Old 10-16-2009, 10:36 PM   #21
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Originally Posted by firefirefire90 View Post
what sickens me is my local indy quoted me 2 hours for this job while the OP has been quoted 4.5 for a job that requires no additional work other than dropping the oil pan
Not sure what you mean?? Removing the control arms have nothing to do with dropping the frame enough to get clearance for the oil pan to come out.
4.5 hours is a fair time for doing an oil pan gasket.
Oil Pan Gasket
Replace
Single Timing Chain
M3 B 3.9 5.2 Notes
Dual Timing Chain
325
2WD
Convertible B 3.3 4.6 Notes
Coupe, Sedan, Wagon
Manual Trans B 3.3 4.6 Notes
Auto Trans B 3.4 4.6 Notes
AWD
Manual Trans B 6.3 8.8 Notes
Auto Trans B 6.4 8.8 Notes
330
2WD
Coupe, Sedan
AWD
Manual Trans B 6.4 8.8 Notes
Auto Trans B 6.5 8.8
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 10-19-2009, 10:58 AM   #22
gwburke
My Ride: 1999 BMW 328i
[QUOTE=jbeurotech;10773303]Not sure what you mean?? Removing the control arms have nothing to do with dropping the frame enough to get clearance for the oil pan to come out.
All due respect bro, but my mechanic has my cross-brace and control arms and bushings removed to replace a couple of broken bolts. From there he has to unbolt the front sway bar (1 minute), unbolt/lower the engine brace while using an engine hoist for support (29 minutes if he takes his time), unbolt/lower power steering pump (10 minutes because he has to remove the pulley first)...then remove 20+ oil pan bolts, replace gasket, re bolt everything. 4.5 hours for that is ridiculous! I have no issue with a mechanic needing to feed his family, but I'll pay him for the actual time he puts in on my car...not some bullshit BMW work allotment figure.
Some DIY'ers find removing the bushings allows the engine brace to drop further, I agree.
gwburke is offline   Reply With Quote
Old 10-19-2009, 11:01 AM   #23
jbeurotech
Regional Sponsor
[QUOTE=gwburke;10781811]
Don't forget the steering rack that has to be taken loose to drop the cross member. I would be happy to charge actual time Customers really would not like this system any better than the current one.
All I am saying is he quoted a fair price to do the work You may not like the price so you have the option of DIY or finding someone less qualified that will do it for less.
Seth Thorson
Old 11-15-2009, 10:35 PM   #24
Lbert
My Ride: 325i
titan 3, jbeurotech, or anyone:
Is the eyelet or engine lift ring by the vanos enough to hold the engine in place with the engine cross brace off? Do you need other lift points to do the job. I plan to use the HF engine brace mentioned in this post to hold up the engine while doing the oil pan gasket replacement.
Lbert is offline   Reply With Quote
Old 11-15-2009, 10:53 PM   #25
BodyMan
My Ride: 2002 325i
If you don't want to pay to have it done, why don't you buy all the tools needed and just do it you're self? You are partly correct, there is some labor overlap. I don't know of any shops around where I live (body shops or mech.shops) that charge actual time. If I charged that way, I would retire off of you're car because it would take me 6 weeks to repair it at what, $80-$100 an hour? I'm down with that.
BodyMan is offline   Reply With Quote
Old 11-15-2009, 11:40 PM   #26
jmay87
jmay87's Avatar
My Ride: e36,e46,e90
the front eyelet works fine to just drop the cross brace to drop the oil pan
--1995 E36 M3--2001 E46 325i--2008 E90 335i--
jmay87 is offline   Reply With Quote
Old 11-15-2009, 11:53 PM   #27
Titan 3
Titan 3's Avatar
My Ride: E46 325ci, F36 428ix
Agreed. Front eyelet gets it done.
Titan 3 is offline   Reply With Quote
Old 11-17-2009, 12:16 PM   #28
Dan1983
My Ride: X3 35i, MaxPsi M3
after reading this thread I worked the oil pan around a bit and got it off without removing the oil pump. It helps to remove the small bracket at the front of the oil pan on the driver's side, it gives a little more room.
Dan1983 is offline   Reply With Quote
Old 11-17-2009, 04:28 PM   #29
jbeurotech
Regional Sponsor
Yup front Eyelet will work
Seth Thorson
Old 07-15-2010, 08:36 PM   #30
topaz_330
My Ride: 2002 BMW 330Ci
Can anyone tell me from experience, or having done this if you had to have the car re-aligned after taking brace/s off to drop it?
Thanks!
topaz_330 is offline   Reply With Quote
Old 07-15-2010, 11:10 PM   #31
loginfailed
My Ride: My buddies 350hp
Thanks!
