Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
#1 |
58mm of Bliss
M54B30 Specs and Measurments
I figured I should start a thread to house the mountain of details I've learned about the M54B30 engine. If anyone has any verified specs that they would like to share, please comment and I'll work towards adding them below. The list will grow shortly....
Combustion Chamber Volume (Head) = 34cc Intake valve size = 33mm Intake valve weight = 45 grams Exhaust valve size = 30.5mm Exhaust valve weight = 47 grams Piston size = 84mm Piston weight (w/rings) = 313 grams Piston pin weight = 108 grams Rod + bearing weight = 602 grams My Arrow rod/ CP piston combo weighed 926 grams.... Cylinder Head Flow: Last edited by PEI330Ci; 01-16-2010 at 03:39 AM. |
#2 |
58mm of Bliss
Ever wanted to know what the combustion chamber volume is?
Me too: ![]() ![]() ![]() Adding water: ![]() I ran into a problem trying to get the last bit of water to fit in. The problem? Surface tension. The solution? A bit of Royal Purple "Purple Ice" coolant treatment which has the same effect as a detergent: ![]() Total volume is 34cc. |
#3 |
Very cool !
And good to know. Rob |
#4 |
Are those stock heads? I can't see a lot of material being removed if headwork was done.
#5 |
Just so you know, those head bolts go in the other way.
#6 | |
58mm of Bliss
Where are you thinking material would be removed? I know....I figured it out after a leak-down test.... |
#7 |
Maybe I'm thinking incorrectly, but there is no "quench" area to mill down. I think I may be off with my thinking.
#8 |
58mm of Bliss
#9 |
58mm of Bliss
Which piston has more compression?
#1: ![]() #2: |
#10 |
![]() Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs Turbo Driveability Video Horsepower vs. Torque - updated |
#11 |
Keep it clean
I'm going with 2.
#12 |
#1 looks too beat to have high compression numbers I would think |
#13 |
58mm of Bliss
OEM Piston:
3.7mm down from the deck @ TDC ![]() Ready for CC'ing: ![]() Adding water: ![]() ![]() 17.4cc total volume Last edited by PEI330Ci; 03-10-2010 at 11:24 AM. |
#14 |
58mm of Bliss
CP Piston:
3.7mm down from the deck @ TDC ![]() Ready for CC'ing: ![]() Adding water: ![]() 22.5cc total volume Last edited by PEI330Ci; 03-10-2010 at 11:24 AM. |
#15 |
#16 |
Very interesting ...
330i SMG M-Sport Paket II Euro Spec
Mods: CF Roundels all around, Black grillz, 7000k Angel eyes,6300k HID fog lights, Hamman Lip reps, ACS roof spoiler reps, Alutech front and rear struts, BMC CDA with DIY heatshield, Pro RS braided brake line, ///M Billet Oil Cap, OEM ///M mats, ///M aluminium pedals, ![]() |
#17 |
58mm of Bliss
I've measured this stuff a number of times, and I'm still coming up with the same numbers. So here's what's been bothering me:
Cylinder bore = 3.307" Stroke = 3.528" Combustion chamber volume = 34cc Piston/cylinder volume below deck = 17.4cc Head gasket thickness = 0.030" Head gasket bore = 3.346" Plug all those numbers into a compression ratio calculator and you get 9.911:1. BMW advertises 10.2:1 for the M54B30 The only thing I can guess is that BMW is not including the volume inside the spark plug, and the area above the first piston ring along the cylinder wall. The actual "pour volume" using fluid equals 55.723 inside the combustion chamber with the piston at TDC. Dropping that by just 2cc brings the compression ratio to 10.24:1, which might be the case if you didn't include the spark plug volume ect.... I'm sticking with real world numbers, so the M54B30 in my books is a 9.9:1 engine. The CP pistons I have pictured above netted a compression ratio of 9.26:1 with a "pour volume" of 60.823cc. Using a well known engine calculation software package, I was able to build a "model" of my engine to represent the actual power it made on the dyno. (252hp/229tq) I then changed the compression ratio from 9.26 to 11.4:1 and netted a calculated 265hp/241tq @ 6400 RPM which was closer to what I was expecting when I built the engine. Last edited by PEI330Ci; 03-22-2010 at 06:09 PM. |
#18 |
58mm of Bliss
Adding the custom Schrick cams/valvetrain to the 11.4:1 engine would have theoretically moved the peak power RPM to 7500 RPM netting 317hp/245tq. Clearly a different intake manifold would be needed than the OEM M54B30 piece to achieve these numbers. It's fun to work with the numbers though....
#19 | |
I was getting something close to those numbers, with a 33cc combustion chamber volume. I may have some insight to add tomorrow when I go to the machine shop. I have some printed calculation sheets with some of the numbers that CP uses, such as compressed gasket thickness (I believe .025). Also, aren't your CPs 84.5mm? My cylinder bore was 3.328. I'm guessing you were referring to the measurements for the stock pistons?
#20 | |
58mm of Bliss
I measured used gaskets that had already been compressed, and found them to be 0.030" thick. I have a new gasket at the shop I could measure for reference as well. (I'm amazed how much "new" stuff I still have) Were you measuring the head with the spark plug installed? |
