The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 18 votes, 5.00 average.
Old 02-07-2010, 02:22 PM   #1001
Boosted_ZHP
My Ride: 88 325
Send a message via AIM to Boosted_ZHP
Im just waiting on parts to come in.
Still to come in are tie rod ends, temp switch, SS components, spark plugs, and a few other things.
Removing the rack
Out
I also finished modifing the kuckle but my batteries died. Ill have pics in the next update.
Boosted_ZHP is offline   Reply With Quote
Old 02-10-2010, 12:59 AM   #1002
Boosted_ZHP
My Ride: 88 325
I got a little bit of work done today, but the damn CSB was hardto remove so I need to get a bearing puller. The rain poured on me while removing the oil pan, so I had to call it quits.
I got a few parts in today. The SS kit, and temp guage are the main things.
Removing the Water pump, T stat, and belts
Off
New ones on
A/C belt on
I found this cracked so I need to buy a new one tomorow
Old Temp guage
New temo guage installed
Note stock e36 shifter to z4 3.0 shifter
Installing the parts
Removing Traction Control
One of my biggest fears when starting this was losing track of tubes and wires.
Does anyone know where this one goes?
Ends here
Starts here
And this one on the e36
I almost got the pan off before it started to pour. This was the last pic I could take
Thanks.
Old 02-10-2010, 09:40 PM   #1003
Boosted_ZHP
My Ride: 88 325
Today I got in the new pulley and tie rod end.
I also rented a bearing puller to get that damn CSB off.
Pics of the process
Off
New one on
A/C belt, and WP pulley on
Now on to the e34 oil pan
With the pan off this was the best time to deal with the oil pump nut
Nut off
New nut Thread locked on, and the threading messed up
e34 oil pick up tube
Sanded the pan and block to clean it off
Copper gasket applied
Pan on
Belt on
Dip stick installed.
Thats it for today.
Old 02-10-2010, 10:55 PM   #1004
cchrisstopherr
My Ride: W126 300ce
nice to see you started on the engine!
reminds me when i brought back to "life" my car
cchrisstopherr is offline   Reply With Quote
Old 02-11-2010, 05:31 AM   #1005
ClubSport3er
My Ride: E82
Can't wait to see more improvments. Specially E30 is waiting outside for warmer days and I havent decided yet wich way I will go with her.
ClubSport3er is offline   Reply With Quote
Old 02-11-2010, 11:03 AM   #1006
BMWLOVE100
Banned
My Ride: 1984 m3
great job on your E30
BMWLOVE100 is offline   Reply With Quote
Old 02-11-2010, 11:57 PM   #1007
Boosted_ZHP
My Ride: 88 325
Thanks, and thank you for following this from the begining.
Good memories, huh?
Thanks, go crazy and dont look back
Thank you
Old 02-11-2010, 11:57 PM   #1008
Boosted_ZHP
My Ride: 88 325
Today I got a little bit of work done. I got the CABs off but have no pics of that. I also got the headers installed.
Stock
Removed
Test fit
Mounted
I noticed that I would hit the heat sheild on the mount
That had to go
It was still close, so there were spots that I had to smooth out
Done
Thats all today
Old 02-12-2010, 08:24 AM   #1009
rrgoo7
My Ride: E92 M3
Great Progress!!! How long before you think she'll be up and running again?
rrgoo7 is offline   Reply With Quote
Old 02-12-2010, 11:08 AM   #1010
lsmkr01
My Ride: 04 330i ZHP, 89 325i
Nice progress...makes me miss my e30. Car was wayy easier to work on than my e46.
lsmkr01 is offline   Reply With Quote
Old 02-18-2010, 02:08 AM   #1011
Boosted_ZHP
My Ride: 88 325
Thanks Randy. Soon, I just have to drop it in then do the wiring. I am not working on it but a few hours here and there, so in the next week or two.
Thanks, yes it is, lol.
Old 02-18-2010, 02:09 AM   #1012
Boosted_ZHP
My Ride: 88 325
I got a little bit of work done the past few days.
I took off the valve cover to refinish it.
Off
Taking off the gunk
Process
Then I found this.
I need to get that welded up real quick. It was a crack that was filled with JB weld.
I also worked on the front end
New tierod
Installed
Removing the control arm
Old one out
Compare
Process
Installed
Now on to the e36 steering rack
Tie rods on.
Installed
Removing the driveshaft
Taking off the cover
CSB
CSB unbolted
Taken out
I missed a gasket on the oil pickup tube before so I had to remove the pan again
Off
Cleaning the old gasket
Gasket on the pickup
Pickup mounted
Cleaning the block
New gasket on
All done
As soon as the Valve cover is welded up, the motor is ready to drop in.
Old 02-18-2010, 11:40 PM   #1013
2pur2ride
My Ride: E46
Great job so far.
Love the aluminum floor jack too? What brand is it? I want one.
2pur2ride is offline   Reply With Quote
Old 02-18-2010, 11:55 PM   #1014
cchrisstopherr
My Ride: W126 300ce
very cool, nice update!
Old 02-19-2010, 12:06 AM   #1015
SDKmann
My Ride: 01 Cherokee
Originally Posted by 2pur2ride View Post
Great job so far.
That looks a lot like my lighted Harbor Freight jack.
SDKmann is offline   Reply With Quote
Old 02-22-2010, 09:37 AM   #1016
yusufm786
My Ride: 318i
This is probably a basic question, but when you retrofit a E36 motor into an E30, or even the steering rack for that matter, how do you know if it will fit? Are they the same size, do they have the same mountings, will they work optimally when retrofitted, etc?
yusufm786 is offline   Reply With Quote
Old 02-22-2010, 11:08 AM   #1017
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
Lookin good... can't wait to see the motor in
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 02-22-2010, 01:42 PM   #1018
The Chosen One
My Ride: E46
awesome rebuild!
subscribed
The Chosen One is offline   Reply With Quote
Old 02-23-2010, 02:16 AM   #1019
Boosted_ZHP
My Ride: 88 325
Great job so far.
Thank you. It is a Harbor Freight Jack. They have coupons in the back of the car magazines ( automobile, car & driver, motor trend...) I really reccomend it.
Thanks buddy
Yep, I just didnt get the lighted one
These particular swaps have been done so many times that they are tried and true. You could look up all of the info and follow step by step instructions.
Eveything needs to be modified, but imho since everything is put out there to read it is not so bad. Plus the modifications are not too labor intensive. It is more like putting certain parts together.
Thanks, youre next
Originally Posted by The Chosen One View Post
awesome rebuild!
subscribed
Thank you.
Old 02-23-2010, 02:17 AM   #1020
Boosted_ZHP
My Ride: 88 325
I got a little bit of work done the past days.
Since I had modified the stock tranny brace to accept the tilt with the new motor. I had to re weld it back to its stock location.
I also decided to change the Rear main seal, Pilot bearing, and throw out bearing. The clutch has been changed before and is in good condition.
Tranny off
Old RMS out, new one in
I took out the wire harness finally, does anyone know what this harness connects to? It was connected and I could follow it, but I am limited in space right now.
The pilot bearing was too small
The throw out bearing was also wrong, so thats it for today.
Rate This Thread
