Old 04-17-2010, 10:26 AM   #1
joneperry
My Ride: e46 + S60 + Z
Unhappy Oil Leak =( Please help
Decided to remove the engine splash guard after seeing it wet. When i removed the splash guard, it was half drenched in oil in the rear of it. Cleaned the area with brake parts cleaner and drove for 30 minutes, these are the attached pics of what i have after driving. Please help me identify source of leak
PS there was a lot of oil in the subframe but i thought it could have been from previous messy oil changes but i could be wrong, i hope its not the oil pan
ID:	356457   Click image for larger version
ID:	356458   Click image for larger version
ID:	356459   Click image for larger version
ID:	356461   Click image for larger version
joneperry is offline   Reply With Quote
Old 04-17-2010, 10:31 AM   #2
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
from the looks of some of the pics i would suspect oil filter housing gasket.
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 04-17-2010, 10:40 AM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
...and that's what I was thinking too.
Odds are that the ccv might be spewing out something too if ofh gasket is gone...anyway, OP, check behind the ofh about 8-12" toward rear of car with inspection mirror and good light. If oil is back there too, could be ccv, but I think if it is ccv, it's still the ofh also.
Finally, doublecheck under the PS reservoir...those hoses leak...use new clamps.
Also, when doing ofh gasket, get a new vanos oil line and four crush washers for it...simple to change with ofh g
HTH
Doug
See me in June!
dmax on Facebook
Mangofy your E46!
Old 04-17-2010, 11:08 AM   #4
330ciandr6
My Ride: .
yeah, the drain tube for the ccv could be leaking also
Old 04-17-2010, 12:18 PM   #5
joneperry
so by the looks in pictures 2 and 3, it doesnt seem like an oil pan gasket leak right?
Old 04-17-2010, 12:23 PM   #6
330ciandr6
My Ride: .
thats from the oil running down and along the oil pan
Old 04-17-2010, 02:09 PM   #7
jratoll
My Ride: 330I
I had the same issue couple of months back. I brought it BMW -_-_lership and they keep telling me there's no leak. So after bringing it to them twice and keep getting the same answer I brought it to a locally own shop. They've found an oil leak under the oil filter housing and my power steering hose was leaking also. Glad some of it was taken care off by my extended insurance coverage.
jratoll is offline   Reply With Quote
Old 04-17-2010, 04:48 PM   #8
joneperry
so the oil filter housing gasket could be leaking even if my oil dipstick shows sufficient amount of oil between the two lines right?
Old 04-17-2010, 04:55 PM   #9
Many330i
My Ride: e90 M3
Looks like PS fluid to me....
Many330i is offline   Reply With Quote
Old 04-17-2010, 05:14 PM   #10
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Steam clean the engein install some UV dye in the oil run it for 10-15 min the use a black light and find and repar the leak at the highest point to start
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 04-17-2010, 05:23 PM   #11
dmax
dmax's Avatar
Mine was prolly leaking a year from both ofh and ccv...just a drip or two every night on the ground...a little more on the underskirt...and more yet, dried up on engine...but my level of oil hardly noticed it...so mostly a nuisance I think...that, and I don't think the hoses like oil on them either!
Anyway, you'll be able to tell if there's oil with inspection mirror under the ofh or the ccv...and if it's high up under either or both...well, there you go!
Doug
See me in June!
dmax on Facebook
Mangofy your E46!
Old 04-17-2010, 08:53 PM   #12
joneperry
aite, from everyones input it looks like a legit ofh leak, so i will start removing the airbox and everything else this week. thanks everyone
gasket, leak, oil, oil leak, oil pan
