont show jack sh1t
Old 10-27-2009, 10:55 PM   #15130
RSDeuce
Not true, codes can be generated, and then go away (i.e. emissions sensors that fail, but then work again). If your car died like that, SOMETHING might have been recorded by the engine.
Old 10-27-2009, 10:58 PM   #15131
Snik
Snik's Avatar
No, if the CEL didnt come on a ODB2 reader WILL NOT read sh1t.
the ODB2 is meant for diagnostic stuff related to emission stuff, so a BMW code wont show on a OBD2 scanner if the CEL is not on.
Old 10-27-2009, 10:58 PM   #15132
Impulsed7
ECU's usually store codes for at least 40 starts, but he pulled the battery cable, which resets any stored codes.
edit, TV died today, time for HDTV, Plasma, and much bigger...
Old 10-27-2009, 11:12 PM   #15133
robb1887
My Ride: 00 Mshoe
Anyone got any small jobs they need done? Im in need of some Dinero stat...
robb1887 is offline   Reply With Quote
Old 10-27-2009, 11:20 PM   #15134
Snik
Snik's Avatar
Arent errors stored in the DME? i dont think the loss of power erases the codes. ive had CEL and disconnected and the CEL was still there.
Old 10-27-2009, 11:20 PM   #15135
Snik
Snik's Avatar
when u find one call me up, ill help you.
Old 10-27-2009, 11:28 PM   #15136
I-H8-DMV
My Ride: 2001 e39
Originally Posted by idriveane34 View Post
it's this changing weather fvcking with everyone's immune systems.
I agree. I do not get sick. I get headaches from sudden temperature changes. My body is very sensitive to barometric pressure. I like it either very hot or very cold. I like brunette or blond...I like vanilla or chocolate. I may sound like a black or white guy, but I do not make the dating a latino transition before I get with a black girl...I just go right for it....
...I dunno how I got on to this subject.
Oh yeah. It is the weather!
I-H8-DMV is offline   Reply With Quote
Old 10-27-2009, 11:32 PM   #15137
Snik
Snik's Avatar
^ lol
Old 10-28-2009, 06:44 AM   #15138
idriveane34
My Ride: kills bugs
that post made me laugh. ADD ftw!
shhhh....
idriveane34 is offline   Reply With Quote
Old 10-28-2009, 08:10 AM   #15139
StephWithStars
My Ride: 2004 330i
Send a message via AIM to StephWithStars Send a message via Yahoo to StephWithStars
I had a Neon that did that to me back before I joined the military. I was going 65 and it just died on me. The lights, dash, engine, everything. We unplugged the battery, then re-plugged it and attempted to jump start it - it actually worked, and the car ran long enough for me to get home. We tried everything; changed the spark plugs, coil pack, checked the fuel filter and it still wouldn't run again. Had it towed to the shop and turned out I had fried the computer and had a bad EGR valve.
Completely different car, but still bizarre nonetheless.
Neons are garbage to begin with. Absolute shiat. ANYway...
StephWithStars is offline   Reply With Quote
Old 10-28-2009, 09:16 AM   #15140
idriveane34
My Ride: kills bugs
How's everyone doing today?
shhhh....
Rate This Thread
