Old 01-25-2010, 03:29 PM   #1
agb1976
My Ride: 325i
Replaced rtab's now what?
I had a terrible vibration on the right rear of my e46 sedan. The inside of the tire wore faster than any other part. So I had the car aligned. Vibration still there. Bought a new tire, still there. Replaced the rtab's last week with the powerflex ones. Vibration still there, but maybe a little better. So know I'm thinking wheel bearing. The tire sits in more at the top and out more on the bottom. Any suggestions. Car is 01 325i manual, sub frame has been inspected. Thanks
agb1976 is offline   Reply With Quote
Old 01-25-2010, 03:54 PM   #2
Bert336
My Ride: 330i ZHP 6MT
blown suspension? wheel bearing would make a whining noise as certain speeds, bent wheel?
Bert336 is offline   Reply With Quote
Old 01-25-2010, 05:12 PM   #3
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Did you have the car re-aligned after you installed the RTABs?
Old 01-25-2010, 05:25 PM   #4
agb1976
My Ride: 325i
The wheel was switched with the spare when I had the new tire put on. Haven't realigned the car yet. There is a whine from the rear the faster you go.
Old 01-25-2010, 05:27 PM   #5
firefirefire90
Banned
My Ride: suce ma bite
Send a message via AIM to firefirefire90
get the car realigned, how bad were your Rtabs before?
firefirefire90 is offline   Reply With Quote
Old 01-25-2010, 05:54 PM   #6
TrippinBimmer
My Ride: Just Fast!
New Rear Tires and New Alignment... Also, Check is ur Rear Wheel Bearings are bad or not...
-TrippinBimmer
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 01-26-2010, 09:12 AM   #7
agb1976
My Ride: 325i
Yeah probably have to do the alignment, rtab weren't that bad from what I can tell. What should I look for?
Old 01-27-2010, 10:35 PM   #8
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
Get an alignment, your stock rear camber arm might be bent. The noise sounds like a wheel bearing.
Did the car ever hit a curb on the side that's making noise? I tagged a curb a couple months ago and my wheel bearing went out because of it (in addition to the wheel and rear camber arm bending)
hi its me alec is offline   Reply With Quote
Old 02-12-2010, 02:29 PM   #9
agb1976
My Ride: 325i
Turns out the wheel bearing in the right rear rear was bad. After the car was aligned and after the new rtab, the noise was horribly louder. I had the wheel bearing replaced and now its nice and quiet again.
