#1 |
So sometimes you just get tired of the old interior trim. And that means you have to either replace it, paint it, wrap it in CF, or a fabric. Fabric lets you have something that is both unique and has texture.
![]() DISCLAIMER: you fvck up its not on me. Supplies: 3M Super 77 ScotchGuard 1 yard of fabric (2 if you are doing c pillars as well) Tools: Flathead and Phillips screwdriver scissors - sharp and small is nice too. several flat clean surfaces. So first we need to do a test run. TEST RUN: 1. cut a small piece of fabric 2. scotchgaurd it 3. stick it onto something you dont care about 4. let it dry 5. Visual inspection - is anything staining, does the glue make it look wrong, is it bleeding ect..... 6. try water test and the rub test, no pigment should come off on your hand. so if everything is good we can move on to the wrap. STEP A: Scotchgaurd everything 1. place the whole sheet of fabric on the floor or a large table 2. give it 3/4 light coats of gaurd 3. Let it dry STEP B: Wrapping Trim pieces 1. Pull trim pieces 2. wash with soap and water, get all the armor all/finger oil and everything else off the pieces 3. take them to a table with fabric, cut a piece of fabric around the trip piece with plenty of spare room 4. take to a separate clean surface and place the trim, trim side up, spray it with super 77 from about 12 inches with quick strokes(basically same technique as spray paint) 5. take your strip and place it on the glue part 6. VERY IMPORTANT: immediately stretch/rub it smooth. make sure there are no bubble or wrinkles while the glue is still wet. a. this is easy to do on all the pieces except the long curved one in front of the passenger. what you need to do here is cut a large piece and start from the left, go about 3 inches and make a cut from the edge of the fabric to about a centimeter away from the trim piece. this will allow the fabric to "bend" w/o causing bubbles. b. The trick to corners is this. wrap like you would a present. so you get this triangular thing sticking up with fabric stuck to itself. then simply snip it off. that way there is a great perfect corner, but no material sticking up in the back. 7.now that you are all flush and even on the other side, flip the trim piece. 8. fold the fabric over and use the scissors to trim the fabric in such a way that it will only wrap around the edge a little,and doesn't get in the way of the pegs. When wrapping the shifter piece, you will need to cut to the corners of the holes for the switches and scissors. it is important that your wrap as close to the corners as possible to avoid bunching and so the switches fit. 9. spray the backside with super 77 10. wrap the trim around and let it stick to the back of the trim 11. look over your work and rewrap if necessary. 12. reinstall everything in the car and enjoy.
-Maksim DIY: How to Tackle Electronics Projects Need Quality Brakes, Headers, Meyle Products? BimmerBrakes has it! |
#2 |
I don't really like that print, but that's what makes us all different.
Thanks for the DIY. You made it all so simple. Love the disclaimer.
...is rocking a new look! Special thanks to Mr. AWD for the new sig... |
#3 | |
It looks really excellent in person, kind of subdued and classy, but i was at a party last night, and i had to give some chicks a ride back to campus, and i got a few compliments
#4 |
Looks great good job!
Boys Do What They Can, Men Do What They Want
#5 |
#6 |
are you doing your mom's car? jk
good diy |
#7 |
My Ride: Dream 2 B Suprchrgd
haha now you just need curtains and some plush pillows for the back seet and its already more luxurious then my house!
![]() AKA Huggy1989 "I expect to pass through life but once. If, therefore, there can be any kindness I can show, or any good thing I can do to any fellow being, let me do it now, and not defer or neglect it, as I shall not pass this way again."- WP |
#8 |
My Ride: 318I>328I>328I>328CI
whats a good fabric to wrap the trim in everyone has cf so im tired of that look where can i find good fabric that wont bleed and that the pigments wont rub off on your hand?
thanks very good DIY
#9 | ||
![]() ![]() Quote:
![]() what can i say. i is classy. Quote:
then simply spray them and glue them to a milk bottle or some plastic and see how it looks. i cant tell you one fabric will work best, just gotta experiment.
#10 |
My Ride: Hairdressers car
I'm liking your idea, a lot cheaper then replacing the trim, thanks!
My only concern would be that after a while I'd get tired of the look and want to change it up, does the 3M super 77 set up real solid or do you think you could peel off the fabric and use something like WD40, Goo Gone etc to remove the glue residue thus returning the trim to its previously appearance? I might just have to try it on some scrap platic and give it a shot.... |
#11 | |
my suggestion is if you get bored, wrap it in something else, or sand it and spray it.
#12 |
Tell me you're only kidding! What's next? Dingle balls and a furry kitty in the back window? Maybe a nice pastel floral print?
#13 | |
![]() yup pink faux fur, and big pink furry dice actually. The pictures dont really give it justice the black blends perfectly. took it out to a meet last night, and got tons of compliments.
#14 |
thanks for the info i was searching joannes but i didnt like the print on the fabric im looking for something more abstract any other places you could recommend ? thanks
#15 |
google maps your adress and search for fabric near you. There is a a place near me called fabric fabrique that had cool ****. mostly places that do dresses and stuff.
#16 |
My Ride: automatic m3
Love the way it turned out. Thumbs up!
instagram @bowie__bowie
*tried going gay because I don't get girls crew* *couldn't get guys either crew* *no shower crew* *fap 3x a day crew* *friend zoned by escort crew* *phone vibrates, get excited that a girl texted me, then realize no girls ever text me crew* *Save moms phone number as her first name so people think I have a girl in my phone crew* *female spam bots don't tweet me crew* |
#17 |
#18 |
What about a headliner to match?
#19 |
maybe a bit much to do the whole headliner. May do the dome light/sensor thing between the front seats though.
#20 | ||
it looks b1tchin in person. its so subtle u might miss it at first. people get in and are like did the car come from the factory like this cuz your is sorta ballin.that would be overkill. i would
| Tags |
| cloth trim, cool, diy, e46, trim wrap |