The last one I did at work. I test drove after I completed the job and it drove straight and the steering wheel was straight. However I did check the toe and found it was slightly out of spec.
I always include an alignment for any quote that involves removing/replacing any suspension parts. Even though there may be no immediate symptoms, over the course of few thousand miles, a minor toe issue can eat up tires pretty bad.
loginfailed is offline   Reply With Quote
Old 07-15-2010, 11:35 PM   #32
loginfailed
There's more to it than that. Like installation & removal of the engine support brace. Disconnecting and reconnecting of the battery. Cleaning the surface of the block & pan to remove any stubborn, stuck on old gasket material. Dealing with oil dripping all over him during removal, while cleaning surfaces and during replacement of the pan onto the block. Applying dabs of sealant where required. Re-stabbing the dipstick tube making sure the o-ring is still in tact and in place. Paying special care not to damage the high mileage brittle platic dipstick tube vent hose while removing/reinstalling the tube. Torquing the oil pan bolts to proper spec to prevent future leaks and or cracking the oil pan due to over torquing. Filling the engine with oil afterwards. Road testing the car after the repair. Lifting the car back up after the road test to verify it's no longer leaking. Cleaning the shop floor from the mess the leaky car made all over his floor.
No offense intended.. Just saying.
Old 07-16-2010, 11:24 AM   #33
topaz_330
Well said!
Old 10-27-2010, 04:57 PM   #34
MCMILO
My Ride: 2002 BMW 330i
Okay...just my 2 cents. Repair times are APPROXIMATE not EXACT, true mechanics are faster than techs. Login, no offense but about half of what you say adds to repair time is BS, you're padding the bill sir. Oil fill? You drained it, fill it back up. Road test? That's on you, checking to see if you messed up or not. Lift and verify? You should know if you did it right or not. Cleaning up after yourself? That's on you brother.
I suppose the clock is still running if you run to the john or getting tools before you start or washing your hands(you forgot that one). I hate using the book for repair times because it's mostly inaccurate...1hr billed is more like 20min actual work time.
Just saying.
MCMILO is offline   Reply With Quote
Old 10-27-2010, 06:00 PM   #35
loginfailed
Just saying.
This is the difference between someone who has experience and expertise, and someone who is just monkeying around under your car.
Pay once my way or pay twice your way. You obviously have no idea what you are talking about.
Period.
Old 10-28-2010, 08:14 AM   #36
jbeurotech
Regional Sponsor
Just saying.
So all that time Cleaning up and stuff is for free. Guess where you work they ask you to PUNCH out to put away your pencil...... BS
Seth Thorson
Old 10-28-2010, 08:40 AM   #37
loginfailed
1) Discover the BMW mommy gave me has an oil pan leak.
2) Search google for a how-to to fix it myself.
3) Find a thread on E46F where grown men are talking.
4) Realize I can't do it myself because I'm 16.
5) Realize there's no way I can pay 4.5 hrs labor on my McDonalds salary.
6) Sign up for E46F and make a single post displaying my ignorance.
7) Ask mommy for a loan.
Old 09-24-2012, 07:45 PM   #38
Herbalicious
My Ride: 330ci, M3, Z06
Yep, pretty much!
Some of these people on here are so dumb and ignorant!
Don't wanna pay then do it yourself, judging by the idiot speaking it will take him 10 hours before he has the car towed to a shop to fix his mess!
Herbalicious is offline   Reply With Quote
Old 02-11-2014, 12:43 PM   #39
getawaycarz
Account Under Review
My Ride: conversions
Originally Posted by Herbalicious View Post
Yep, pretty much!
I was scrolling google looking for a simple labor time for an oil pan gasket on a 325xi and this forum thread popped up. I see that it is only for the 2 wheel drive E46, though I was reading anyway and signed up to add to the conversation. I know 4.5 hours to be a fair time for a 2 wheeler, with the proper engine hanger, a lift, full tool box with top quality non-rounding off all your hardware style tools, patience to not break anything in the process to cost the customer more money that isn't necessary, cleaning solutions and corner sealants that most don't even use but are needed, time to actually completely degrease the engine compartment and yes...check your work after a road test. A fact: You can't efficiently beat that time and come out with the same clean work that a good qualified mechanic/tech did that used the proper everything and can tell you honestly that he checked it afterward and it has been fixed properly.
getawaycarz is offline   Reply With Quote
Old 02-11-2014, 01:09 PM   #40
Cowspoo
My Ride: 328Ci
Welcome, Getawaycarz ... I mean, i've thought about registering on a random forum just to write a thirteen line response to a two year old post, but haven't done it yet. How'd it feel?
spacebarissolazy
doesntfeelikebeingpressed
Cowspoo is offline   Reply With Quote
