Old 02-09-2010, 07:34 PM   #21
jzwu
My Ride: 2005 BMW 330Cic
Sounds like some fuel pump problem
jzwu is offline   Reply With Quote
Old 02-09-2010, 10:13 PM   #22
slickware
My Ride: 323i
lol.
I keep gas in my car, so that's definitely not it.
slickware is offline   Reply With Quote
Old 02-09-2010, 10:15 PM   #23
slickware
My Ride: 323i
I think the pump itself is in good shape.
I was thinking maybe fuel pressure regulator...
Old 02-10-2010, 12:35 PM   #24
slickware
My Ride: 323i
CPS and Serpentine belt arrived today. Figured if I have to take the fan off, I'll put in a new serp belt too. Who knows when it was done last!
Old 02-11-2010, 03:18 PM   #25
slickware
My Ride: 323i
2 CPS sensors and serp belt installed. Wow, what a ***** to find the connector for that intake CPS! It's frigging UNDER EVERYTHING!
Cleared my CEL, gotta go drive it around a bit now and keep my fingers crossed. Should take about 5 minutes before the sucker comes back on
On the bright side, throttle response is back to normal, nice snappy bmw feel.
Old 02-12-2010, 04:15 PM   #26
slickware
My Ride: 323i
50-60 miles on the car since the VANOS repair and the CPS replacement. Still no CEL, although the car did refuse to start today - sits there and cranks like it's still not getting fuel, and then starts.
However, it *didn't* act limp the hard-start, like it usually does.
I'll check for codes in a little bit, even though the CEL is still off.
Any other thoughts?
Old 02-13-2010, 08:52 AM   #27
slickware
My Ride: 323i
Scanned codes with the peake tool: 15/41: Camshaft Position Intake Sensor
WTF. Returning the aftermarket and purchasing the $116 OEM one today I guess.
Old 02-13-2010, 02:16 PM   #28
slickware
My Ride: 323i
OEM sensor installed. Cleared CEL again, time to go drive...
Old 02-13-2010, 04:55 PM   #29
carthageHannial
My Ride: 330CI
Try to reflash the DME, I mean you've replaced pretty much everything on that car ....
I don't beleive hard/hesitant starts have anything to do with the DME, but some of the problems you've mentioned- car stalling when slowing down/breaking to low speed- could be fixed with a reflash. Not sure if you did, but check the spark plugs, take'em out and examine them.
carthageHannial is offline   Reply With Quote
Old 02-13-2010, 07:15 PM   #30
slickware
My Ride: 323i
Engine is now throwing codes for the EXHAUST camshaft sensor! Stupid aftermarket sensors!
I'll have to order a new one and put it in Tuesday.
On the bright side, the car is running fine otherwise.
Carthage - I'll search the forum and look at reflashing the DME. I'm not sure what that means but I am sure I can figure it out with a search
Old 02-15-2010, 07:28 AM   #31
slickware
My Ride: 323i
So I put my old sensor back in, no engine light and no Exhaust Camshaft Sensor code.
NEW code: "EVAP LDP reed switch doesn't open".
How'd that happen? Could the old exhaust CPS be bad and cause that code somehow?
fuel, shitbox, stalling, starting, vanos
