Sponsored by The Tire Rack
Old 04-25-2010, 01:19 PM   #1
PhilSiri
My Ride: miata
Aggressive Vb3 fitment?
Hi does anyone know if these wheel and tire specs will sit flush or maybe poke a little in rear on a 2001 325ci/330ci with a fender roll and possibly some negative camber in rear?
19"x8.5" +40mm Front 225/35/19
19"x9.5" +22mm Rear 235/35/19
PhilSiri is offline   Reply With Quote
Old 04-25-2010, 05:34 PM   #2
Solo 323 CI
My Ride: 00 323Ci
The rear will definitely give a little poke but with a trim and that tire size it's very doable. The fronts seem really conservative. Mine were +35 new so I threw on a 10mm spacer and run +25.
Solo 323 CI is offline   Reply With Quote
Old 04-25-2010, 05:46 PM   #3
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
rear will poke as solo said, it is doable for sure though. fronts i would run 9.5+33 with 235/35
Chris
dreamdrivedrift is offline   Reply With Quote
Old 04-25-2010, 09:28 PM   #4
BartenderPlease
My Ride: '03 540i/6 M-Sport
yes and yes
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Trim | JL Audio | V1
BartenderPlease is offline   Reply With Quote
Old 04-25-2010, 09:46 PM   #5
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
8.5@et40 in the front is worthless for fitment. i was running 8.5, et40 + 12mm spacer and it was not super flush, but it was decent. i think a 15mm would be perfect for the fronts.
SL Blak Soldier is offline   Reply With Quote
Old 04-25-2010, 10:12 PM   #6
be-doubleyou
My Ride: 02 325ci
I run 19x8.5 et 18 with 215/35's in the front and 19x9.5 et23 with 225/35's in the rear. The front has a slight poke w/ -1.8* camber. The rear has a 5-8mm poke with factory camber settings, and a slight poke at -2.4* camber. I have both my front and rear fenders rolled & pulled.
Bill
be-doubleyou is offline   Reply With Quote
Old 04-25-2010, 10:13 PM   #7
BartenderPlease
I feel like a 20mm would be best to try and keep up with the rear poke
Old 04-26-2010, 12:47 PM   #8
be-doubleyou
My Ride: 02 325ci
+1. My 8.5" et18 fronts match the 9.5" et23 rear poke very well. With a 20mm spacer on the fronts, the setup in the OP would would look really good. I would go with 215's and 225's though to run less camber and prevent rubbing since coupe fenders are a b1tch to roll as flat as sedan fenders.
Bill
Old 04-27-2010, 12:49 PM   #9
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
The rears going to require a lot more modifications then most people would want to deal with. Just be sure you know what you are getting into before purchasing this fitment. A 235 or 245 tire will be required.
Here's a shot of my car on 9.5 +33 with 255 fronts. I am currently running about -2.4 camber up front on Kumho SPT's.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 04-27-2010, 09:03 PM   #10
BartenderPlease
charles, thats a beauty. link to more pics?
