Old 04-18-2010, 10:41 AM   #1
heinrict
My Ride: 2001 325I
Car smokes when started
My 01 325 smokes after it is started. Here's the rub! It is intermittant. It smokes badly maybe once e week. I never know when it is going to happen. The car has 100k. (items i replaced recently)I removed the DISA and there is some oil in the intake but not much. I had a vacuum leak, replaced line to CCV or PCV. Don't quite know which one it was. Replaced oil filter housing seal. Change plugs. They were well worn. Fuel milage has dropped off even with plug replacement. This smoke has stumped me. Any ideas???
heinrict is offline   Reply With Quote
Old 04-18-2010, 11:19 AM   #2
viceversa
My Ride: 2004 325i
Questions -
What color is the smoke (blue smoke usually means burning oil)
What does the smoke smell like (sweet smell usually =s antifreeze, burning rubber = something burning/leaning against a hot metal part)
Can you find where the smoke originates from?
Originally Posted by i_ween View Post
OP: I am sure your English Writing teacher told you this every year, regardless of who s/he was: writing is important. Others will either respect you or ignore you or piss on you if you type like a moron. This isn't an instant message site; it's a forum. We aren't texting each other right now. We are typing messages. Type regular English and people are more likely to respond.
viceversa is offline   Reply With Quote
Old 04-18-2010, 11:26 AM   #3
cnotesdip
My Ride: 330ci
did u change the valve cover gasket
cnotesdip is offline   Reply With Quote
Old 04-18-2010, 06:37 PM   #4
heinrict
My Ride: 2001 325I
The smoke does not smell like anything. Not antifreeze- not using any. Oil! Maybe a little but this happens so infrequently I am totally stumped. It is certainly comming out the exhaust. When I start the car and the smoke appears, It appears heavy like I cannot see out of my garage till it clears. Could it be a sticking valve guide??
Old 04-18-2010, 06:41 PM   #5
ChasCan
My Ride: 2001 330xi
Smoke coming out of the exhaust can mean only 1 of 2 things. Either you're burning oil or you're burning coolant. Is the smoke white or blue in color? If white, coolant. If blue, oil. Chas
ChasCan is offline   Reply With Quote
Old 04-18-2010, 09:28 PM   #6
jdstrickland
My Ride: '94 325iC & '00 323i
White, whispy "smoke" on a cold startup is condensation that's inside the exhaust system. It is normal. Sometimes you can observe water droplets from the tail pipe on cold startup, this too is normal.
Old 04-18-2010, 09:36 PM   #7
ChasCan
My Ride: 2001 330xi
Much more than the normal exhaust condensation that appears on regular start up. This type of smoke will not cloud up so badly that you cannot see out of your garage. Chas
Old 05-09-2010, 02:18 PM   #8
heinrict
My Ride: 2001 325I
OK. Smoked heavily again apon startup after 3 weeks of normal starting. I got out of the car and smelled the smoke. Does not smell like anything. Occasionally when the car is started, it runs rough for just a few seconds but never any smoke. Any ideas??
Old 05-09-2010, 02:22 PM   #9
Chibo
My Ride: Nothing
White can also be caused by a stuck injector pouring fuel in.
2005 330i ZHP Sedan (Street/Track)
2002 Honda S2000 (Street/Track)
2003 Yamaha R6 (Track/Race)
2007 Aprilia Tuono 1000 (Street/Track)
Chibo is offline   Reply With Quote
Old 05-09-2010, 02:26 PM   #10
heinrict
My Ride: 2001 325I
Wouldn't I smell a strong odor of unburnt fuel in that case?
Old 05-09-2010, 02:28 PM   #11
Chibo
My Ride: Nothing
Yeah, definitely. I was more adding on to what he said.
Does it only smoke after sitting for a while or overnight?
Old 05-09-2010, 08:03 PM   #12
Renboy
My Ride: 04 330Ci '08 Daytona
If the smoke only occurs after start up, then it's almost always a worn valve guide. Very cheap part, pretty expensive labour.
Renboy is offline   Reply With Quote
Old 05-10-2010, 05:51 AM   #13
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I know that ccv going bad can lead to smoking issues...and from what I've read, the combined with vcg can too (inner gaskets over cylinder holes).
If you just replaced one hose on ccv, maybe it's the ccv valve that's gone bad, which you didn't replace. Maybe one of your plugs is loose (sorry).
Maybe valve is almost clogged and you just need to take her out for real long drive to get her cleaned out. Maybe you filled up with gas from a station that had water in gas...heard of this from no-name brands.
Only other thing I can think of right now, is cylinder head gasket...that the car went through an overheating event prior to your owning it, and you're seeing the evidence now. A little coolant burning up at start up, a little bit of a rough start, then once it burns off, car seems to run fine?
HTH
Doug
Upcoming comedy shows: April 23, Tierney's Tavern, Montclair, NJ, 7:00 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 05-11-2010, 12:49 AM   #14
White_Knuckles
My Ride: 2003 325xi
Pull off your oil fill cap and look under it. If there are water droplets, rust or slime, it's water. Condensation can occur with proper CCV vacuum. Hot to cold weather temp changes and white smoke is condensation in your engine and exhaust system as jdstrickland mentions. Water smoke scared me at first.
Old 05-11-2010, 10:18 AM   #15
TMO3
My Ride: M3
he still hasn't told us what color the smoke is. thats pretty important if we're going to diagnose the problem.
TMO3 is offline   Reply With Quote
Old 06-04-2010, 12:36 PM   #16
heinrict
My Ride: 2001 325I
The smoke is white and smells like the smoke you would see at those crazy dance clubs. My question would be, why so infrequent?? I live in a dry climate (Arizona) I do only take her out for short rides. I do see lots of oil in the intake but am told it is normal for this car!!
Old 06-04-2010, 12:51 PM   #17
rowdy lee
My Ride: 2000 323ci
well then...
simply stop listening to whomever is advising you.
White smoke, intermittent or not PLUS short trips, Arizona or not.... = CVV.
Cough up a measley $150 for an entire new CVV system.
Problem solved. Pay me later.
Next?
I'd buy it in a heartbeat... if only I wasn't living on the moon!
rowdy lee is offline   Reply With Quote
