Old 08-10-2009, 07:16 PM   #1
mvrk10256
My Ride: E30 325i
Wink Mounting 6.5 woofers in deck and doors
So i managed to blow out all 4 woofers being a teenager and listening to my music too loud. So i decided to replace them. unfortunatly the pics of the day got destroyed so i wont post a full write up but i will post this handy hint.
Those little angled black brackets that come with speakers are damn handy for mounting 6.5 in the BMW. The actual speaker size in the BMW is a little smaller but the Blaupunkts i purchased are 158mm so they are a perfect match. GTx series sound very good. anyway back to the mounting.
if you take those black things bend them straight, use some needle nose to open the screw hole a bit wider, use some 6/32 x 1/2" bolts and nuts, you can use them to pressure mount the speakers both in the front and the back. This is a cheap (everything except the bolts come with the speakers) and efficient (i even did it in the doors with locking washers, so they wont come lose from closing the door).
Way easier then cutting a adapter or buying one, if they even sell one.
just a heads up to those guys who want a solid job, but are a bit low on cash.
Old 08-12-2009, 12:01 AM   #2
winston330xi
My Ride: 2001 bmw 330xi
Good that it worked out for you without any adapters. These are what i used for both front and rear speakers. Cheap and easy to use. http://cgi.ebay.com/ebaymotors/ws/eB...category=38646
winston330xi is offline   Reply With Quote
Old 08-12-2009, 12:38 AM   #3
mvrk10256
My Ride: E30 325i
lol that would have made it way easier. but hey you live you learn. thanks for posting.
Old 11-10-2009, 09:06 PM   #4
bor3dom
My Ride: 2000 323i
question...were u able to still use your normal mesh grilles? or did you just leave them off?
also...is there any reason you got the 6.5" speaker versus a 5.25" like the stock ones?
bor3dom is offline   Reply With Quote
Old 11-10-2009, 09:06 PM   #5
bor3dom
My Ride: 2000 323i
Old 11-11-2009, 02:30 PM   #6
mvrk10256
My Ride: E30 325i
the stock ones are 6.25" if i remeber correctly. the 6.5fit perfectly. ..... ya i mounted that insulator ring and the stock grill, i especially like these cause theymount perfectly in the doors with no modiffication. just use the same method for attachemne.
Old 11-11-2009, 02:37 PM   #7
Snik
Snik's Avatar
My Ride: IR M3 Vert.
im running 6.5s, used a wooden ring spacer, to hold the speaker, but said ring is glued and screwed to the stock opening. works great.
Do you ride a sportbike?
Old 11-11-2009, 02:43 PM   #8
mvrk10256
My Ride: E30 325i
thats probably the right way to do it... but if a pinch my method works. decided to go and take some pics to show you guys
ID:	338162   Click image for larger version
ID:	338163   Click image for larger version
ID:	338164   Click image for larger version
Old 11-11-2009, 02:45 PM   #9
Snik
Snik's Avatar
^ does it clear your window glass when lowered, in the back.
my 6.5s are deep, i think my window actually rests on the back of the speaker when lowered.
Old 11-11-2009, 03:00 PM   #10
mvrk10256
My Ride: E30 325i
the nice thing about the blaukpunkt GTx series is that they are really shallow. these GTx650s were actually about 1/2cm "shorter" then teh stock speakers great for whe i did the door.s
Old 11-11-2009, 03:01 PM   #11
Snik
Snik's Avatar
cool
Old 11-12-2009, 11:20 PM   #12
mvrk10256
My Ride: E30 325i
yupz
323i, deck, doors, speaker, woofer
