///M3 Forum
Thread Tools Search this Thread Rating: Thread Rating: 37 votes, 5.00 average. Display Modes
Old 05-03-2010, 01:44 PM   #1
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
Exclamation * M3 DIY Thread *
The OFFICIAL Best of the Best M3 DIY Thread
While many DIYs are the same as the non-M3 there are also plenty of M3 specific DIYs and this thread will be a resource to get you all the M3 DIYs you need.
Please email me (Tim@performanceIX.com) with your M3 DIY links so I can add them to the thread. If you know a non-M3 DIY works the same for the M3 send me those links as well!
Existing DIY thread - http://forum.e46fanatics.com/showthread.php?t=519743
Exterior
CF Roof Install
http://forum.e46fanatics.com/showthread.php?t=483306
Fender Rolling
http://forum.e46fanatics.com/showthread.php?t=598528
Interior
Convertible Top Interior Trim Flap Repair
http://forum.e46fanatics.com/showthread.php?t=520323
Dash Removal / Replace
http://forum.E46Fanatics.com/showthread.php?t=628898
OEM illuminated gear knob installation
http://www.argyrides.eu/bmw/accessor...knob/shift.htm
Suspension/Brakes/Drive train/Engine
Brake Rotors and Pads
http://forum.e46fanatics.com/showthread.php?t=410638
Oil Level Sensor
http://forum.e46fanatics.com/showthread.php?t=366659
Front Control Arm Bushing (FCAB)
http://forum.e46fanatics.com/showthread.php?t=140066
PowerFlex Rear Trailing Arm Bushing RTAB DIY
http://forum.e46fanatics.com/showthread.php?t=678004
Replacing all 3 M3 Rear Differential bushings while leaving the subframe on the car
http://forum.e46fanatics.com/showthread.php?t=1101104
Power Steering Pump
http://forum.e46fanatics.com/showthread.php?t=575499
UUC Under Drive Pulley Install
http://forum.e46fanatics.com/showthread.php?t=483472
02 Simulator install
http://forum.e46fanatics.com/showthread.php?t=654222
Installing Adjustable Lower Control Arms
http://forum.e46fanatics.com/showthread.php?t=675565
S54 Vanos Info Thread
http://www.m3forum.net/m3forum/showthread.php?t=545367
Lighting
Angle Eye Install
http://www.fastm.com/m3/angeleyes.html
Corner / Parking Light Delete
http://forum.e46fanatics.com/showthread.php?t=278132
Corner / Parking Light Delete - without risking damage
http://forum.e46fanatics.com/showthread.php?t=694015
Taking your headlight apart
http://forum.e46fanatics.com/showthread.php?t=609558
Changing Xenon Bulbs on 04+ coupe
http://forum.e46fanatics.com/showthr...66#post8288566
Changing Xenon Bulbs on all e46 models (except 04-06 coupes)
http://forum.e46fanatics.com/showthread.php?t=609544
Installing LED interior lights
http://forum.e46fanatics.com/showthread.php?t=640683
Electronics/ICE/Stereo
Parrot Bluetooth using Connects2
http://www.bokchoys.com/differential..._bluetooth.htm
OEM Navigation Retrofit Guide
http://forum.e46fanatics.com/showthread.php?t=203145
BMW 16:9 Widescreen NAV Retrofit
http://forum.e46fanatics.com/showthread.php?t=121982
Carputer
http://forum.e46fanatics.com/showthread.php?t=409009
Maintenance
Fuel Filter Change
http://forum.e46fanatics.com/showthread.php?t=799622
Camshaft Sensor
http://forum.e46fanatics.com/showthr...ghlight=sensor
http://forum.e46fanatics.com/showthr...sensor+exhaust
Belt Replacement
http://forum.e46fanatics.com/showthread.php?t=522832
Blower fan
http://forum.e46fanatics.com/showthread.php?t=418987
Rear Wheel Bearing on the Cheap
http://forum.e46fanatics.com/showthread.php?t=581164
E46 Front Wheel Bearings
http://forum.e46fanatics.com/showthread.php?t=610725
Manual Transmission Fluid Change
http://forum.e46fanatics.com/showthread.php?t=491209
Oil Change
http://forum.e46fanatics.com/showthread.php?t=483444
General/Stuff that didn't fit into any other category
BMW E46 M3 DSC - How to disable it before a race! - VIDEO
http://forum.e46fanatics.com/showthread.php?t=761832
Window Regulators
http://forum.e46fanatics.com/showthread.php?t=104035
http://forum.e46fanatics.com/showthread.php?t=356847
Rim/Wheel Curb Rash Repair
http://forum.e46fanatics.com/showthread.php?t=556806
A bunch of DIYs
http://bimmerinfo.com/diy/
Airbag light - Seat Belt Pretensioner
http://forum.e46fanatics.com/showthread.php?t=565806
Final Stage Resistor
http://forum.e46fanatics.com/showpos...34&postcount=7
E46 M3 Tire/Wheel Sizing Guide
http://www.m3forum.net/m3forum/showthread.php?t=318122
Lock Beep - hear a beep when you lock your E46 BMW
http://forum.e46fanatics.com/showthread.php?t=687303
tim330i is online now   Reply With Quote
Old 05-03-2010, 01:47 PM   #2
Define ///M3
My Ride: E92
Define M3
tiag 2000 323ci - sold
BSM 2004 325ci - sold
AW 2013 328i - sold
MWM 2012 e92 328i - current
Looking 4 e46 M3
Define ///M3 is offline   Reply With Quote
Old 05-03-2010, 02:07 PM   #3
bimmer777
My Ride: subway
Oh this is very nice! Thank you for putting this together.
