Old 05-07-2010, 10:19 PM   #1
chaosticbry
My Ride: 2000 323i
help im stuck
ok, i looked at all the DIY's and still cant get the front shock out from under my car, i unbolted everything but i still cant get enough room to pull the shock out from the holder thing, plz help! thanks
chaosticbry is offline   Reply With Quote
Old 05-07-2010, 10:42 PM   #2
chaosticbry
My Ride: 2000 323i
anyone
Old 05-07-2010, 11:08 PM   #3
BodyMan
My Ride: 2002 325i
I assume that the strut is loose in the knuckle,but there isn't enough room to remove it.You might want to remove the 2 bolts that attach the lower control arm bushing to the frame rail.If that fails,then remove the nut on the outer ball joint and separate the knuckle from the control arm. This should give you all the room you need.
BodyMan is offline   Reply With Quote
Old 05-07-2010, 11:20 PM   #4
chaosticbry
My Ride: 2000 323i
i cant get the second bold off... fml.
ok so there is one bolt on the control arm that is with the wheel/ axle which i unbolted so is the control arm suppose to be able to come off now?
Old 05-08-2010, 12:14 AM   #5
chaosticbry
My Ride: 2000 323i
bump
Old 05-08-2010, 12:29 AM   #6
smoke96
My Ride: 2004 325ci
PB blaster.
[QUOTE=Back2Basics;11538236]So you're gonna have your food delivered to you while you sit at your computer screen on the 112th floor responding to questions about dildo's and sex lube's while strangers fill your bank account to acquire the tools needed for their sick, guilty pleasures?
That's pretty ****ing legit man.
smoke96 is offline   Reply With Quote
Old 05-08-2010, 02:34 AM   #7
chaosticbry
My Ride: 2000 323i
1 down! 1 to go
