Old 02-20-2010, 09:51 PM   #1
TiG3rBa7m
My Ride: looking
OBX pulleys
hey ppls trying to put on my OBX pulley kit. since the pulleys are alittle big should i go with a bigger belt or is the oem still the right now to go with.
99 323i SOLD!!!!!
91 240sx w/ RB20
TiG3rBa7m is offline   Reply With Quote
Old 02-21-2010, 01:54 AM   #2
khbiesfd
My Ride: 2000 BMW 323ci
Holy cheap junk batman. OBX makes terrible products. Not trying to bash but actually concerned with the well being of your car. They are not balanced and will seriously screw up your engine.
khbiesfd is offline   Reply With Quote
Old 02-21-2010, 08:34 PM   #3
TiG3rBa7m
My Ride: looking
ok lets get someone else here to answer my question... btw i used obx on a number of cars with problem
99 323i SOLD!!!!!
91 240sx w/ RB20
Old 02-21-2010, 08:46 PM   #4
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
yes, you will need a longer belt. I'm surprised they didn't give you one with the pulleys.
SUMMIT POINT WV 1:24:229 SCCA
Old 02-21-2010, 09:37 PM   #5
mrshelley
My Ride: 2004 330i
If you can't get a belt, you can always go to a NAPA and size out a longer one. If you can work with them, you can get three different lengths and try each one on. Once you find the one you like, return the other two. That's what I did since I run a stock water pump pulley but the other two (alt and PS) are larger ones. There was no set belt length but I finally figured it out.
Old 02-21-2010, 10:47 PM   #6
TiG3rBa7m
My Ride: looking
well i got the oem belt back on the car. took alittle more to get it on but i did and it seems to be running fine idk.
99 323i SOLD!!!!!
91 240sx w/ RB20
Old 02-21-2010, 11:07 PM   #7
Rob43
Rob43's Avatar
That very tight belt is putting undo load on all those bearings, yes it fits, but it's to tight.
Give Bimmerworld or Tuner a call, they both will sell you a new belt that was designed for
there pulleys, but should work just fine with yours. I would only run that tight belt for a
very short period of time.
Good luck,
