Sponsored by The Tire Rack
Old 02-14-2010, 07:25 PM   #1
Clean_3
My Ride: E46
325i sedan, Eibach Pro Springs, 255/30/19 to 255/35/19 ?
Im running Kumho Ecsta SPT 255/30/19's on the rear. I need new rears and I'm thinking of switching to Continental Extreme Contacts DWS size 255/35/19 but Im wondering how much more the sidewall is going to push and how it will affect rubbing? Anybody changed to that size? Anybody have experience with these ties? I really am tired of running such a thin tire (30's) and would like to bump up to (35's) .... please input your .02
TIA
Front is running 235/35/19. I have V710's staggered
Originally Posted by BeRzErKaS View Post
You don't know how to spend a half day without your wife?
Try snooping through her things and finding out where she stashed your ballz...
Clean_3 is offline   Reply With Quote
Old 02-14-2010, 11:01 PM   #2
SpeedDemon
My Ride: E92M3 E46ZHP Golf7R
Don't do it. That is way too far off: http://www.miata.net/garage/tirecalc.html
SpeedDemon is offline   Reply With Quote
Old 02-15-2010, 11:37 AM   #3
Clean_3
My Ride: E46
Thats a pretty cool calculator ..... .5" Im thinking i might be able to pull it off as I currently don't rub unless I have a full car (I barely rub with a full ride). Im also planning to get a lighter box for my sub so that will help in the rear? Opinions? Perhaps pulling/flaring out the fender a bit? My fender is already rolled. Is it a difficult thing to get the fenders pulled or can shops accomplish pretty easily?
Old 02-15-2010, 01:19 PM   #4
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
The 35 series will definitely cause some rubbing issues during compression, full cabin, or going over large bumps. I would recommend staying with the 30.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 02-15-2010, 02:21 PM   #5
Clean_3
My Ride: E46
How much wider is a 265 from a 255?
Old 02-15-2010, 02:36 PM   #6
southpaw
My Ride: E36 M3 and E36 318ti
265
-255
10
Ten millimeters.
-Brandon
239whp/227wtq @2700lbs
southpaw is offline   Reply With Quote
Old 02-15-2010, 02:46 PM   #7
Clean_3
My Ride: E46
Originally Posted by southpaw View Post
265
-255
10
Ten millimeters.
Oh i c lol .. that simple huh
Old 02-16-2010, 12:58 PM   #8
VMRWheels
VMRWheels's Avatar
If you are thinking about running a 265, this size is extremely wide for a Sedan. What widths and offsets are you going to be running?
-Charles@VMRWheels
Old 02-16-2010, 01:14 PM   #9
Don B
My Ride: 325i (RHD)
-Charles@VMRWheels
I'm putting on 265 30 19 on the rear of my sedan next week, the offset is ET45 on the rears, will these be ok?
Don B is offline   Reply With Quote
Old 02-17-2010, 10:51 AM   #10
Don B
My Ride: 325i (RHD)
Anyone? I can order a 255 30 19 for the rear if that gives me more clearance....I'll be running an Eibach pro kit too
Old 02-17-2010, 11:36 AM   #11
Clean_3
My Ride: E46
What tires are you going to get?
255/30/19 Will definitely clear. Ive ran Kumho Ecsta Spt's 255/30/19 and really had no rubbing issues. 265's 30 or 35 will rub however, i'd like to hear about 255/35/19's (+.5") because I'm tempted to run that size. Im ordering today (I have a busted tire) so Im pretty much out of time ...
Old 02-17-2010, 01:11 PM   #12
Don B
My Ride: 325i (RHD)
I'll be running Kumho Ecsta too, so should probably go for 255 30 19...but
won't be going low on the rear at all with the pro kit..
Old 02-17-2010, 01:30 PM   #13
BartenderPlease
My Ride: '03 540i/6 M-Sport
With the right alignment you won't have any issues at all with a 265/30/19 on a Pro-Kit since that drop isn't extreme. ET45 has worked on numerous sedans without rubbing issues, but for some others it has rubbed.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Trim | JL Audio | V1
BartenderPlease is offline   Reply With Quote
Old 02-17-2010, 01:44 PM   #14
Don B
My Ride: 325i (RHD)
Yeah, I think different tyre brands etc have alot to do with it.
I did have 18 x 8 ET35 with 255 35 18 on the rear before and didn't rub at all.
How would the 265 30 19 ET45 compare?
Thanks for the input.
Old 02-17-2010, 02:34 PM   #15
Clean_3
My Ride: E46
I have an Eibach Pro Kit already on. Ive been running the above mentioned Kumho specs on the Pro Kit. going anything bigger on the rear seems like it might rub but at the same time i think its borderline to where I might pull it off with 265's or 35 series 255's
Old 02-17-2010, 02:39 PM   #16
TheRusski
My Ride: gone...
Ur on Eibach Pro...you should be fine
TheRusski is offline   Reply With Quote
Old 02-17-2010, 05:22 PM   #17
Clean_3
My Ride: E46
How about 225/35/19 and 245/35/19 ... Is that a noticeable difference to what it "looks" like now? will it look or be stretched some? or is that still within range for them to look normal? anybody have pics of those sizes on 19's staggered?
edit: found this thread with some info
http://forum.e46fanatics.com/showthr...ight=245+35+19
anybody else have more input? pics?
Old 02-17-2010, 06:28 PM   #18
BartenderPlease
If you run a 225/35/19 for the front, I'd recommend a 245/30/19 for the rear to keep the diameters as close as possible. I personally would stick to a 255/30/19 rear.
Old 02-18-2010, 01:26 PM   #19
VMRWheels
VMRWheels's Avatar
I would recommend you go with the 255 rear. It will allow you more room to work with if you decide to go with other tire manufacturers that have slightly wider tires. If you plan on going with a 255 rear, 235 front would also work.
-Charles@VMRWheels
