Thread Tools Search this Thread Rating: Thread Rating: 232 votes, 4.97 average.
Old 11-17-2009, 10:58 AM   #1
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
Wink BMW E46 Integrated Bluetooth and Voice Command for Less than $100 Pictorial DIY
FIRST OFF: I must give much props and thanks to SycE46 for giving me the idea for doing this. He had already did this DIY on his car by the time I started it on mine and without his advice and directions this Pictorial DIY Project would not have been possible. Thsnks SycE46!
This DIY is for adding Bluetooth with Voice Command features to your 1998 to 2006 BMW E46 Sedan, Coupes and Convertibles. This DIY focuses on integrating an aftermarket bluetooth and voice command into the BMW Business CD53 Radio (all year Blaupunkt or Alpine models) so that you control your mobile phone's incoming and outgoing calls only using the steering wheel buttons and your voice.
The DIY difficulty of this project is very easy and takes the average Joe about 30-40 minutes. The only tools required are clean fingers, a star point screw driver and flat clean dull butter knife for prying the dash trim off. There is no splicing wires, no removing seats or console armrest, no adding antennas on your roof or digging around your trunk for cables. This DIY ONLY requires removal of the Radio, Center Vent and Glove Box (total of 10 screws) and everything else is plug and play. Some DIYs state that removal of the A P!llar is necessary for running the mic to the headliner but I will show you that it is NOT necessary to remove the A P!llar.
The cost of this DIY can vary. You will need to purchase the Connects2 CTPPAR007 steering wheel integration kit from the UK vendor
( http://www.lowcostcaraudio.co.uk/lcc...er/pid/7642231 ) and their price is set at 49.99 (about $80.00 USD). And next you will need to order the Parrot CK3000 Bluetooth kit (it is also called the Parrot ck3000 evolution) which can cost from $9.00 and up on eBay. You do not need to buy anything else nor can you substitute other Parrot Bluetooth kits or aftermarket Steering Wheel/Radio Adapter harnesses. It will not work here. Also do not get tempted to save money on the CTPPAR007 and buy another similar Steering Wheel Control Adapter harness-and they are lots out there that claim to work with various bluetooth kits. It will not work here. This DIY will ONLY WORK with the CTPPAR007 and the Parrot ck3000 together!
When said and done this DIY will upgrade your BMW with much of what the OEM Bluetooth does including instant and automatic pairing and unpairing when you enter or exit the car, one button touch voice command, one button touch redial and full radio and steering wheel integration. The only thing you will not get is full Caller ID read out on your radio display-instead it will display PHONE or WAIT. This is something I can do without as I may have people sitting in my car and I do not want them to see who is calling me (see under girlfriend).
PART ONE: Looking at what we got
Here I got everything I needed off eBay. You need the CTPPAR007 kit which you can also find on eBay or eBay.co.uk. The vendor states that the CTPPAR007 is for the 1998 to 2001 E46 and the CTPPAR008 is for the 2002 to 2005 E46. This is wrong the CTPPAR007 has the 17 pin style connecter that all year BMW E46 cars and all year BMW Business CD53 Radios come with.
The CTPPAR008 is the flat style 40 pin connector that is found on the 2006+ E90 BMWs. So that will not work on the E46.
When you open the Parrot ck3000 kit you will see the obvious main bits (the blue box, the mic and the controller) and you will also see a bag filled with a few wire harnesses and a black rectangular module for connecting to the radio and allowing for the mute function. You do not need this since the CTPPAR007 will replace this portion of the ck3000 kit. Also you MUST HAVE the ck3000 Controller connected to the main blue box in order for the CTPPAR007 to make the steering wheel buttons work with the kit. You do not need the controller on your dash when using the Bluetooth as it only needs to be connected so you can tuck it behind the glovebox with the other modules.
delmarco is offline   Reply With Quote
Old 11-17-2009, 11:00 AM   #2
delmarco
PART TWO: Opening up the Dash
Here is a picture showing the location of the six screws. Unscrew these and the glove box will drop out easily.
Old 11-17-2009, 11:03 AM   #3
delmarco
PART THREE: Installing the Guts
NOTE: For ease of understanding this DIY I've taken the liberty of labeling the Harness Head Connectors as A, B and C. This labeling is only specific to this DIY and not used by Parrot or Connects2.
The A Connector is what you have in your car right now. It is what connects the car to the BMW Business CD53 Radio. With the exception of the possible Data Link mini connectors that attach to the bottom section brackets(you may or may not have these Data Links in your car's A Connector depending on whether your car has prewiring for the CD Changer or AUX input/Sirius/Ipod Data Links) these are all the same on all BMW E46 vehicles from 1998 to 2006.
The B Connector
. This is what will replace the function of your A Connector when you install the kit. Or a better way to say this is that it will take on the role of the A Connecter in connecting directly to the CD53 Radio and also carrying any Data Link connectors that you have going into the Radio.
The C Connector forms a connection with the original A Connector in your car thus connecting the entire Bluetooth system AND CD53 Radio to the rest of the car (IE. for power, ground, speakers, etc...). This C/A Connection is the only thing that adds difficulty to the DIY as it is hard to tuck away behind the Radio when replacing the Radio unit. So we must set the C/A Connection above the radio space and to the side of the upper Center Vent space.
Old 11-17-2009, 11:07 AM   #4
delmarco
PART FOUR: Setting up your MIC
And that is it you are done!
I been getting a few PMs from folks with GPS Factory Navigation units looking for the 17 pin A Connector in their cars or wondering if they have the same connections.
