Sponsored by The Tire Rack
Old 05-07-2010, 01:48 PM   #1
ECSTuning
ECSTuning's Avatar
My Ride: BMW
: ECS Tuning : H&R Hub Adapter/Spacers & HubCentric Rings ~ 72.5mm-74mm & 74mm-72.5m
Want to run a wider selection of wheels on your BMW but don't want harsh wheel vibrations?
H&R TRAK+ hub adapters convert your 72.5mm to the 74mm or 74mm to 72.5mm wheel hubs.
Classic example is E39 5 Series Wheels (74mm) on E36/E46 3 Series (72.5mm)
This allows perfect wheel alignment onto the hub eliminating any wheel vibrations.
Made from high grade aluminum and are drilled for the stock bolt pattern.
These are available in thicknesses (5mm, 10mm, 15mm and 20mm) and longer wheel bolts are required.
72.5 to 74mm
Click HERE to order or for more information.
74mm to 72.5
Extended Wheel Bolts
Recommended extended wheel bolts for each adapter...
5mm -12x1.5x35mm
10mm - 12x1.5x40mm
15mm - 12x1.5x45mm
20mm - 12x1.5x50mm
Don't need the extra spacing? We have your solution there too!
Wheel Hub Centric Ring Adapters...
Allows the use of 74mm hub wheels to 72.5mm
As always please let me know if you have any questions! Feel free to shoot me a PM or email.
Cheers,
Joe
