Thread Tools Search this Thread Rating: Thread Rating: 6 votes, 4.33 average. Display Modes
Old 11-09-2009, 07:45 PM   #1
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Jakes DIY Videos
E46 gauge cluster removal - sharpie mod - gauge face removal (portion). Should be similar in a way to other models
E46 spark plug diy - should be similar to other I6 engine models.
E46 DISA removal. Should be the same for other I6 engine models
E46 spark plug boot diy - should be similar to other I6 engine models.
E46 idle control valve diy - should be similar to other I6 engine models.
BMW Oil service / inspection reset
Old 11-10-2009, 04:05 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
Vids updated: Added service indicator reset
Old 11-10-2009, 08:56 PM   #3
Hartman
My Ride: 2000 323i
Does that procedure work on all e46s?
Hartman is offline   Reply With Quote
Old 11-10-2009, 09:19 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
It should. I read your thread about you having a problem, right? Give it another shot
Old 11-10-2009, 09:23 PM   #5
stakka
My Ride: 325ci
Send a message via AIM to stakka
nice. props jake!
stakka is offline   Reply With Quote
Old 11-11-2009, 10:42 PM   #6
ken@bimmertools
Is NOT A Mechanic
ken@bimmertools's Avatar
My Ride: F30
Awesome, Jake!
Bimmertools is under new ownership! Please welcome Taylor@bimmertools.com.
Click Here to say hi.
ken@bimmertools is offline   Reply With Quote
Old 11-12-2009, 04:02 PM   #7
Hartman
My Ride: 2000 323i
Nope that wasn't me
Old 11-12-2009, 09:01 PM   #8
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
SolidJ,
What does the red sharpied cluster needles looks like at night? or looks like in general?
any pics or vids?
delmarco is offline   Reply With Quote
Old 11-12-2009, 09:17 PM   #9
secono330ci
My Ride: 04' 330ci/15' A3 TDI
Nice dude I will doing spark plugs soon so that will be a help
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 11-12-2009, 09:25 PM   #10
Solidjake
Zero. Leaks.
Solidjake's Avatar
Originally Posted by delmarco View Post
SolidJ,
any pics or vids?
Same thing as if the needles were white
See attachment
Right on brotha!
Old 11-12-2009, 11:14 PM   #11
delmarco
See attachment
Right on brotha!
so it just looks red during the day?
Old 11-13-2009, 06:57 AM   #12
Solidjake
Zero. Leaks.
Solidjake's Avatar
Correctemundo
Old 11-13-2009, 09:42 AM   #13
WidowFactory
My Ride: '99 328i
Awesome set of diys, but how did you clean the ICV? Just run it under the tap?
WidowFactory is offline   Reply With Quote
Old 11-18-2009, 10:04 AM   #14
Solidjake
Zero. Leaks.
Solidjake's Avatar
Get brake parts cleaner and put the stick in there, spray it up a lot and slosh the fluid inside.
Old 11-18-2009, 10:09 AM   #15
smolck
My Ride: 2004 ZHP Sedan
No, it won't work on 99-00 models. Only 01 and up. The earlier ones have to have the pins on the gong connector (where you hook to tune the ECU) under the hood jumpered together.
AWESOME JAKE!!!!
Check out my BMW Blog
http://smolckbmw.blogspot.com/
Check my Youtube channel for DIY's and fun stuff
http://www.youtube.com/user/flipfinish?feature=mhee
smolck is offline   Reply With Quote
Old 11-18-2009, 02:18 PM   #16
Solidjake
Zero. Leaks.
Solidjake's Avatar
AWESOME JAKE!!!!
Thanks!
Old 11-18-2009, 02:33 PM   #17
Custom3
My Ride: HellRot 330CI
very cool....good stuff man
Old 11-18-2009, 02:36 PM   #18
Custom3
for the idle control valve what are the symptoms of it being dirty? ruff idle? did you feel any difference by cleaning it?
Old 02-02-2010, 02:24 PM   #19
anacondatcu
My Ride: 2000 328i
AWESOME JAKE!!!!
wish i knew this before i started. i now have the idle control valve seperated from the engine, but cant remove it. i need to reattach it and would appreciate any advice on doing this with the throttle cable in the way, otherwise i'll need to tow it
anacondatcu is offline   Reply With Quote
Old 02-02-2010, 03:25 PM   #20
Solidjake
Zero. Leaks.
Solidjake's Avatar
The ICV just gets pushed back in. Shouldn't be that difficult.
o2 sensor spark plugs icv