From what I can tell you do have the same A Connector but it is location in the trunk with the GPS Computer ECU/DVD module.
and it will look like this
So you will need to hook up the parrot ck3000 and ctppar007 all in this trunk space and run the mic thru to the cabin dash area. The ck3000 mic wire is long enough to pass thru the firewall into the cabin along the driver's side and you can place it on the dash or A p!llar column. If it is short you can get a mic cable extender at Radio Shack or any electronics store.
Old 11-17-2009, 11:23 AM   #5
TR_MS3
Banned
My Ride: 2002 M3 Convertible
subbed
TR_MS3 is offline   Reply With Quote
Old 11-17-2009, 12:02 PM   #6
delmarco
Here is a direct link to the picture album;
http://img196.imageshack.us/gal.php?g=60481887.jpg
....and my eBay auctions showing where and how I got my stuff.
Old 11-17-2009, 12:07 PM   #7
DANe46
My Ride: 2004 BMW 325i E46
NICE... looks like value of the Parrot kit has gone up on EBAY since this DIY. Definitely going to try this, this weekend... THANKS!
DANe46 is offline   Reply With Quote
Old 11-17-2009, 02:19 PM   #8
pmal
My Ride: '05 325ci, '04 R1
Dude, it's unbelievable how thorough and complete your DIY's are! I plan on using your homelink DIY first, and then moving on to the bluetooth next. For a 1st time BMW owner, this is awesome. Just wanted to let you know that this stuff is much appreciated. Thx for taking the time!
pmal is offline   Reply With Quote
Old 11-17-2009, 03:17 PM   #9
delmarco
Thanks.
Next DIY coming up is the BMW Business CD53 (MP3/Sirius/iPod) Ultimate Media Upgrade DIY for all years BMW E46 especially the pre-2002 cars.
Then Coolant/Waterpump/Thermostat Maintenance over the Winter and brakes and wheels next Spring.
Old 11-17-2009, 04:24 PM   #10
Darkoz
My Ride: E46 325Ci
fantastic write up, very clear and thorough, well done.
Darkoz is offline   Reply With Quote
Old 11-17-2009, 09:48 PM   #11
GoldieE46
My Ride: 2000 328Ci
I'm waiting for the sirius/ipod!
GoldieE46 is offline   Reply With Quote
Old 11-18-2009, 10:14 PM   #12
dave330i
My Ride: 2001 330i steel blue
+1 on the sirius,,,I would love to integrate it off my winshield and I would love an ipod as well in my 01
2001 330i 5sp Sport package ,steel blue, AA S/C , Remus exhaust, UUC Short shifter, UUC clutch stop, Braided brake lines, UUC Strut bar, Xenons, depo clears, Eagle Eye LED's
dave330i is offline   Reply With Quote
Old 11-19-2009, 02:39 PM   #13
e46bonestock
My Ride: 325
awesome job, this will be my next project for next month.
edit: woah! prices have jumped. I'll have to see if I can get these anywhere else.
e46bonestock is offline   Reply With Quote
Old 11-19-2009, 02:52 PM   #14
tha ridla
My Ride: '03 325i
NICE DIY!!!! Any idea if this would be possible with the Pioneer AVIC N3?
tha ridla is offline   Reply With Quote
Old 11-19-2009, 03:07 PM   #15
delmarco
Good Question.
I was wondering that myself.
On paper;
It should work if
1. Your AVIC N3 has the ability to work with a steering wheel control adapter AND
2. The connections in the back of your AVIC N3 matches up with the B connector-and I'm guess it will because the B connector takes the role of the A connector that is coming from the car. So as long as the AVIC N3 installation doesn't require you cutting out your car's original A connector and splicing an aftermarket connector that matches the input of the AVIC N3 then you should be fine.
That said, I always assumed those fancy $799 to $1499 AVIC units already came with bluetooth?
Old 11-19-2009, 03:26 PM   #16
FlzRider
My Ride: AW 1M
Your DIYs are probably the best I have seen on any forum.
I def. plan on doing this to my car. I just recently installed a Motorola BT kit into my sister's MINI and also saw the adapter cables being sold online but I opted for a simple install without the radio integration.
I'm still trying to find a Homelink/Compass mirror on ebay like you have on your car. I see you also have the regular Homelink module as well, how many garages do you open?! lol
Also, does the phone have to be voice-command capable? My 1st-gen iPhone doesn't have any voice command capabilities and I'm wondering if that means it will or will not work?
FlzRider is offline   Reply With Quote
Old 11-19-2009, 03:44 PM   #17
tha ridla
My Ride: '03 325i
Originally Posted by delmarco View Post
Good Question.
On paper;
It should work if
AWESOME... want to make a DIY?
Old 11-19-2009, 04:04 PM   #18
delmarco
Thanks Gainsville,
Yeah it will work SYCE46 figured it out see below.
Originally Posted by sycE46 View Post
Voice Dialing DOES work with the iPhone! I just tested it out. It actually uses the iPhone's voice control. You press the speech / phone button and it'll activate the iPhone's voice control.
You don't need to program the CK3000's voice commands / keywords or do a data push.
My Homelink cheat sheet;
I use everyone of them there buttons...lol
Old 11-20-2009, 03:57 AM   #19
FlzRider
My Ride: AW 1M
I just realized this wont work for iPhone users UNLESS your iPhone is a 3GS. The 3GS is the only iPhone with voice dialing capabilities.
Old 11-20-2009, 02:02 PM   #20
nhs99v
My Ride: 330ci
Quick Question
First off - brilliant post! I am definitely going to follow this!
However, I don't have the CD player in the dash, I have the tape deck as there is an autochanger in the boot.
Please tell me that this will work with that as it is too good to be true if it does! I have read some very complicated posts about how you can get the phone controls activated in the steering wheel and all very very expensive!
Thanks again!
nhs99v is offline   Reply With Quote
Rate This Thread