bimmer777 is offline   Reply With Quote
Old 05-03-2010, 02:46 PM   #4
sick.boy1986
My Ride: ///M3
This was a long time coming, it's funny because I was thinking about how there should be stickies in here with technical data/DIYs instead of just "the pic of the day"...
Maybe that pdf I posted, and the one I linked to from another member should be stickies as well? Thanks for putting this together.
E46 M3
FZJ80
sick.boy1986 is offline   Reply With Quote
Old 05-03-2010, 03:25 PM   #5
MrAdam
My Ride: S.L.O.W.
wow, that probly took a while. THANKS!!!
~Adam
NEED BODY SHOP ADVICE?
135i REPAIR THREAD
911 REPAIR THREAD
MrAdam is offline   Reply With Quote
Old 05-03-2010, 03:30 PM   #6
bimmerfan08
My Ride: F
this will come in handy
"You are free to make choices. You are not free to escape the consequences."
bimmerfan08 is offline   Reply With Quote
Old 05-03-2010, 03:31 PM   #7
lftlane
My Ride: 2006 M3
nice!
lftlane is offline   Reply With Quote
Old 05-03-2010, 03:50 PM   #8
asianscion
My Ride: 2003 M3 SMG Vert
Wow, good stuff. I often find non-M3 DIYs and always wonder what'll be missing/different!
Big thanks!
asianscion is offline   Reply With Quote
Old 05-03-2010, 06:40 PM   #9
Black107
My Ride: 2002 M3
Oh come on Tim, don't be so modest. You can go ahead and sticky this thread
Black107 is offline   Reply With Quote
Old 05-03-2010, 06:42 PM   #10
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
tim
Timeless Motor Group
Old 05-03-2010, 06:52 PM   #11
[phoenx]
Banned User
My Ride: 2006 M3
Good stuff! As other suggested, this should be a sticky
[phoenx] is offline   Reply With Quote
Old 05-03-2010, 07:33 PM   #12
ILLuSioNz X
My Ride: 03 TiAg E46 M3 Coupe
good idea, this thread will make some of the diys easier to find.
-Chauncey
2003 E46 M3 COUPE
Check out my for sale threads: Misc. OEM E46 M3 Steering Wheel Parts | (2) H&R 2.5" 650lb/in coilover springs - $85
ILLuSioNz X is offline   Reply With Quote
Old 05-03-2010, 07:54 PM   #13
ldev869
My Ride: 02 ///M Trois
Send a message via AIM to ldev869 Send a message via MSN to ldev869
+421453563 on the motion to sticky
-Luke
2002 ///M3 6MT
Alpine White/Black
ldev869 is offline   Reply With Quote
Old 05-03-2010, 08:05 PM   #14
redice
My Ride: 06 M3 ZCP
great post!
redice is offline   Reply With Quote
Old 05-03-2010, 08:48 PM   #15
Beamn46
My Ride: 02 M3 SMG CB/CINN
Send a message via AIM to Beamn46 Send a message via MSN to Beamn46
very nice!
Beamn46 is offline   Reply With Quote
Old 05-04-2010, 12:56 AM   #16
bimmerfan08
My Ride: F
Tim, can you sticky this since there is really nothing stickied in the M3 forum? thanks
Old 05-04-2010, 01:44 AM   #17
Kringkily
My Ride: e46 m3 convertible
thank you thank you
Kringkily is offline   Reply With Quote
Old 05-06-2010, 05:00 PM   #18
bimmerfan08
My Ride: F
its stickied
Old 05-07-2010, 03:41 AM   #19
phat///M3
Formerly know as phatbimma
My Ride: 03.5 ///M3 Coupe
Does anyone have a DIY with camshaft sensor replacement that is M3 specific? In particular the intake side?
///M3 CB/BLK Alcantara
H&R Brembo Eisenmann Le Mans OEM CSL Bootlid // Interior // Diffuser // Wheels VCSL Full CF Front Bumper ACS Rogue Engineering Recaro child Seat
Mini Cooper 'Virus' LY/BLK
H&R OEM Aero Kit JCW Chrome Mirrors 17" Split Rims Black Front grills & side grills Recaro child seat
- OEM CSL BABY -
phat///M3 is offline   Reply With Quote
Old 05-07-2010, 10:55 AM   #20
///matth
My Ride: 04 M3 vert SMG
Great post... how about a DIY to replace springs/gear position sensor in SMG, anyone tried it themselves?
'04 M3 vert smg
///matth is offline   Reply With Quote
