Old 04-26-2010, 01:36 AM   #1
Rhino_e28
My Ride: 2003 325it
5 speed swap wont start
I installed all 5spd swap into my e46 touring and it wont start. I wired up the clutch switch correctly. Still no go. Im thinking the EWS is whats keeping me car from starting but am not sure. I check wiring all night with the Bentley.
I also cant code for some reason. My e46 wont code with the bmw gt1. Also my peake wont connect. I traced all its wiring and it all checks out. Im thinking that this issue might of been around since before the swap.
Any ideas, Im losing my mind with this car.
Little side note: I can pop the clutch to start the car.
I heard there is a way to jump connecters on the transmission harness to make the car run with pout coding. I really just need the CEL off and ABS, DSC to work. I can live with the Gear light until i can get the coding problem fixed.
Rhino_e28 is offline   Reply With Quote
Old 04-26-2010, 06:27 AM   #2
tinkwithanr
My Ride: '00 323i + '75 2002
pm neil or ivegotissues666, both of them have been through what your talking about (I'm pretty sure). Good luck getting it to work.
Tinker Engineering - 2014
Mica - 2000 BMW 323i - The one that started it all
Fiona - 1975 BMW 2002 - The Definition of Project Creep
Heidi - 1988 BMW M5 - The piece of BMW history
Silvia - 2013 Subaru WRX - Stock, for now
tinkwithanr is offline   Reply With Quote
Old 04-26-2010, 07:01 AM   #3
ChasCan
My Ride: 2001 330xi
I hear you when you said you wired up the clutch correctly. But, have you tried bypassing the switch completely by connecting the wires directly? Chas
ChasCan is offline   Reply With Quote
Old 04-26-2010, 08:46 AM   #4
tinkwithanr
^^^ If he hasn't coded the car yet it won't be looking for the clutch switch, so that's probably not it. I think it has to do with the auto not being 'connected' electronically anymore.
Old 04-26-2010, 04:22 PM   #5
Rhino_e28
My Ride: 2003 325it
BUMP. No one has PMed me back and I need this car running now!!!! Help Please. Thanks guys.
Cheers
Ryan
Old 04-27-2010, 09:34 AM   #6
Rhino_e28
My Ride: 2003 325it
bump
Old 04-27-2010, 02:23 PM   #7
tinkwithanr
Have you wired the 12V source into the EWS in the Auto tranny's wiring harness yet?
Old 04-27-2010, 06:03 PM   #8
bagrach
My Ride: 2003 325Ci
I am going to guess that the fact that the auto tranny isnt giving any kind of signal, the ecu wont allow it to start. I'm new to BMW's but I know that any loss of signal from critical components and the car wont allow itself to start. Try taking it to the dealership and having them reprogram the ecu for 5 speed and start from there.
bagrach is offline   Reply With Quote
Old 04-27-2010, 08:21 PM   #9
Rhino_e28
My Ride: 2003 325it
I have the bmw Software to code. But neither the computer nor the peake reader will actually read the car OBD. Its like the obd is dead. I check its wiring and it appear to me wired right.
Old 04-27-2010, 08:25 PM   #10
Rhino_e28
My Ride: 2003 325it
The harness i removed??? I have not done that yet.....
Or are you talking about the EWS under the dash where the clutch switch wiring also goes?
Old 04-27-2010, 10:08 PM   #11
tinkwithanr
I'm not sure about the OBD not working, but in order to start the car before it is recoded (i.e. with the auto tranny no longer electrically connected, but without the manual coding) there is a jumper that must be made in the automatic transmission's harness. Look at post #3 on this thread. Follow his diagram and I think that should work.....
http://forum.e46fanatics.com/showthr...ht=swap+jumper
Let me know if this works....
Old 04-28-2010, 01:51 AM   #12
2filthy3
My Ride: e46 m3
I did an e34 auto to man conversion once, initially I just left the auto gear selector switch in place and in park, it worked ok, but there were no loom mods performed.
2filthy3 is offline   Reply With Quote
Old 04-28-2010, 06:46 PM   #13
Lagjunky
My Ride: e30cabby,e46m3tourin
hi mate done this a few times is it turning over? if not the auto ews might need an extra live feed. (must be from the inhibitor switch in the auto shifter to tell it not to start unless its in park) this was pin 9 on the e36 that i did, hope it hasnt changed!
did the car run before?
have you only changed the gearbox/linkage?
good luck
Lagjunky is offline   Reply With Quote
Old 04-29-2010, 07:59 PM   #14
Rhino_e28
My Ride: 2003 325it
So no go. jumped pins 2 and 8 and got no start. Thats guys car was a m52. Just fyi.
