Difference - swap M3 to 330i brakes/calipers - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-28-2010, 01:03 PM   #1
dinac
My Ride: 330i
I have opportunity to swap M3 setup to my 330i ...
(m3 has 325 x 28 , my 330i is 325 x 25 size)
Does anybody know main difference between these two brakes ? Are they have same No. pistons ?
Is it worth doing it ? Will i notice any difference between this two setup?
Tnx !
dinac is offline   Reply With Quote
Old 04-28-2010, 02:07 PM   #2
paraklas
My Ride: ESS TS2 320ci
Same number of pistons, not worth doing it, wont feel any difference. plus you need to machine the carriers to fit them. Get better pads/fluid/brake lines and you will be more than happy
Old 04-28-2010, 02:10 PM   #3
nathancarter
My Ride: 02 330i
Agreed, not worth it unless you have a specific reason, such as brake fade while you're on the track. For cosmetics, the 330i rotors are the same diameter. For track purposes, the M3 rotors are thicker, so they have more mass for heat absorption and dissipation.
nathancarter is offline   Reply With Quote
Old 04-29-2010, 04:58 AM   #4
dinac
My Ride: 330i
i dont need for track, just wonna better brakes
did you made that swap that you cam claim that is worthless?
icant believe that it wont be difference
....or?...
Old 04-29-2010, 05:05 AM   #5
bishop1977
My Ride: 04 330i ZHP S/C
Just get better rotors and pads and put ss brake lines in
bishop1977 is offline   Reply With Quote
Old 04-29-2010, 05:44 AM   #6
braymond141
My Ride: 96 M3, 02 M3, 01 M5
Both brakes are 325mm in diameter. The regular M3 brakes have 28mm thickness and the 330 have 26mm of thickness. The M3 brakes would be better, marginally, for fade resistance, that's about it. More so if you went with Euro floating rotors.
The stock brakes are single piston and rather useless. It's not worth your time... maybe try to get some ZCP M3 brakes, those are nice and aggressive, but still nothing like BBK's.
braymond141 is offline   Reply With Quote
Old 04-29-2010, 09:11 AM   #7
nathancarter
My Ride: 02 330i
....or?...
If you're not tracking, it won't make a difference. Educate yourself on how brake systems work, and what constitutes "better" braking.
For street purposes:
ANY car can lock up the brakes (or engage ABS) if you stomp on the pedal. That threshold is reached when the brakes stop the wheels from turning, and the tires lose grip on the road. In that case, the brakes are doing their job and the tires are the weak link. If you're engaging ABS but still not stopping fast enough for your tastes, you need better tires. The brakes are doing their job just fine.
For track purposes:
Braking performance can be reduced when the brake system overheats, either due to the pads overheating or the brake fluid boiling. Rotors with more mass can absorb then dissipate heat better than smaller, thinner rotors. Good track pads work best under extreme-heat conditions, but even then you need to be able to handle excess heat, and big brake systems can do that better. Brake overheating is practically never an issue for street cars.
Other factors to consider:
Pad life, brake dust, noise, pedal feel. Do these influence whether your brakes are "better?" IMO, yes. I want quiet pads with no dust; and consistent, responsive pedal feel.
Anyway. Disregard our advice and swap it if you like. For street purposes, the driver and the tires are the weakest link in emergency-stop situations.
Old 04-29-2010, 01:54 PM   #8
33beto
My Ride: 08 328i Sedan(R.I.P)
Send a message via AIM to 33beto
So even the M3 has one piston front calipers? just slightly bigger rotors? wow, imagine that comcept!
33beto is offline   Reply With Quote
Old 04-29-2010, 01:57 PM   #9
dinac
My Ride: 330i
not even bigger , just thicker ..
so if i make swap there will be no difference since iam not going to track
Old 04-29-2010, 02:12 PM   #10
mkodama
mkodama's Avatar
Even if you did go to the track, there would probably be no difference. The 330 brakes I think have the advantage being so much cheaper and being so similar. If you want to have some bling, you can get the BMW performance floating rotors for the 330, and get some higher performance pads, and then you would definitely have a more fade resistant and lighter setup than stock M3 front brakes.
Old 04-29-2010, 02:24 PM   #11
33beto
So what do i need to convert the fronts to a 330 setup? Just rotos, pads and carriers (sorry for the highjack)
Old 04-30-2010, 12:34 AM   #12
mkodama
mkodama's Avatar
all that and the actual calipers.
Old 04-30-2010, 06:55 AM   #13
33beto
thanks! my new Summer proyect.
Old 04-30-2010, 08:34 AM   #14
nk_zhp
My Ride: ZHP / E30 M3
Thicker brakes are designed to absorb more heat. You will not get better braking with them but you will eliminate the fade a little bit. If you aren't tracking this is completely irrelevant.
nk_zhp is offline   Reply With Quote
