Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 11-27-2008, 03:04 PM   #41
sycE46
My Ride: 323ci
nice job. Makes me want to do an engine swap.
sycE46 is offline   Reply With Quote
Old 12-08-2008, 10:47 AM   #42
95blkmax
My Ride: 00 BMW 328i
Send a message via AIM to 95blkmax
Raymond, this forum (as great as it is) needs more DIY people like yourself, that although told it would be a PITA/ would not work/ too complex, just went out to do it ANYWAYS, and succeed while proving some A$Sumptions to be incorrect.
Excellent work!!!
95blkmax is offline   Reply With Quote
Old 12-08-2008, 12:03 PM   #43
sonspot
My Ride: 330I Spot/Prem/cold
damn wish i saw this sooner, i was brampton all last week visiting my parents and friends,, i have EDIABAS setup on my laptop, maybe it could have helped with finding your leaks or any other fault codes,. anyhow great job, let me know if you go to any meets in brampton, (guys are lazy in windsor) i should be in the GTA closer to christmas week.
thanks
sonspot is offline   Reply With Quote
Old 12-08-2008, 01:22 PM   #44
JSanders
My Ride: Breaks too often
Awesome job!!!
JSanders is offline   Reply With Quote
Old 12-17-2008, 01:45 AM   #45
raymond3080
My Ride: 323CI
Excellent work!!!
Thanks man i think that's what the forms are for! They let people see what they can do and helps share knowledge between us.
thanks
Hey sonspot yeah if you have any time that would be great im done my exams today so i gotta sort out the leak on my break...lemme know when your in town by PM...Thanks though
Originally Posted by wrathchild819 View Post
Awesome job!!!
Thanks!
haha engine swaps are always fun...but they are even better when dont need to drive the car!
raymond3080 is offline   Reply With Quote
Old 12-17-2008, 01:58 AM   #46
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
interesting - I have read over and over that the intake volume on the 330 intake is greater than the 2.5 intakes...they are different part numbers - when comparing the m54b30 and m54b25
/_________\
O==[][]==O
Old 12-17-2008, 02:08 AM   #47
raymond3080
My Ride: 323CI
yeah they are not EXACTLY the same...But so close that i used the M54b30 intake boot on the M52Tu25 intake manifold...beside each other they are very close in size... it is only the MAF section which is larger but not the actual throttle body.. i would suspect that this would allow for greater air flow but not by a marginal amount...
Old 12-17-2008, 03:14 AM   #48
330i ZHP
330i ZHP's Avatar
Again, I have a M54b30 and an m54b25 sitting here and I have examined the intakes and throttle bodies - i agree that looking at the intakes there does not seem to be a difference...but the TB's are different sizes
AND like you mentioned, the intake tubes from the MAF to the TB are very different (as are the MAF's)
Which injectors are you running? If using the 323 injectors, are you starving the motor?? Running it lean? What color are the injectors on the 323?
btw - I am not questioning your efforts - I am genuinly interested as I have the spare M54b25 motor sitting here and would love to find a dead 323 or 328 or 325 in swap this motor in for my daughter who will be driving in a few months.
does anyone know how much a 323 or 328 with a dead motor would cost? Needs to have clean body and interior...I can fix the rest
/_________\
O==[][]==O
Old 12-17-2008, 10:49 AM   #49
raymond3080
My Ride: 323CI
ah dont worry im glad your looking into doing the swap your self! well because of vacuum leak i couldn't really tell if switching the injectors made a difference... from what i remember the M52 has black and the M54 blue? Id imagine that the blues have a bit higher flow rating although im sure the stock ones could handle the displacement increase...Up here in canada your lookin at around $5000CND if that helps...I noticed your from Washington, DC. Nice place my friend goes to school around there so I took a couple days off and drove down...only bad part are the roads downtown washington holy crap my slammed vw passat didnt like it very much...gl with your swap though let me know if you need anything else...
