Old 03-21-2010, 01:32 PM   #1
lilbimmer
My Ride: 01 330ci Step
Send a message via Yahoo to lilbimmer
Escaping air noise coming from Engine
I hear some air escaping from what seems to be a small box attached to the right side of the engine just behind the dipstick. The noise is pretty loud hissing sound and I do not know what is causing it. Is this normal?
History:
I have been having issues recently (this winter) where the car starts violently upon cold starts. At first I thought is was due to the extreme cold weather here in MD, but it has been warm the past week and it still happens. Idle above 650 it seems fine, but at 550 it is rough. Twice it would get to the point where the car would not start (or actually cut off after starting) and I would have to jump it.
Codes thrown:
p0313, p0300, p1343, p1345, p1347, p1348, p1351, p1353, p0174, p0171. These appear to be related to cylinder misfires and the 017x, which I knew about already, is the fuel leak.
"sim simma, who gat di keys to mi bimma" - beenie man
lilbimmer is offline   Reply With Quote
Old 03-21-2010, 01:44 PM   #2
lllSupra
My Ride: E46 330i
Spark plug
lllSupra is offline   Reply With Quote
Old 03-21-2010, 01:55 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
By right side of engine, I'm assuming you mean the left side of engine behind dipstick? I'm pretty sure right and left are always from car's point of view, not yours...which is why in US, I always tell guys driver's or passenger side...just to be safe.
Anyway, rectangular black box maybe 1" thick, 3" high and about 5" long?
= DISA
Isolate sound with a hose in ear or stethoscope. If it's hissing from there, pretty easy to get to and get it off. There is a gasket that can be replaced...and DISA's go bad pretty often from what I hear.
Many other places for air leaks, so before you go replacing a million parts, isolate well.
HTH
Doug
Facebook.com/DMAXstandup
Mangofy your E46!
dmax is online now   Reply With Quote
Old 03-21-2010, 01:56 PM   #4
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
spark plug? wtf?
sounds like your disa is leaking
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 03-21-2010, 01:58 PM   #5
lllSupra
My Ride: E46 330i
is that small box by any chance the DISA Valve? it could be loose or you could have a ripped intake boot. There are 2 T-40 torx screws that hold hold that thing on try tightening them and check for any leaks in the rubber intake boot that goes down to the throttle body from your MAF and air box.
Old 03-21-2010, 01:58 PM   #6
lllSupra
My Ride: E46 330i
Originally Posted by 330ciandr6 View Post
spark plug? wtf?
For mis firing
Old 03-21-2010, 03:22 PM   #7
lilbimmer
dmax you are correct in your description. Sorry for the confusion regarding left and right. Just curious as to the issues this potential DISA leak can cause. Loss of power/torque or idle issues? As for the spark plug issues, I changed all of them at my last service in November. Could problems be happening already?
Edit: Just came from AA and they tested my battery and told me my charge was low (350v when it should be 850v).
Old 03-21-2010, 03:33 PM   #8
dmax
dmax's Avatar
Can't really comment on issues a faulty or leaky DISA would have, but know you'll find tons of info from searching.
On the battery, if you think you can trust the alcoholics to diagnose your battery, then probably time for a new one...another simple repair! Sorry!
Also, while I'm picking on you, I suspect the 350 vs. 850 is CCA, or cold cranking amps...as our batteries only put out 12 volts...plus or minus. More when running and alt. is charging it...think then it should read 14 something.
Anyway, I also wouldn't be surprised if some of your issues relate to low voltage from battery. Wouldn't be the first time a low battery has caused all kinds of issues...and many sensors need the right power to signal the right things...mostly a guess, OP, but one based on years of experience...just no specific knowledge! Again, sorry!
BTW, I like the idea of trying to tighten DISA...just check torque specs and don't go crazy. If you don't have a Bentley, write back and I'll see what it says...or also search here...some guy posted a torque spec for everything in our car not long ago. What a great place...huh?
Doug
Mangofy your E46!
Old 03-21-2010, 03:54 PM   #9
330I6SPD
My Ride: 2005 330I 6Spd.
Originally Posted by lllSupra View Post
Spark plug
Yeah, you need to stop putting those cheap, noisy plugs in your engine.
330I6SPD is offline   Reply With Quote
Old 03-21-2010, 09:40 PM   #10
lilbimmer
hey dmax can you send me the info from the Bentley manual and I will take a look at this through the week. I will also check out the battery issue.
Old 03-21-2010, 09:50 PM   #11
dmax
dmax's Avatar
I could not find torque specs on the DISA in Bentley...but if the screws are loose, tighten them evenly by feel...it's not 'mad' tight. Also, as others have learned too late, use the right size bit. I remember a guy who stripped his bolt...he used an allen bit that fit...but it was a torx head screw! I'm 'vaguely' remembering T25...but don't trust me!
If you search torque values or something...I bet that posting with a TIS on all torque values will come up...hope so...but think you're going to do it by feel anyway...so my guess would be somewhere between 10-20 lbs...but don't go crazy!
HTH
Doug
Mangofy your E46!
Old 04-04-2010, 12:45 AM   #12
bimmer94
My Ride: 330i
So lilbimmer any updates?
bimmer94 is offline   Reply With Quote
Old 04-04-2010, 01:03 PM   #13
lilbimmer
Yes indeed! I ended up taking it to a local mechanic they ended up finding holes in 2 hoses. They replaced the hoses and now the SES light I have been driving with for over a year has not come back on since (knock on wood). My car also sounds better during early morning starts and the belt noise I used to hear while idle, in reverse and in park, is either non-existent or only shows up when the car has been driven for a while. My power seems to have returned and my gas mileage seems to be doing better.
All-in-all I feel good about my car again. Now to get some work done on my skirts that seem to want to drop of :/
Old 04-04-2010, 07:12 PM   #14
bimmer94
My Ride: 330i
Thats great to hear man, so any idea of which hoses they were, did he do a smoke test on it?
Old 01-17-2013, 12:56 PM   #15
adrianpl
My Ride: 01 330ci
Hey im gay
adrianpl is offline   Reply With Quote
Old 01-17-2013, 02:16 PM   #16
trj
My Ride: 325Ci
Originally Posted by adrianpl View Post
Hey im gay
what a way to bump an old thread.
Cant stop laughing.
