Old 12-12-2009, 07:47 PM   #1
oofie
My Ride: 07 Fit
Send a message via AIM to oofie
Autocross...help
So my brother and I need new tires for his Z4 that we autocross. We have Falken Azenis right now but they're almost slicks right now. We're looking for some suggestions.
1) We have 235/40/17 right now on all four corners, will 245s or 255s help increase handling? Is it worth it to go from 235 to 245 or just go straight to 255s?
2) We're looking to get the Dunlop Direzza Z1 Star Specs. Is there anything else we should consider in that price range (about $140-160 per tire). How about the Kumho Ecsta XS? They're a bit cheaper than the Direzza, but since we're using this set strictly for autocross, we don't really mind spending if we're to get better tires.
Any help is greatly appreciated
oofie is offline   Reply With Quote
Old 12-13-2009, 01:53 AM   #2
e46techtuner
My Ride: 2000 328i
I would get 255s, star specs. Haven't heard much about the xs.
e46techtuner is offline   Reply With Quote
Old 12-13-2009, 02:14 AM   #3
BruceWayne
BruceWayne's Avatar
My Ride: 03 LSB ///M3
255s would be a different diameter and would be changing the ratios, 255/40/17 is too large and 255/35/17 is too small
AST 4200 | Vorshlag camber plates | Power Flex rtab & fcab | AFE stg. 2 | Auto Solutions SSK | Macht Schnell Studs | Stoptech stg. 2
BruceWayne is offline   Reply With Quote
Old 12-13-2009, 02:18 AM   #4
trippinbillies4
trippinbillies4's Avatar
My Ride: '02 Mini, '13 FR-S
Changing the size ratio doesn't matter as long as you don't care if your speedo is off...
I ran RE-11's for a bit on mine, they do well at autox, especially after they're worn down to about 2/32". MY suggestion: get a second set of wheels and some A6's and be done with it. So much more fun!
__________________________________________________
'02 Mini Cooper #40HS, '13 Scion FR-S #40CS, '12 Ducati SF848
trippinbillies4 is offline   Reply With Quote
Old 12-13-2009, 04:05 AM   #5
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I have the Dunlops Z1 SS's. Great tire even in occasional 35 degree weather. They grip pretty well when cold which I think is better for autocross. Only downside is a relatively small selection in sizes.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
bigjae1976 is online now   Reply With Quote
Old 12-13-2009, 10:43 AM   #6
oofie
My Ride: 07 Fit
We're just running with BMW CCA and we'd like to stay in the stock class for now, so no R compounds for us. Are you running R compounds? We'd love those RE-11's but they're just too much for us right now (price wise).
So is 255/40/17 better than 255/35/17? And as trippinbillies4 said, we really don't care about the ratio, the set will be strictly for autocross.
Old 12-13-2009, 01:32 PM   #7
e46techtuner
My Ride: 2000 328i
Some people like using smaller diameter tires/wheels for better acceleration.
I would get 255/40/17. Its your choice though.
1010tires.com and discount tire both have a tire calculators you can use. The difference in diameter is very small.
Old 12-13-2009, 03:33 PM   #8
oofie
My Ride: 07 Fit
Yeah, my brother and I are still debating if we would gain grip by going from 235 to 255. However, we'll probably just get the 255 since it's only about $14 more per tire, might as well try another size other than 235s. Thanks guys!
Old 12-13-2009, 08:36 PM   #9
e46techtuner
My Ride: 2000 328i
you will definitely feel a difference in traction compared to 235s.
Old 12-18-2009, 08:45 PM   #10
trippinbillies4
With an open diff, you might take some of the camber out of the rear. Sounds crazy I know... I took my rear camber down to -1.4, toe'd out the back end 1/8". Makes a huge difference in getting the car to rotate.
Old 12-22-2009, 02:47 PM   #11
murph1379
My Ride: 2006 M3
I'm not sure where someone got the 255/35/17 size, but if someone made one I'd definitely buy that! (but they don't)
255 star specs all around will work well for you.
murph1379 is offline   Reply With Quote
Old 12-30-2009, 09:56 PM   #12
M3it
My Ride: '02M3,325it,330Ci
+1, Murph knows what he is talking about!
I ran Dunlops in the same 6 cyl stock group as your Z4 in SD, and was faster than the M cars.
Rick
Dunlop Tires / GreenFilter / ChaseCam in car video / Bilstein shocks / Enkei wheels
M3it is offline   Reply With Quote
Old 01-06-2010, 06:20 PM   #13
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
255 17s ftw. Check out the NT05 as well...
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 01-06-2010, 06:21 PM   #14
Activ3
What I also had to do was run 550lb rear springs with soft progressive ones up front. You can almost dial in off-throttle oversteer so that you can power on early to keep her straight.
