Old 12-02-2009, 04:23 PM   #1
-z0sick-
My Ride: z06
Secondary Air Pump Check Valve Removal Help
Hi,
So my car is throwing codes P1421 & P1423 (Secondary Airflow).
I did the usual troubleshooting of looking at the air pump, vacuum hoses, etc and everything seems to be ok.
The last thing to check is the check valve. I'd like to remove it and clean it out with some solvent but am having a tough time reaching the bolts.
Does anyone have some tips/advice on how to reach and remove the two bolts that secures the check valve to the exhaust port?
http://forum.e46fanatics.com/attachm...7&d=1195419895
-z0sick- is offline   Reply With Quote
Old 12-02-2009, 05:46 PM   #2
325adam
My Ride: 02 330i
You can try checking fuse #36 to see if its blown. That is $2.50 fix.
325adam is offline   Reply With Quote
Old 12-02-2009, 05:55 PM   #3
-z0sick-
My Ride: z06
Thanks for the tip but I don't thinks it's the fuse since I can hear the Air Pump turn on and run on cold starts.
Old 12-02-2009, 06:20 PM   #4
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
Mine was a bad relay... it's behind your glove box. I checked and checked over everything constantly and all was working, after clearing the codes over and over at Advance Auto I was able to diagnose it thru trial and error. Sometimes the system would be fine, other times the light would trigger, all times I would hear the air pump kick on. Ultimately it was the relay which occasionally delayed the start of the system which triggered the light. It's a $13 OEM part. After I took my old one out I took it apart by removing the cover and sure enough the contact point inside was charred.
To answer you question though, theres just two bolts/nuts that hold it on, but removing it my require a new gasket. Try using a U-joint. Should be straight forward though. Take the hose off and feel in there for blockage with the motor OFF. Then on a cold morning when it kicks open at first start (verify it's doing this), shoot a little throttle body cleaner or seafoam in it then hook the pump hose back up to blow it thru the ports. I did that but it didn't fix anything.
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is online now   Reply With Quote
Old 12-02-2009, 07:16 PM   #5
-z0sick-
My Ride: z06
Ok thanks guys, I will check the relay...I think I saw a post showing where it's located somewhere on the forum. Will keep you posted. Thanks again.
Old 12-02-2009, 08:09 PM   #6
ThatGuy_JZ
No prob, it's the Salmon colored one behind the glove box. You have to take the glove box out to get to it.
Old 12-03-2009, 11:20 AM   #7
nvoges
My Ride: 01 325i
Does anyone have a part number for the secondary air injection pump? I tried finding it on RealOem but haven't had any luck locating it.
nvoges is offline   Reply With Quote
Old 12-13-2009, 04:38 PM   #8
sbuoncri
My Ride: 325it TS1, e30
I have one extra for you if you want it. it'll be 25 shipped.
sbuoncri is offline   Reply With Quote
Old 12-13-2009, 04:39 PM   #9
sbuoncri
I have an article for you too if you need it. give me your email address. It talks about all of the secondary air pump stuff and how to diagnose the exact problem.
Old 02-16-2010, 03:24 AM   #10
Sshark
My Ride: 328i and Z3
Any chance you can remember the part number of that relay?
Sshark is offline   Reply With Quote
Old 03-04-2010, 03:00 PM   #11
nhbmwguy
My Ride: 2002 325xi C/P/S
Genuine BMW 5-Prong salmon red changer relay for air injection system.
BMW Part Number: 12631742690 / 12-63-1-742-690
nhbmwguy is offline   Reply With Quote
Old 03-04-2010, 05:00 PM   #12
xi_ter
My Ride: 2003 325xi
Instead of removing the valve, use the blowing power of the Secondary air pump to blow Seafoam solvent through the valve and into the exhaust ports.
To clear this carbon, pour Seafoam into the hose from secondary air pump to the valve and engine port before the cold engine is started in the morning.
The hose will hold just over an ounce of Seafoam. Reconnect the hose and run the car 5 seconds so the air pump blows the Seafoam into the exhaust port. Repeat this fill and restart 3 more times only running the engine 5 seconds so the secondary air pump runs for the 3 fills.
Then let the engine sit 15 minutes and warm up the car. There will be significant amounts of Seafoam carbon burnoff in the form of white smoke. The carbon burnoff will clean exhaust areas in the path to the O2 sensors that measure secondary air flow.
Since doing this using a couple of cans over a few months, the CELs have gone away and the engine feels smoother.
Old 03-05-2010, 08:24 AM   #13
nhbmwguy
I did this last night and it worked just as you described. I only used about 1-2 ounces the first try.
The amount of smoke it produces is amazing.
Old 03-17-2010, 10:14 AM   #14
GA2002325
My Ride: 2002 - 325I
Does running SeaFoam do any harm to the O2 sensors?
Will this help, I am getting a P0492 code (Secondary air sytem - bank 2)?
GA2002325 is offline   Reply With Quote
Old 03-17-2010, 01:22 PM   #15
xi_ter
My Ride: 2003 325xi
Seafoam has never hurt my O2 sensors. Filling the tube with Seafoam as above will clear the secondary air passages and in my case corrected the low secondary air flow code.
Listen for the secondary air pump hum at start up and inspect the hose. If it doesn't fill up after you've poured 1 1/2 oz of Seafoam there might be a leak in the hose.
Old 03-19-2010, 02:33 PM   #16
catso
My Ride: 2000 323i 1988 528e
Mine had the P1421 and P1423 codes and it was a leak in the air pump vaccuum line right below cylinder #3. I repaired the plastic vaccum line with rubber vaccuum hose, cleared the codes and they didn't come back.
catso is offline   Reply With Quote
Old 03-19-2010, 05:21 PM   #17
Sshark
Any chance you took any pic of which vaccum line exactly?
Old 03-22-2010, 08:06 PM   #18
Bright Red
My Ride: 330Ci's
Seafoam in pump for me tonight, results tbd!
Bright Red is offline   Reply With Quote
Old 03-29-2010, 11:55 AM   #19
GA2002325
I did have a hole in the secondary pump hose to valve about six months ago. It threw a CEL and I replaced the hose. Now I keep getting CEL for this and bank2 low flow indicated. (I am using a peake reader for codes)
I will give the seafoam a try.
About how long does it take for the smoke to burn off?
I have also noticed the pump sounds like a mini turbine engine (high pitch whine) when it is running lately, is this from the low flow or is the pump going bad?
Brian
Newnan, GA
Old 03-29-2010, 01:28 PM   #20
xi_ter
My Ride: 2003 325xi
5 Minutes
The pump whines for about 2 minutes at start. If there is back pressure the pump would meet resistance and would be louder. The pump is like a leaf blower so the fact it turns on and powers off after 2 minutes means the system is working mechanically. Build up of carbon will cause a code if the O2 sensor is not measuring enough flow about 2 minutes after start up.
