Old 01-13-2010, 09:29 PM   #41
Iceman00
Banned User
My Ride: E90 6MT
Elaborate on this for me. What is with the duration on those cams.
Old 01-13-2010, 11:11 PM   #42
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Do the math with the #s I provided, you'll see....
Old 01-13-2010, 11:15 PM   #43
djnekkon
My Ride: MB3ci & z33 HR
where was I? good thread
Old 01-15-2010, 12:16 PM   #44
Iceman00
Banned User
My Ride: E90 6MT
I see what appears to be a lot of duration. I'll try to decipher this, but it's not my strong point.
Old 01-16-2010, 12:01 AM   #45
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Intake cam at idle
Open: 18.2944 deg after TDC
Close: 54.8870 deg after BDC
Cam lobe centerline versus TDC: +126 deg
Intake cam advanced
Open: 21.7056 deg before TDC
Close: 14.8870 deg after BDC
Cam lobe centerline versus TDC: +86 deg
TDC to BDC is 180 degrees
Old 01-18-2010, 08:52 AM   #46
NightRunner
My Ride: Slowmobile
duration is a constant 216.5926* (@ .050)
That's really not much (at least what I'm used to).....weird.
NightRunner is offline   Reply With Quote
Old 01-18-2010, 05:07 PM   #47
Iceman00
Banned User
My Ride: E90 6MT
How did you figure that one? There has to be something I'm missing here...
Old 01-18-2010, 05:41 PM   #48
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Bingo!!!
And this makes the power that BMWs make that much more impressive.
I find it helped me in the beginning to look at a "cam card" from one of the big name cam companies. This is one of the best websites I've found out there for easy to understand info on cams:
http://harveycrane.com/
Old 01-19-2010, 07:11 PM   #49
derek0606
My Ride: 01 330CI Orient
Jesus! That's terrible but glad to see he is still around for us pups!
derek0606 is offline   Reply With Quote
Old 01-26-2010, 03:34 PM   #50
Iceman00
Banned User
My Ride: E90 6MT
Bingo!!!
I've seen the cams cards before, crower would send them out with a set of cams to help you degree them.
Old 02-23-2010, 11:44 AM   #51
95blkmax
My Ride: 00 BMW 328i
Send a message via AIM to 95blkmax
The TMS dyno plot.
I did 156 pulls on the dyno in 2009, all with 264/248 Schrick cams.
....and I've got all the cam specs anyone could want about those cams.
I look forward to reading about the testing with your car.
Just to update this thread since I never posted up my baseline dyno...
In this thread, http://forum.e46fanatics.com/showthread.php?t=735323, I posted my baseline and post-header dyno.
When I went to dyno after the headers I bought a new thumb drive and got my baseline dyno as well.
Hi, my name is 95BlkMax, and I am a Boostaholic
"DANGER TO MANIFOLD!!!!" O_o!
95blkmax is offline   Reply With Quote
Old 02-23-2010, 01:52 PM   #52
McSpeed
My Ride: 2005 ZHP TT Stg 1
Subscribed.
Tune-wise you might want to talk to NickG - especially if you're going turbo down the road. His shop's in Pompano Beach - nickg@techniquetuning.com
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 02-24-2010, 01:20 PM   #53
95blkmax
Originally Posted by McSpeed View Post
Subscribed.
Thanks! I will contact him in due time.
Guys here's something new, next month I will be taking the plunge (for the better of E46Fanatics! jaja) and I will try to get an Apexi SAFC-II to work on my car.
I dont see why people here have not tried it before (I searched and no one seems to have used one, maybe because most are just scared to do some mild cutting into their DME harness, or that it does not work, but since no one has posted a thread mentioning it, I'll try it out).
My goal here is not to squeeze every possible HP from my engine with an AFC, after all, this will only take care of air/fuel tuning. But given how much richer my engine is running after the headers, Im sure I'll see a benefit from a/f tuning alone. On the richest spot which for my was 6000rpm, stock was at 12.92:1, with headers it was 12.05:1. There would be a few horses to be had there by just taking it up in the 13.1-13.3:1 range. I would have to sit on the dyno for some time to really see what a/f this engine likes best.
The dyno here shows the best baseline run Vs 2 of my headers dyno runs. I blew up the air/fuel box to get a closer look at the change...
This is of course wishful thinking; I still need to see if the AFC can work on my car. I do not see why it would not. AFCs are super easy to work, and require very little input. I know some folks on bimmerforums.com with M54s had problems getting it to work simply because they could not get a clean Throttle % signal, but on my M52TU it SHOULD not be a problem given that I have a cable-operated TB. Also people often have had problems getting piggybacks to work with the ignition system (and fuel system for the injectors); that would not be the case with an AFC because they tune by modifying the MAF signal before it reaches the DME, so as far as the DME is concerned, the AFC does not exist.
Anyways, here are my questions...
- Does anyone here have the M52TU DME's wiring diagram and pinout? I would need to identify a few cables to make it work... DME 12v Power, DME Ground, Throttle Position, MassAirFlow Signal... that's all I'd need
- Ebay has those Repair Manual CDs, are those worth the $10 or should I just dish out the $ for an actual Bentley CD? This way I can just get this information myself
Thank you guys in advance! Hopefully someone out there can steer me the right direction.
Old 02-26-2010, 11:30 PM   #54
95blkmax
bump to the top :-p
Old 02-27-2010, 04:52 AM   #55
Iceman00
Banned User
My Ride: E90 6MT
SAFC's do add to ignition timing(not user controlled), be careful, and good luck.
Old 02-27-2010, 04:53 AM   #56
Iceman00
Banned User
My Ride: E90 6MT
Look into a B30 manifold, that will give you a good boost in power too.
Old 02-27-2010, 10:52 AM   #57
95blkmax
Yea I know, I just didnt want to get into a technical convo regarding that here when the majority of people here are scared of anything other than a plug-n-play tuning medium (like a SharkInjector lol). On my 3.5 swap I had actually upped to fuel pressure to a constant 55psi in order to do more correction via the AFC (I remember at 4500 I was already at about -27% IIRC). Running an OBD2 scanner program, I saw gains of ignition timing around that RPM of just about 5-6*. So yes Im aware of this indirect timing changes that can happen with tuning via MAF. . Im sure this engine could use some of it as well.
One step at a time, but maybe around summer time I'll be doing this. Right now I need to upgrade my phone/plan, gym membership, and also starting to save up for tuition, as I'll be getting back into school this summer .
Do you happen to have a before and after dyno comparison of this swap on your car? Just wondering.
Thnx!
Old 02-27-2010, 12:29 PM   #58
Iceman00
Banned User
My Ride: E90 6MT
Thnx!
Phones are overrated, you can get special gym membership rates if you go to the Y, and are a student. I understand school is important, because I'm a student too, awesome to see your priorities are in check.
No before and after dyno yet, but I'm working on that.
