Old 08-27-2009, 12:28 PM   #1
Kubica
My Ride: 2003 325xi
Feathered Tires
Hey guys i have a question or you.
I run a square 18" setup on my xi with Vredestin tires.
My right side tires are both feathered on the outside edge from driving at NHMS.
Should I switch them to the left side? I do plan on going to the track two more times this summer. The tires are not directional, they only have an inside and an outside.
If I do swap, id have to go front right to front left, and rear right to rear left, because one of my rear wheels is slightly bent and I dont want it on the front.
Any suggestions? Should i just leave them and keep driving? What causes the feathering?
Thanks guys.
Old 08-31-2009, 03:28 AM   #2
e46techtuner
My Ride: 2000 328i
Feathering is usually caused by too much toe positive or negative. You can check your alighnment.
e46techtuner is offline   Reply With Quote
Old 09-01-2009, 04:47 PM   #3
Kubica
My Ride: 2003 325xi
Thanks. The alignment is actually good, so it's not that.
Remember it's both right side tires that are feathered on the outside edge.
I am fairly certain its from running over rumble strips at NHMS with my right side wheels.
Do you guys think i should switch them to the left side before my next track day?
That way I'll probably have 4 feathered tires, rather than just two!?
Anybody know if this is tire pressure related?
Old 09-02-2009, 02:50 AM   #4
e46techtuner
My Ride: 2000 328i
I would rotate them. That way they wear evenly so you get the most use out of them.
Old 09-02-2009, 11:53 AM   #5
Kubica
My Ride: 2003 325xi
I had been rotating them until I slightly bent one wheel, which now resides on the back.
I guess the question is if i should swap left for right, so all my tires are feathered after I go to the track the next time?
Or leave them where they are, feather the right side tires more at the track, then put both feathered tires on the back of the car?
All four tires have about 6.5-7/32nds left.
Old 09-08-2009, 05:39 AM   #6
e46techtuner
My Ride: 2000 328i
I would get that bent wheel straightened or replaced.
Rotate, swap...tomato, tamato...
Looks like you will be needing new tires soon.
Old 11-19-2009, 02:58 PM   #7
teleopti
My Ride: BMW 330i
Any feathering issues are caused by too low of air pressure. You can't reverse feathering effects but can minimalize it once it started by ensuring proper air pressure at all times.
teleopti is offline   Reply With Quote
Old 11-19-2009, 03:28 PM   #8
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Rotate them and kill them out at the track, then get some new tires...
I have the same issue as you since I have an aggressive camber and toe spec on my track car.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