Old 12-17-2008, 12:47 PM   #50
330i ZHP
330i ZHP's Avatar
I just finished (well, I have some more wiring to wrap up) a swap in my wagon. I removed the m54b25/auto and installed a m54b30/6spd with supercharger. This was after swapping the 3.0L in my sedan with a built 3.0L for stage III SC. I built the 3.0L stage III motor and I enjoyed every minute of it
/_________\
O==[][]==O
Old 01-14-2009, 04:52 PM   #51
jersyboyy
My Ride: My dad has a 323i
Hey you wanna sell that m54/b25 motor you just removed from that one car to upgrade to the b30?
jersyboyy is offline   Reply With Quote
Old 01-14-2009, 05:26 PM   #52
02m3csl325
My Ride: is Stage 2 AWD!
Originally Posted by azzy989 View Post
ya i'd like to see pics too..someone did this swap on his 328 and it turns out there are some plugs that didn't fit.
http://forum.e46fanatics.com/showpos...2&postcount=19
did you also retrofit the drive by wire?
I was under the impression that the 2.3 and the 2.8 were "matching" and the 2.5 and the 3.0 were "matching" in the sense of swappability. When motor parts and exhausts are sold, the 2.3 and 2.8 are always the same parts and the 2.5 and 3.0 are the same parts. If I'm wrong then glad it works but I was thinking it wouldn't.
02m3csl325 is offline   Reply With Quote
Old 01-14-2009, 10:55 PM   #53
330i ZHP
330i ZHP's Avatar
yes I would - it is a 2.5 and I have the 5spd auto still attached to it
/_________\
O==[][]==O
Old 02-03-2009, 03:40 PM   #54
jersyboyy
Pm me a price for just the motor minus electronics/intake manifold/throttle body
Im going to attempt the same swap raymond did in my father 323i(he blew his motor up it shad 180k on it blew a head gasket and warped the head/block)
Old 08-24-2009, 10:54 PM   #55
R1killa
My Ride: E46
This sounds like an awesome swap. I have a couple of questions:
1. So as long as you use the m52tub25 intake manifold everything else is plug and play? As in you did not have to make any customer modifications to either any electrical connections? Exhaust? Drive shaft, mounts, anything, etc? or was is just as if you were swapping a m52tub25 back into it?
2. Do you know if the 323 transmissions fits the m54?
3. Did you do a dyno to see what you were getting out of the motor with the m52 intake and dme? I have Beltronics FX2 so if you want to get an idea let me know.
4. Finally, I am in the GTA also and I am just wondering how you found the engine? What are some specific places I can start calling?
R1killa is offline   Reply With Quote
Old 10-27-2009, 07:18 PM   #56
mujjuman
My Ride: not an E46
I'm trying to do this swap as well.... but from 325i to 330i
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 10-27-2009, 09:57 PM   #57
R0B
My Ride: zhp sedan
Originally Posted by VonGeiss View Post
how much of a difference in performance do you notice going from the 323 to the 330 engine? given that you've had both now.
My cousine has a 323i (one of the last ones in production) and I have a 330i zhp. I feel like the difference is pretty immense... But I am looking to get rid of my engine and buying a S54. I would offer my M54 but it has 106,000 miles on it. It does get 31 mpg on highway still I don't know how.
R0B is offline   Reply With Quote
Old 10-27-2009, 10:07 PM   #58
JojO CeL
My Ride: 2001 325ci
Send a message via AIM to JojO CeL
Originally Posted by raymond3080 View Post
Well I couldn't find any support on this site but after some research I found out it could be done so I did it. Anyways I have some pictures and can give some info and tips on how its done. Quite a easy swap. Anyways if anyone wants more info just IM me or post here and I'll post more.
i did a motorswap on my 325ci to a 330 engine. then did a stage 2 supercharger on it from technik.
the DME was a ***** to reprogram.
| team 16niss
sponsors: Dunlop | Meguiars | Valvoline | Swiss Audio | Rogue Engineering | Speedwell footwear |Zaino Mobile Detail | First Class Paint and Body | Umnitza | GSmotorsports
JojO CeL is offline   Reply With Quote
Old 10-27-2009, 10:08 PM   #59
JojO CeL
My Ride: 2001 325ci
http://forum.e46fanatics.com/showthr...light=jojo+cel
| team 16niss
Old 10-27-2009, 10:26 PM   #60
mujjuman
My Ride: not an E46
lol if you were in NY, i would buy that engine off you.
mujjuman
2003 325xi 5MT
sig by Solidjake
323ci, 330ci, m52, m54, swap
