Thread Tools Search this Thread Rating: Thread Rating: 24 votes, 5.00 average. Display Modes
Old 01-01-2010, 12:21 AM   #1
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
M54B30 Specs and Measurments
I figured I should start a thread to house the mountain of details I've learned about the M54B30 engine. If anyone has any verified specs that they would like to share, please comment and I'll work towards adding them below. The list will grow shortly....
Combustion Chamber Volume (Head) = 34cc
Intake valve size = 33mm
Intake valve weight = 45 grams
Exhaust valve size = 30.5mm
Exhaust valve weight = 47 grams
Piston size = 84mm
Piston weight (w/rings) = 313 grams
Piston pin weight = 108 grams
Rod + bearing weight = 602 grams
My Arrow rod/ CP piston combo weighed 926 grams....
Cylinder Head Flow:
PEI330Ci is online now   Reply With Quote
Old 01-03-2010, 10:13 AM   #2
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Ever wanted to know what the combustion chamber volume is?
Me too:
Adding water:
I ran into a problem trying to get the last bit of water to fit in. The problem? Surface tension. The solution? A bit of Royal Purple "Purple Ice" coolant treatment which has the same effect as a detergent:
Total volume is 34cc.
Old 01-03-2010, 02:58 PM   #3
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Very cool !
And good to know.
Rob
Old 01-03-2010, 03:07 PM   #4
Iceman00
Banned User
My Ride: E90 6MT
Are those stock heads? I can't see a lot of material being removed if headwork was done.
Old 01-03-2010, 03:27 PM   #5
mrshelley
My Ride: 2004 330i
Just so you know, those head bolts go in the other way.
Old 01-03-2010, 04:43 PM   #6
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Yes, it's an OEM head.
Where are you thinking material would be removed?
I know....I figured it out after a leak-down test....
Old 01-03-2010, 05:36 PM   #7
Iceman00
Banned User
My Ride: E90 6MT
Maybe I'm thinking incorrectly, but there is no "quench" area to mill down. I think I may be off with my thinking.
Old 01-03-2010, 06:07 PM   #8
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
That is not something that is normally modified with the head. Normally, if you want to change the quench, you do it in piston design.
Old 03-10-2010, 10:37 AM   #9
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Which piston has more compression?
#1:
#2:
Old 03-10-2010, 10:54 AM   #10
McSpeed
My Ride: 2005 ZHP TT Stg 1
Originally Posted by pei330ci View Post
which piston has more compression?
#1?
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 03-10-2010, 11:50 AM   #11
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
I'm going with 2.
Old 03-10-2010, 12:09 PM   #12
Michel
My Ride: 330ci
#2,
#1 looks too beat to have high compression numbers I would think
Michel is offline   Reply With Quote
Old 03-10-2010, 12:11 PM   #13
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
OEM Piston:
3.7mm down from the deck @ TDC
Ready for CC'ing:
Adding water:
17.4cc total volume
Old 03-10-2010, 12:21 PM   #14
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
CP Piston:
Ready for CC'ing:
Adding water:
22.5cc total volume
Old 03-10-2010, 02:05 PM   #15
McSpeed
#1
Old 03-10-2010, 02:25 PM   #16
B33MER
My Ride: 330i SMG M-Sport
Very interesting ...
330i SMG M-Sport Paket II Euro Spec
Mods:
CF Roundels all around, Black grillz, 7000k Angel eyes,6300k HID fog lights, Hamman Lip reps, ACS roof spoiler reps, Alutech front and rear struts, BMC CDA with DIY heatshield, Pro RS braided brake line, ///M Billet Oil Cap, OEM ///M mats, ///M aluminium pedals,
B33MER is offline   Reply With Quote
Old 03-22-2010, 05:54 PM   #17
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
I've measured this stuff a number of times, and I'm still coming up with the same numbers. So here's what's been bothering me:
Cylinder bore = 3.307"
Stroke = 3.528"
Combustion chamber volume = 34cc
Piston/cylinder volume below deck = 17.4cc
Head gasket thickness = 0.030"
Head gasket bore = 3.346"
Plug all those numbers into a compression ratio calculator and you get 9.911:1.
BMW advertises 10.2:1 for the M54B30
The only thing I can guess is that BMW is not including the volume inside the spark plug, and the area above the first piston ring along the cylinder wall. The actual "pour volume" using fluid equals 55.723 inside the combustion chamber with the piston at TDC. Dropping that by just 2cc brings the compression ratio to 10.24:1, which might be the case if you didn't include the spark plug volume ect....
I'm sticking with real world numbers, so the M54B30 in my books is a 9.9:1 engine.
The CP pistons I have pictured above netted a compression ratio of 9.26:1 with a "pour volume" of 60.823cc.
Using a well known engine calculation software package, I was able to build a "model" of my engine to represent the actual power it made on the dyno. (252hp/229tq)
I then changed the compression ratio from 9.26 to 11.4:1 and netted a calculated 265hp/241tq @ 6400 RPM which was closer to what I was expecting when I built the engine.
Old 03-22-2010, 06:18 PM   #18
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Adding the custom Schrick cams/valvetrain to the 11.4:1 engine would have theoretically moved the peak power RPM to 7500 RPM netting 317hp/245tq. Clearly a different intake manifold would be needed than the OEM M54B30 piece to achieve these numbers. It's fun to work with the numbers though....
Old 03-22-2010, 09:26 PM   #19
///Orient3
My Ride: can't be defined
Stroke = 3.528"
Adam,
I was getting something close to those numbers, with a 33cc combustion chamber volume. I may have some insight to add tomorrow when I go to the machine shop. I have some printed calculation sheets with some of the numbers that CP uses, such as compressed gasket thickness (I believe .025). Also, aren't your CPs 84.5mm? My cylinder bore was 3.328. I'm guessing you were referring to the measurements for the stock pistons?
[url=http://photos.e46fanatics.com/showphoto.php/photo/90077]
///Orient3 is offline   Reply With Quote
Old 03-23-2010, 06:59 AM   #20
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Originally Posted by ///Orient3 View Post
Adam,
For the OEM calcs, I used 84mm bore.
I measured used gaskets that had already been compressed, and found them to be 0.030" thick. I have a new gasket at the shop I could measure for reference as well. (I'm amazed how much "new" stuff I still have)
Were you measuring the head with the spark plug installed?
