Old 01-06-2010, 10:10 PM   #1
AMCINK
My Ride: 2000 323CI
Those window wise men please answer this
My driver side window rolls up and down ok; however it does not do the up and down motion when you close or open the door. What could it be?
I've been told that the sensor to do this might be inside the actuator therefore a whole actuator swap or could I repair the existing one
AMCINK is offline   Reply With Quote
Old 01-06-2010, 10:16 PM   #2
ProchaineStation
My Ride: 03 Corolla
Send a message via MSN to ProchaineStation
so how do you do it.
Halfway
Next Stop: ProchaineStation™
www.youtube.com/AntoDamicoShow
ProchaineStation is offline   Reply With Quote
Old 01-06-2010, 10:31 PM   #3
AMCINK
My Ride: 2000 323CI
roll the window all the way up and then carefully guide the window with your left hand under the door trim and close it.
by the way I also have the stuck door syndrome - will this also tell me that the actuator needs to be replace???
Old 01-07-2010, 11:19 AM   #4
AMCINK
My Ride: 2000 323CI
anyone?????
Old 01-07-2010, 01:29 PM   #5
MysticBlau330Ci
My Ride: 330Ci '04 & M4 2016
when your door is open do you get a door open symbol on your dash?
MysticBlau330Ci is offline   Reply With Quote
Old 01-07-2010, 02:51 PM   #6
AMCINK
My Ride: 2000 323CI
^^^^^^^ No!! I'm not getting the open door symbol
Old 01-07-2010, 05:26 PM   #7
MysticBlau330Ci
if there is no 'open door' indicator on when the other door/trunk is open I think your General Module is acting up and may need to be reset. Try disconnecting the battery for a few minutes and see if that works. If you do get a 'door open' indicator in the other door then looks like your sensor is bad. Try the battery disconnect for that too.
Old 01-07-2010, 05:29 PM   #8
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: Project 330xi
I had this same problem on occasion years ago and as bizarre as it sounds, a new lock cylinder in the door fixed the problem. Now my lock cylinder completely failed which is why I had it replaced, but it also in turn fixed my window issues.
-Gary
DiscoStu is offline   Reply With Quote
Old 01-07-2010, 06:22 PM   #9
scottjoh
My Ride: '99 323i & '02 540i
I really doubt it is the General Module that would cause the lack of door open indicator. More likely the door lock actuator as that is where the sensor is for door ajar or the wiring between the door and the chassis. Unless there were a whole bunch of things acting funny I would not suspect the GM. The GM is solid expect for the door lock relays of course.
scottjoh is offline   Reply With Quote
Old 01-07-2010, 06:24 PM   #10
scottjoh
Please explain what stuck door syndrome is.
Old 01-07-2010, 06:25 PM   #11
Define ///M3
My Ride: E92
this is going on in the other bimmer. im curious
Define M3
tiag 2000 323ci - sold
BSM 2004 325ci - sold
AW 2013 328i - sold
MWM 2012 e92 328i - current
Looking 4 e46 M3
Define ///M3 is offline   Reply With Quote
Old 01-07-2010, 07:11 PM   #12
AMCINK
My Ride: 2000 323CI
The "stuck door syndrome" is when you try to open the door and pull the handle and the door does not open on the first try; you then need to pull it again sometime several times (with more induced force) to actually open the door.
Old 01-07-2010, 07:24 PM   #13
MysticBlau330Ci
Yeah, my post was a little 'off'. What I meant was if ALL doors and trunk etc do not show open then it MAY be the GM which I too doubt. If it's just the one door then yes, more likely actuator/sensor or wiring. I would still try the 'battery' reset first.
Old 01-07-2010, 07:28 PM   #14
skang330
My Ride: 2005 E46 330ci
Send a message via AIM to skang330
oh no this happens to me sometime
skang330 is offline   Reply With Quote
Old 01-07-2010, 07:35 PM   #15
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Um, I hope this 'stuck door' syndrome isn't just that the door is locked, meaning that the first pull shouldn't open the door...the second pull should.
Also, I thought that you could have a permanent setting where the door locks whenever you go above a certain speed (like you can set the car to have day time lights on or not). Anyway, I hope this 'issue' isn't mistakenly thought of as a glitch, when it's not.
That said, if it is repeated tries to open the door, that certainly is an issue.
Also, in my 16 years with BMWs, I've got to say the the 'disconnect the battery for 10 mins.' idea has saved me many times for a variety of electrical gremlins...hope it's a simple as that for you OP!
Doug
Old 01-07-2010, 07:54 PM   #16
York
My Ride: 01 330Ci
Of course I can't find it right now, but I saw in another thread that the up/down feature is controlled by the door lock actuator.
Here's one talking about weather causing the issue:
http://forum.e46fanatics.com/showthr...p+down+feature
330Ci
York is offline   Reply With Quote
Old 01-07-2010, 08:45 PM   #17
blk04zhpcpe
My Ride: 2004 330ci zhp coupe
if the "up and down thing" you're referring to is the slight drop in the window's height before the door opens or the slight rise in the window's height after the door is closed, i have had each window take its' turn losing this functionality. each time, i reset the offending window by rolling it down all the way, then immediately rolling it back up all the way but continued to hold the window switch in the rollup position an additional 20 seconds or so after it had reached full travel. this was successful each time. it seems to memorize the end stop. i got this tip from a similar thread on this forum some months ago.
blk04zhpcpe is offline   Reply With Quote
Old 01-08-2010, 11:27 AM   #18
AMCINK
My Ride: 2000 323CI
Yea! I have try this method but I hold the button down for only 10 seconds I will try the 20 seconds rule adn report back
Old 01-09-2010, 01:44 PM   #19
York
My Ride: 01 330Ci
My heck, I think this works? I just popped out the overhead panel to prep my Homelink install. I used the passenger door and when I closed it, the window did not move up the last bit. I opened and close it a few times with no luck. So, I sat inside with the door closed, lowered the window all the way and then raised it all the way and held the window switch for an extra 10 seconds (second try would have been 20 seconds) and the window now works as before. I'll watch the door to see if this fix lasts. Sweet!
330Ci
Old 02-17-2010, 10:30 PM   #20
warrior9504
My Ride: 330ci
Hey AMCINK,
did you ever fix your problem? I am having the exact problem with my 01 330ci.
warrior9504 is offline   Reply With Quote
