E46 Xi Forum
Old 03-02-2010, 11:05 PM   #1
OrisuE46
My Ride: 325xi
Suspension Question: Xi vs I
Just curious if anyone knows the difference between a 325xi and 325i when it comes to modding the suspension. i was told you could easily mod 325i coilover to fit an XI...seems like they cant be that different. but i dont know much about cars so i thought i'd ask the forum!
has anyone retrofit coils to fit an XI??
TIA
>>*David*<<
R.I.P
OrisuE46 is offline   Reply With Quote
Old 03-02-2010, 11:37 PM   #2
xi_ter
My Ride: 2003 325xi
xi axles, boots and CV joints can be stressed if dropped too much. I have dropped mine about 1.5 inches by installing an Eibach Pro Kit and replacing the spring pads with the thinnest available. The back pad was 15mm and I replaced it with a 5mm pad. Then get an alignment annually, a good tech will tell you if there are any suspension components that need replacement. So far no problems as a result of the drop.
Old 03-03-2010, 12:22 AM   #3
benjamin1
My Ride: 350z track edition
xbox 360: ImTooNiceAtThis
benjamin1 is offline   Reply With Quote
Old 03-03-2010, 02:21 AM   #4
T330
My Ride: X5
Send a message via AIM to T330
just get xi specific coilovers...
T330 is offline   Reply With Quote
Old 03-03-2010, 06:15 PM   #5
OrisuE46
My Ride: 325xi
that is my plan. i was just wondering what makes the coilovers different. like what would possibly happen "if" i put normal 325i coils on??
>>*David*<<
R.I.P
Old 03-03-2010, 06:17 PM   #6
OrisuE46
My Ride: 325xi
so do you have Xi specific coils? or did you just mod it to Xi specs?
>>*David*<<
R.I.P
Old 03-03-2010, 06:19 PM   #7
grocerygttr
My Ride: 2001 325xiT
maybe different spring rates to make up for the added weight.
grocerygttr is offline   Reply With Quote
Old 03-03-2010, 09:08 PM   #8
mekaneck
My Ride: 2003 325xi
The rear springs & shocks would fit between XI and non-XI. The front struts may have a different mounting location for the sway bar endlinks, otherwise they would be swappable too. You can buy adjustable length endlinks though, so maybe that would solve it if there even is a difference. As far as differences in the actual springs & dampers, I would imagine they would be tuned for the added weight (220lbs) and thicker roll bars of the XI. Don't know how much of a difference that would make though.
2003 325xi Black
mekaneck is offline   Reply With Quote
Old 03-03-2010, 11:32 PM   #9
xi_ter
My Ride: 2003 325xi
I didn't buy coils-over since I didn't want to slam the car although I would like to have the ability to adjust for more winter clearance.
The Eibach Pro Kit sport springs had a different part number for an xi
325xi part number #: 2089.140
325i part number #: 2067.140
Old 03-04-2010, 09:25 PM   #10
OrisuE46
My Ride: 325xi
thanks a lot that answered my question kind of
>>*David*<<
R.I.P
Old 03-21-2010, 10:24 AM   #11
bmwauug
My Ride: 325xi
Can you share how much a shop would chard to have the springs installed?
bmwauug is offline   Reply With Quote
Old 03-21-2010, 06:54 PM   #12
bmwauug
My Ride: 325xi
Any pics?
Old 03-22-2010, 09:38 PM   #13
ZZen330
My Ride: 2002 330Ci
Originally Posted by bmwauug View Post
Any pics?
^ what he said.
ZZen330 is offline   Reply With Quote
Old 03-23-2010, 12:50 PM   #14
xi_ter
My Ride: 2003 325xi
This is a pic of the drop on winter wheels.
Gap in rear is 1 1/2 fingers. The Eibach Prokit plus pulling out the 15mm spring pad and using a 5mm spring pad gave a 1.9 inch drop.
Gap in front is 2 fingers. All from the Prokit. I didn't find any rough road spring pads in my front strut to remove.
Gaps are similar to OEM Sport suspension.
Approx a year on the stock Sachs xi shocks. Comfortable, sportier handling.
Old 04-26-2010, 11:27 PM   #15
OrisuE46
My Ride: 325xi
looks good.. not sure how it would look with rims...i want no gap. low as i can go. slamber lamps style.
>>*David*<<
R.I.P
