Engine & Performance
Everything to make your car faster! Air intakes, superchargers, turbos, flywheel & clutch, differentials, chips, short shift kits, exhausts, etc..... |
#1 |
JB Racing LTW Flywheel for Non-M 5-speed
Used but the surface is still in great shape, Worked great for me. List price is 646.00 on website, Im looking to get 200 +shipping which is a bargain.
FROM JB RACING WEBSITE: Lightweight Aluminum flywheel replaces stock dual-mass flywheel. Accepts OEM clutch/pressure plate/throw-out bearing components as well as performance aftermarket direct replacements. Will also accept many aftermarket sprung-hub clutch discs. Provides improved throttle response and increased performance. FOR: Fitment: 1998 - 04 E46 320i, Ci w/ M54 2.2L- 6 cyl. 1997 - 00 E46 323i, Ci w/ M54 2.2L- 6 cyl. 2000 - 06* E46 325i, Ci, xi w/ M54 2.5L - 6 cyl., 5-spd. only 1997 - 00 E46 328i, Ci w/ M52 2.8L - 6 cyl., 5-spd. only 1999 - 05* E46 330i, Ci, xi w/ M54 3.0L - 6 cyl., 5-spd. only *Note: All above applications using 5-speed transmissions.*
"If only there was a passing lane for the passing lane"
#2 |
Up!!
#3 |
How many miles on it?
#4 |
under 15,000 Miles, I went to the M5 flywheel with a segmented kevlar clutch and couldn't use this flywheel with the m5 clutch.
#5 |
Up
#6 |
How bad did it chatter?
Check out my BMW Blog
http://smolckbmw.blogspot.com/ Check my Youtube channel for DIY's and fun stuff http://www.youtube.com/user/flipfinish?feature=mhee |
#7 |
Sold
#8 |
so wait, youre usig an E34 M5 clutch AND Flywheel on your E46 5 speed box?
#9 |
ya hes prob using the m5 kit with kevlar clutch from uuc, search on here alot have it. Hey how much difference did you feel when you switch from the stock flywheel/clutch?
I will be installing something like this soon ... j/w
I road in my buddies with 350hp and he switched highways at wot scared tge piss out of me felt as fast other bodies 500hp supra awesome car they are rare hopefully they will bring them back rx8s r ok but I don't like tge rear doors and odd shape and lackbof turbos
#10 |
im aware of that mod, but in that post he said he went to a m5 flywheel, with m5 clutch?
#11 |
this flywheel uses the e46 5 speed clutch and pressure plate kit, i upgraded to the UUC e34 style flywheel, that enables me to use the clutch from an M5, im using the m5 segmented kevlar clutch now.
#12 |
oh, ok.. thats what im fixing to go to also, just got the clutch in, hunting for a flywheel.
thanks for the carification |
#13 |
Call up UUC for the m5 style flywheel, they regularly run 20% off
#14 |
snik is a cheap po bastid, i found a used one, once the deal is done, all i'll need is a new friction disc.
#15 |
my bad snik i guess i miss read
#16 |
np....
