Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Great Plains & Rocky Mountains
CO IA KS MO MT ND NE SD WY
Thread Tools Search this Thread Rating: Thread Rating: 19 votes, 4.58 average.
Old 04-26-2010, 12:53 AM   #201
Richaraiza
My Ride: TS2+ 330ci, 135i
Send a message via AIM to Richaraiza Send a message via Yahoo to Richaraiza
Originally Posted by nowerelsetoroam View Post
i was thinking internals but 330 sounds good to i got a few miles in my engine
but if i were to go with the 330 would it really be better to put in a six speed?
You don't have to. Oh, and I was wrong. I think. You'll have to go to a 2.8, not a 3.0. 330 parts are different than a 328's. Either way you should be just under 200 with this upgrade. And no, you don't have to go to a 6 speed.
-Richard Araiza - EVO 3 SSK - D-FORCES - TC KLINES - LINEA CORSA Z2'S - ORION V2'S - ARGUAY LIP(R.I.P.) -
- ESS TS2+ - SS HEADERS - JB FLYWHEEL/CLUTCH - CF TRUNK - O.Z. ALLEGGERITA'S - CUSTOM EXHAUST - 3.23 LSD DIFFS ONLINE-
And much more...
Richaraiza is offline   Reply With Quote
Old 04-26-2010, 12:54 AM   #202
2wenty6
My Ride: e36 M3
Did one run in my stock e36 M with Azzy's 330 swapped 325, we were pretty much even up til about 80mph, and then I got scared and stopped going
Edit: Azzy's is an automatic
2wenty6 is offline   Reply With Quote
Old 04-26-2010, 12:55 AM   #203
T330
My Ride: X5
Send a message via AIM to T330
and then there's Rich with his screwed biatch
T330 is offline   Reply With Quote
Old 04-26-2010, 12:56 AM   #204
Richaraiza
lol, must have been fun. Don't be afraid next time. Show him who's boss.
Yes sir.
And much more...
Old 04-26-2010, 12:58 AM   #205
T330
My Ride: X5
Old 04-26-2010, 12:59 AM   #206
Richaraiza
lol, no "h"
And much more...
Old 04-26-2010, 01:01 AM   #207
T330
My Ride: X5
lol I messed it up too, I spelt christina instead of cristina
Old 04-26-2010, 01:02 AM   #208
nowerelsetoroam
My Ride: E46,740i
Send a message via MSN to nowerelsetoroam
i dnt get how the shark injector usb crap works
Swicthed from
a 323 to a 740
nowerelsetoroam is offline   Reply With Quote
Old 04-26-2010, 01:03 AM   #209
azzy989
azzy989's Avatar
My Ride: 325i
Send a message via AIM to azzy989 Send a message via MSN to azzy989
he can do a 330 swap.... 2 options in this case
either
A) do the 330 swap but get a 328 manifold so that you don't have to switch to drive by wire throttle... (this means slightly less power than a 330 because i believe the 330 maf and intake are a lot larger even than the 328's)
B) do the complete swap and convert to drive by wire
both of those are pretty pricey. my swap ended up being cheap because i found the engine for next to nothing.
if i'm honest 200 whp is probably going to be very hard on that budget. 323's probably dyno around 140 whp stock... with the mods you have that puts you at maybe 160 whp
my 325 with headers put down 165 whp and i have the better flowing manifold. cams will probably be good for another 10-15 whp but other than that, you won't see too much more of a gain without going to the larger displacement.
edit:
it looks like the 323 uses the same throttlebody as the 328... that means that it's the same size... 2.5" and you can use the 323 manifold with a 330 motor... but again, it will be less power. i'm sure you'll be over 200 whp with headers and the '330+323 intake swap'
-Azlan *I want to be like CD330*
azzy989 is offline   Reply With Quote
Old 04-26-2010, 01:04 AM   #210
T330
My Ride: X5
azzy!
Old 04-26-2010, 01:10 AM   #211
nowerelsetoroam
My Ride: E46,740i
why thank ya guyz.
if not i guess i could just play the lottery
and get an m3 haha
Swicthed from
a 323 to a 740
Old 04-26-2010, 01:13 AM   #212
azzy989
azzy989's Avatar
My Ride: 325i
azzy!
haaaaay
why thank ya guyz.
and get an m3 haha
lol if you decide to do cams, that will be a pretty good gain and if you rent the cam tools, i could help you install provided the helix gears are already on there...
you could also do the m54 manifold...
the 330 manifold will yield you more torque... but the 325 manifold also has power gains up top. iceman00 did this...
i happen to have a 325 manifold here
Old 04-26-2010, 01:14 AM   #213
nowerelsetoroam
My Ride: E46,740i
the other option was idk if ya guys remember but some guy in kansas said he would attempt to make
a turbo for my car
Swicthed from
a 323 to a 740
Old 04-26-2010, 01:18 AM   #214
02m3csl325
My Ride: is Stage 2 AWD!
Adam, spacers look good, I will agree with Garrett though, 20mm is a huge spacer and there could and most likely will be some issues down the road.
As far as more power from the 323, I have nothing really to add to anything that these guys have already suggested. It's tough with our engines without going FI.
02m3csl325 is offline   Reply With Quote
Old 04-26-2010, 01:19 AM   #215
azzy989
azzy989's Avatar
My Ride: 325i
ops yeah definitely forgot to comment on the pictures...
spacers look awesome, adam! i know i've told you this but those wheels are fantastic... probably one of my favorite oem wheels.
Old 04-26-2010, 01:20 AM   #216
02m3csl325
Originally Posted by azzy989 View Post
haaaaay
I forgot about that because I think Rich has a certain 330 manifold sitting in a box next to our tire surplus store in the garage
EDIT:
I was referring to for me of course
Old 04-26-2010, 01:24 AM   #217
Richaraiza
Lol, Brandond. Just saw the tags for the thread.
nowerelsetoroam, I don't remember that? How much was he going to do it for and what kind? Setup wise?
And much more...
Old 04-26-2010, 01:27 AM   #218
Richaraiza
EDIT:
BTW, did you get my PM about the battery and stuff?
And much more...
Old 04-26-2010, 01:27 AM   #219
azzy989
azzy989's Avatar
My Ride: 325i
EDIT:
lol do it... the swap isn't too hard...and you get a lot more torque if you go up to the 330 throttle body, intake and maf depending on which way you go, you may need a tune
no brandon filled in the first few... the last two were anthony and me
Old 04-26-2010, 01:27 AM   #220
Richaraiza
too funny.
And much more...
bmw exberts, colorado, denver, fifi, gaga ooh-la-la, kitty puuuuury, mile hi, more than you can afford, rolf, saint louis!, spee, steven was huuuurrr, steven's a girl eepsspee, toolberts, trebdesumanu, tuuuuuuuuuuuurbo awd?, vtec power
Rate This Thread
