E46 Xi Forum
Old 01-16-2010, 11:05 AM   #1
aioros
My Ride: 2001 330xi auto
Exclamation I need help Xi owners CA bushings
I'm changing the control arms ball joints and bushings on my 330Xi. The BJ on this car come separate from the CA. I used the BJ tool and the 3-jaw puller from harbor freight to remove the BJ and the bushing. My question is:
How do I press the bushing back into the CA?
BTW I plan to go pay a mechanic to press in-out the bushings .
aioros is offline   Reply With Quote
Old 01-16-2010, 11:10 AM   #2
Mclovin1458
My Ride: 2005 325ci, zsp/zpp
Yea u grease it and push it back onto the CA
Mclovin1458 is offline   Reply With Quote
Old 01-16-2010, 11:14 AM   #3
aioros
Is it that easy, just by hand?
Old 01-16-2010, 11:18 AM   #4
Mclovin1458
Hmm never done it myself but maybe knock it back on with a mullet maybe.. someone correct me if im wrong.
watch this video
Old 01-16-2010, 01:10 PM   #5
olinjohnston
My Ride: Dakar330Xi + 840 6MT
Send a message via AIM to olinjohnston
Mullet:
Mallet:
olinjohnston is offline   Reply With Quote
Old 01-16-2010, 01:28 PM   #6
xi_ter
My Ride: 2003 325xi
Put soapy water on the bushing and press in using
Old 01-16-2010, 03:03 PM   #7
BadBoostedBmwM3
My Ride: 323i & e36 Turbo M3
Not to steal your thread, OP. But, the dealer says my outer, passenger-side, ball joint on my 2002 330xi needs to be replaced. Do I have to buy the entire new control arm or can I just buy the ball joint??
This is my signature....
BadBoostedBmwM3 is offline   Reply With Quote
Old 01-16-2010, 03:08 PM   #8
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
yes they are incorporated into the CA. do your bushing and inner ball joints and sway bar endlinks while you are at it.
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 01-16-2010, 03:10 PM   #9
BadBoostedBmwM3
I was thinking that...
Yea, I figured I might as well do the inner ones too. Should I replace the tire rods as well??
Old 01-16-2010, 03:13 PM   #10
ABOC
My Ride: 330xi,Blazer,K100RS
Just curious, how did you know they were going bad and needed to be replaced? I think its time for mine, getting a funny, yet ugly sound from the front end. Possible mine need to be changed too, what do mechanics typically charge for this?
ABOC is offline   Reply With Quote
Old 01-16-2010, 04:03 PM   #11
aioros
get a pry bar and pull push the CA side to side, back and forward, you will see a lot of movement. plus mine were torn
Old 01-16-2010, 07:20 PM   #12
CirrusSR22
My Ride: E36 318ti, E46 323it
You need to lubricate it with something that dries. I invested in a quart of P-80 Emulsion which is a specific temporary lubricant for assembly of plastic and rubber components. It was about $15 (ebay) for the quart but will probably last me 10 years since so little is needed.
As was mentioned before, many people have had luck with soapy water. Something called "Circolight" is what BMW lists as a temporary rubber lubricant.
CirrusSR22 is offline   Reply With Quote
Old 01-16-2010, 07:41 PM   #13
aioros
DONE!!! I'm done, I just finished installing the inner ball joints and bushings. i used a 5Lb hammer to make the bushings go in. Does anybody knows what are the torque specs for the inner ball joints? Do they pop as when you take them out?
