Old 12-23-2009, 01:32 PM   #1
Papi325i
My Ride: 2004 330ci
Second coolant top-off in three months - Problem?
Hey everyone,
Quick question. I just topped off my coolant for the second time in three months. Should I be worried about this? I park in a garage and can't see any obvious leaks. Seemed a bit fast to me. Hope everyone has a great holiday.
Rudy
04 330ci
83k miles
So. California
Most recent service: Oil change in Oct.
Papi325i is offline   Reply With Quote
Old 12-23-2009, 01:38 PM   #2
eurodurance
My Ride: '03 330is, '87 535is
Send a message via MSN to eurodurance
How much coolant was missing each time?
- Augustus the 2003 BMW 330i
- Rachel the 1987 BMW 535is
eurodurance is offline   Reply With Quote
Old 12-23-2009, 01:48 PM   #3
GoingNuts
Just Nuts
My Ride: 2004 330Ci
Aggressive topping off will get you an exploding tank.
GoingNuts is offline   Reply With Quote
Old 12-23-2009, 01:48 PM   #4
Papi325i
My Ride: 2004 330ci
At most a quart each time, probably a little less. Both times the light would come on then go off; I filled each time to the max indicated by the floater.
Old 12-23-2009, 01:50 PM   #5
GoingNuts
Just Nuts
My Ride: 2004 330Ci
Then you have a leak.
Old 12-23-2009, 01:51 PM   #6
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
after topping off, start car, let warm up to op temp, and check for leaks again...expansion tank is oft. cited source of first leak...most say it never just goes catastrophically stranding you, but it certainly has happened to some.
Cooling system is closed and pressurized so the loss of coolant is certainly something to concern yourself with...unless you don't mind spending thousands for new head gasket ($1200-1500) or cylinder head (another $1000?) or engine ($$$$)
D
Old 12-23-2009, 01:57 PM   #7
Papi325i
My Ride: 2004 330ci
Perfect. Hopefully my CPO warranty will cover it. Thanks guys.
Old 12-24-2009, 12:43 PM   #8
dave330i
My Ride: 2001 330i steel blue
Same issues for me...but I cannot find a leak, no cream in the oil either...I believe it is the tank though..will change it...rock auto has it for like $33
2001 330i 5sp Sport package ,steel blue, AA S/C , Remus exhaust, UUC Short shifter, UUC clutch stop, Braided brake lines, UUC Strut bar, Xenons, depo clears, Eagle Eye LED's
dave330i is offline   Reply With Quote
Old 12-24-2009, 12:50 PM   #9
Papi325i
My Ride: 2004 330ci
I found the leak last night. It's the coolant temperature sensor behind the left side of the radiator. Did some research and I have the classic ooze out the sides, and all the dried up coolant on the splash guard underneath. Hopefully that's just it; find out Monday.
Old 12-24-2009, 02:55 PM   #10
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
It's not very good to top these tanks off. The only time I've ever heard of them exploding is when people are having problems/leaks already, start topping off the fluid incorrectly (not saying you did it incorrectly or anything, but most people do) and overpressurizing the system.
Weird that it's leaking from your coolant temp sensor... was it ever removed, or did it just start leaking?
hi its me alec is offline   Reply With Quote
Old 12-24-2009, 03:31 PM   #11
Papi325i
My Ride: 2004 330ci
I've never touched it. But from what others have experienced I think the sensor's o-ring gets brittle and alllows coolant to leak under pressure. All the dried up fluid is right under it. Another one of those 25 cent flaws.
I know what you mean about accidentally topping off too high. Bmw's floater indicator isn't the most user friendly.
Old 12-27-2009, 03:50 PM   #12
Phoenix330ci
My Ride: 04 330Ci Convertible
Yeah, mine did this too. Check my threads. Chased around this coolant problem for some time. Mine never hit the tray though, just steamed out or evaporated before hitting the tray.
After replacing enough parts (all parts not covered under CPO) I asked the dealer to look at it when it went in there for the alternator. Ended up getting a new expansion tank bracke, radiator and thermostat. The only two part now not changed in the entier heating and cooling system, is the water pump and heater core. Everythng else is new. Oh and not one time did I ever see a leak, see anything on the lower pan or find a leak trail.
Phoenix330ci is offline   Reply With Quote
coolant
