Old 04-07-2010, 09:49 PM   #1
GCC
My Ride: 330ci
Backlights messed up?
so the light on my dash came up that shows that my back lights are supposed to be messed up, however when i checked to see if all of the lights were working, everything was fine. Any idea on what can be wrong with my car?
2001 330ci btw.
GCC is offline   Reply With Quote
Old 04-07-2010, 10:23 PM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
my money is on license plate lights...or reverse lights. And if need be, if it's not just the bulb, search for me and lights and you'll find a solution to broken wires going from body to trunk through the rubber hose.
HTH
Doug
See me in June!
dmax on Facebook
Mangofy your E46!
Old 04-07-2010, 11:09 PM   #3
sammk
My Ride: Bone-stock E92
False alarm due to corrosion in the tail light circuit affecting the ground. There was a bulletin on this. Contents can be found here - http://www.justanswer.com/questions/...-of-a-sudden-a
I assume you mean 'tail light' by 'back light'.
sammk is offline   Reply With Quote
Old 04-11-2010, 02:42 PM   #4
GCC
My Ride: 330ci
yaho one of my licence plate lights are out, but the resta re fine, and i think it might be the false alarm too.
thanks guys ima go get it checked a mechanic too, jst to see whats goin on =)
Old 05-07-2010, 03:10 PM   #5
bond0007
My Ride: 2001 330i
got same prob but my lights are fine, and I checked the wiring as well, no burn outs...
bond0007 is offline   Reply With Quote
Old 05-07-2010, 03:14 PM   #6
leechieh
My Ride: 325i
It is usually not the wiring but the plug the wiring goes into at the tail lights, the parts should be under 10 to fix it at any dealer, just pull out your pins and repin the new harness
leechieh is offline   Reply With Quote
