Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
Rating:
Display Modes |
#1 |
I screwed up and can't post
E46 Dyno Thread
How this will work:
Member name Car/Engine Mods (brand of each mod you want Dyno type Peak numbers Graph I'll go first Name: Iceman00 Car/Engine: E36/7 M52tuB25 Mods: Custom tube type CAI Peak numbers: 185whp/19Xwtq Dyno type: more than likely a bullshit dyno. ![]() Name: Iceman00 Car/Engine: E36/7 M52tuB25 Mods: Custom tube type CAI, thermal wrapped Ebay headers Peak numbers: 210whp/217wtq Dyno type: more than likely a bullshit dyno. ![]() Name:95blkmax Car/Engine: E46 M52tuB28 Mods: Short ram intake, Thermal wrapped headers, Resonator removal Peak numbers: 180whp/189wtq Dyno type: Dynojet ![]() (dyno is vs stock headers) Name: AggieE46 Car/Engine: E46 M54B30 Mods:Sreamline filter, EvoSport pulleys, Shark Injector, Technik Gen3 headers w/ Swain coating, Magnaflow full catback Peak numbers: 220whp/216wtq Dyno type: Dynojet Last edited by Solidjake; 09-18-2011 at 07:42 AM. |
#2 |
We need this stickied? It's a superb idea but I don't think very many members have dyno results
#3 |
Car/Engine: E46/M54B30 Mods: Conforti CAI, Conforti Shark Injector software, UUC Underdrive Pulleys, UUC LW flywheel, Technik Gen2 Headers, UUC TSE3 Exhaust Peak numbers:229whp/222wtq Dyno type: Dynojet Last edited by Iceman00; 06-02-2010 at 01:53 AM. |
#4 |
#5 |
Car/Engine: E36/8 M54B30 Mods: evosport pulleys , fan delete, ebay headers, custom tune, cat delete, home made CAI, spec clutch , 3.73 lsd, 18" m3 wheels Peak Numbers: 219whp/208wtq Dyno Type: Dynojet ![]() Vs stock |
#6 |
If you want to use that reason they also have an auto -> manual swap stickied
GL with the thread though, I look forward to some results being posted. I did smirk at the Z3 results posted. It is an M52 though so it's k
#7 |
Car/Engine: E46 M54B30 Mods:Sreamline filter, EvoSport pulleys, Shark Injector, Technik Gen3 headers w/ Swain coating, Magnaflow full catback, Shrick Cams Peak numbers: 230whp/215wtq Dyno type: Dynojet vs previous dyno |
#8 |
Car/Engine:E30 M54B30 Mods: OBD1 conversion, M50 (small!) TB, 3" MAF. euro headers, warm air intake, E36 OBD2 cats and muffler, custom tune Peak Numbers:216whp/214wtq Dyno type:Dynojet vs standard E36 OBDII headers Last edited by Iceman00; 06-02-2010 at 02:20 AM. |
#9 |
Are you just taking the result out of those threads where people have M52s and M54s? Rather than doing all of that work you could just link to that thread and be done
#10 |
Car/Engine:E39 M54B30 Mods: 3" exhaust and home made intake and NGK Iridiums(#8 heat range indexed to the intake valves) custom tune Peak Numbers:211whp/207wtq Dyno type:Dynojet vs stock DME programming |
#11 |
Huh? These are all dynos on these forums. Just posting a link would negate the whole point of having a dyno thread. You want the information to be readily available and accessible.
#12 |
Car/Engine: E46 M54B30 Mods:Conforti intake and Technik Gen 3 headers Peak power:219whp/218wtq Dyno type:Dynojet ![]() current dyno vs just conforti intake |
#13 |
Name: joema (bimmerfest)
Car/Engine: E46 M54B30 Mods: Dinan CAI, throttle body, exhaust, and stage 3 ECU software Peak numbers: 212whp/211wtq Dyno type: Mods Vs stock |
#14 |
I have a TSE3 and it sounds good...
Actually on a side note.... i would love to see if what the "gains" would be with just a TSE3 for a mod.... hell even 5whp would be nice considering most don't go for actual gains, rather just sound |
#15 |
Name: KrisL (bimmerfest)
Car/Engine: E46 M54B30 Mods: Stock ZHP package Peak numbers: 185whp/179wtq Dyno Type: Dynojet |
#16 | |
Though, I do have a dyno of file that shows a good amount of low end torque gained with the TSE3 (among other mods) |
#17 |
Name: Andy (bimmerfest)
Car/Engine: E46 M54B30 Mods: ZHP package, Conforti Cold Air Intake, UUC TSE3 Exhaust, UUC Underdrive Pulleys, 15 lb 17 x 8 SSR Comp Wheels (wheel/tire combo is 9lbs lighter then stock),3.07 Limited Slip Differential Dyno type: Dynojet Peak numbers: 209whp/207wtq Mods vs stock Name: Andy (bimmerfest) Car/Engine: E46 M54B30 Mods: ZHP package, Conforti Cold Air Intake, UUC TSE3 Exhaust, UUC Underdrive Pulleys, 15 lb 17 x 8 SSR Comp Wheels (wheel/tire combo is 9lbs lighter then stock),3.07 Limited Slip Differential, Ecu reflash by Oscar Velez Dyno type: Dynojet Peak numbers: 213whp/208wtq Vs stock, Vs mods before reflash Last edited by Iceman00; 06-02-2010 at 12:02 PM. |
#18 |
idk seems like a nice little thread, nice to have everything right there
^^ more than likely a useless post
#19 |
Name: Kaz (bimmerfest)
Car/Engine: E46 M54B30 Mods: Stock ZHP Dyno type: Dynojet Peak Numbers: 197whp /200wtq |
#20 |
Name:fso_BamBam (bimmerfest)
Car/Engine: E46 M54B30 Mods: Dinan Exhaust/CAI/Throttle Body/Stage 3 Software, 89 ocatane Dyno type: dynojet Peak Numbers:204whp/205wtq |
| Tags |
| dyno, dynoed |
